 Old 07-09-2018, 07:49 AM   #1
markrieb's Avatar
Posts: 5   (View Stats)
markrieb is an unknown quantity at this point
Default Idle Issues
Having issues with my MS6. It has been running fine for a couple of months after a round of mods and working on an email tune with FreekTune.
Symptoms:
Starting having idle issues, surging from 1000-2000 rpm for a bit and then settling in at 2000 rpm. It stabilizes a bit faster, but still high when the AC is on. It is hard to start and won't start unless you give it a bit of throttle. Idle O2 looks good as do fuel trims, but if you rev out of gear a bit, it goes very lean (29) and at about 3000 rpm it starts to stutter like it is on the rev limiter.
I've checked the electrical connections to the throttle body and MAF and cleaned the MAF. I've checked for leaks in the intake, intercooler piping and intake manifold by spraying with starting fluid and watching for changes in idle - no affect/change.
Car Mods:
Corksport oil catch can
Corksport HPFP upgrade
Corksport 3.5-bar MAP*
Corksport EBC*
Corksport 18G upgraded turbo*
CX racing frontmount intercooler and piping*
Go Fast Bits Hybrid BOV*
Corksport 3" short/catless downpipe* and resonated mid-pipe (cat replacement)
3" exhaust
JBR EGR delete*
VCTS removed*
Injector seals replaced with Toyota diesel units*
JBR 3.5" intake*
JBR intake gasket
recent walnut blast/carbon cleaning of valves
Cobb Access Port
Freektune email tune (on version E/nearly done)*
New iridium plugs, one range colder than stock
all fresh fluids
Things marked with * are recent as of mid-May
Car has approximately 140k miles, compression is 170-180 psi across all 4
The tuning process has been going well, this just cropped up out of nowhere. The tune that was in it was working fine for a couple of weeks before this happened
I've included a couple of logs. The first with AC off the second with AC on
Any other suggestions on where to start troubleshooting?
markrieb is offline   Reply With Quote
 Old 07-09-2018, 08:04 AM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Did you email freek yet?? Because you should....
 Old 07-09-2018, 08:22 AM   #3
markrieb's Avatar
I have contacted Freektune and I'm waiting on a reply
 Old 07-09-2018, 08:27 AM   #4
kTaLgsTo's Avatar
To meet seems like a vac leak somewhere... I cannot see logs at work
 Old 07-09-2018, 08:34 AM   #5
markrieb's Avatar
Me too and I've torn the car apart looking for a vacuum leak, but can't find one
 Old 07-09-2018, 01:04 PM   #6
Jeff23spl's Avatar
Posts: 1,813   (View Stats)
the only way to find a leak is to do a leak test. Replace your filter by a tube where you can adapt an air nozzle to pressurize the whole system to 20-30psi and you may get surprises...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-11-2018, 07:11 AM   #7
markrieb's Avatar
Built a boost leak tester and found the leak.
It was the brand new Toyota diesel injector seals. Time to pony up the money for the Corksport seals and tear the intake off again.
 Old 07-12-2018, 05:51 AM   #8
Jeff23spl's Avatar
humm you got lucky to have the right cylinder intake valve open at the time you did the leak test or all 4 leaks ?
Wife drive 2010 CX7
 Old 07-12-2018, 06:21 AM   #9
markrieb's Avatar
Mostly got lucky. It could still be the intake gasket, but all of the intake bolts checked OK on torque and it is one of the teflon thermal gaskets.
I'll know more as I get it disassembled
 Old 07-12-2018, 10:04 AM   #10
kTaLgsTo's Avatar
Thermal gaskets and spacers are always leak city in my opinion....
 Old 07-12-2018, 12:48 PM   #11
Jeff23spl's Avatar
do it recommend an oem gasket on each side or nothing ?
Wife drive 2010 CX7
6th port issues, rich at idle. SlowMotion MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 04-21-2018 11:54 AM
Rough idle/Vacuum issues ThomasSpeed3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 06-05-2017 04:48 PM
Engine Start and Idle issues huviduc MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 02-05-2015 10:57 AM
Idle issues after doing a bunch of work. azazelthegreat MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 02-01-2015 07:09 PM
Idle issues jnin MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 11-06-2013 02:20 PM
Page generated in 0.30012 seconds with 23 queries
