 Old 02-01-2015, 05:46 PM   #1
azazelthegreat's Avatar
Posts: 596   (View Stats)
azazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the world
Default Idle issues after doing a bunch of work.
So i took the car around the block after stocking out and putting a new clutch in
It just felt wrong last night.
The car had a bouncy idle last night. i would rev it to 3000 rpm then let off the gas it would go down to 2000 rpm stop and hover then drop down.
At a loss here no idea what to check.
I did notice a leak around the downpipe last night but it's not there today.
No CEL other than EGR
azazelthegreat is offline   Reply With Quote
 Old 02-01-2015, 05:58 PM   #2
btstarcher's Avatar
Posts: 4,850   (View Stats)
Groans: 112
Sensors all plugged in? What's the vacuum at idle? Did you change intakes?
SnailTune in progress
Vansquish (02-01-2015)
 Old 02-01-2015, 06:01 PM   #3
All sensors are plugged in no cel next to egr
If i a sensor was off it would throw a CEL yeah?
 Old 02-01-2015, 06:03 PM   #4
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Agent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the world
Groans: 665
Groaned at 76 Times in 40 Posts
No AP? Post a log.
Agent_Orange is offline   Reply With Quote
 Old 02-01-2015, 06:04 PM   #5
Originally Posted by Agent_Orange View Post
No AP? Post a log.
Ill remarry it. see if i can post pone shipping it off.
 Old 02-01-2015, 06:07 PM   #6
btstarcher's Avatar
Groans: 112
What mods are still on the car?
 Old 02-01-2015, 06:08 PM   #7
All my mods are in my sig
Autotechs are coming out tomorrow afternoon
 Old 02-01-2015, 06:10 PM   #8
btstarcher's Avatar
Groans: 112
Waiting for log. Guessing a hose is off or something.
azazelthegreat (02-01-2015)
 Old 02-01-2015, 08:04 PM   #9
went to log flashed Cobbs stage 0 v233 map
ran fine.
went to take it around the block got stuck in my driveway
got unstuck pulled it into the garage unmarried the AP ( lol shipping it tomorrow )
let the car idle for a bit tried again issue didn't come back
Is there anyway that unflashing maps can go wrong and make your shit act up?
all i did to the car was put my hood back on...
ran fine.
Last edited by azazelthegreat; 02-01-2015 at 08:04 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-01-2015, 08:09 PM   #10
Police - Grammarhead
Vansquish's Avatar
Groans: 1,837
It sounds like you've got a vacuum leak of some kind. Check all the hoses/clamps between the MAF sensor and the turbo. Also check to make sure that all the hoses to/from the vacuum block on the intake manifold are connected properly at both ends. It's easy to accidentally knock the hose to the VTCS actuator off.
Rough idle/Vacuum issues ThomasSpeed3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 06-05-2017 05:48 PM
Engine Start and Idle issues huviduc MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 02-05-2015 11:57 AM
Idle issues jnin MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 11-06-2013 03:20 PM
Issues with rough idle, no boost after intall of bolt-ons 08ms3stock4now MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 02-15-2013 11:28 AM
Strange Idle Issues after FMIC Install nytmar3 MazdaSpeed 3 - Engine, Transmission & Driveline 14 06-21-2008 12:11 AM
Page generated in 0.29712 seconds with 23 queries
