 Old 02-16-2010, 06:19 PM   #1
aintitthelife98's Avatar
Posts: 121   (View Stats)
aintitthelife98 is a glorious beacon of lightaintitthelife98 is a glorious beacon of lightaintitthelife98 is a glorious beacon of lightaintitthelife98 is a glorious beacon of lightaintitthelife98 is a glorious beacon of light
Default Intermittent P2187 Code after K&N Filter Install
Hello Everyone. Ever since I installed a K&N Drop in Filter a month ago on my 2009 MS3, I have been getting an on and off P2187 Code (System Lean at Idle). The odd thing is that the code comes and goes. It will come on when idling at a light and then 4 or 5 days later will go away after enough engine cycles. I reset the ECU thinking that maybe the computer just had to relearn with the new filter but it came back within a few days of that.
Any thoughts on why this is happening? Should I just ditch the K&N filter and go back to the stock paper filters? I've noticed a slight increase in fuel mileage with the new filter but don't want to do anything that screws up the car.
I'm still under warranty so I was going to take it to the dealer but I figured they would just blame it on the K&N filter and do nothing but charge me for it.
Thanks for the help on this.
aintitthelife98 is offline   Reply With Quote
 Old 02-16-2010, 06:28 PM   #2
danesti's Avatar
Posts: 4,186   (View Stats)
danesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the world
Groans: 137
you have a leak somewhere after your mass air flow sensor.
double check all your clamps (including the inlet pipe to turbo).
2008 STi
Intake
Turboback
AP
danesti is offline   Reply With Quote
The Following User Says Thank You to danesti For This Useful Post:
Chriscote (09-11-2012)
 Old 02-16-2010, 06:34 PM   #3
SSinstaller's Avatar
Posts: 3,922   (View Stats)
Groans: 56
It's likely your K&N had a ton of oil on it and has fouled the MAF... Get some electrical parts cleaner and clean the MAF and you'll be good for a while, but as long as your running an oiled filter, expect to have to clean the MAF every month or two..
Soon to be installed:
 Old 02-16-2010, 07:04 PM   #4
Thanks for the replies. I will go ahead and check for leaks as well as get some electrical parts cleaner and clean the MAF. I'm wondering if the limited benefits of the K&N filter are worth the hassle or if I should just go back to paper filters.
 Old 02-16-2010, 07:41 PM   #5
Groans: 56
I'd keep the K&N.. It only takes a minute to clean the MAF.
 Old 02-21-2010, 08:36 PM   #6
Thanks for the help on this. I cleaned the MAF sensor yesterday and have been driving around a fair amount and the car feels much better and also no CEL. The idle seems to have smoothed out considerably.
 Old 09-11-2012, 12:21 PM   #7
FreshcutzZ's Avatar
Posts: 13   (View Stats)
FreshcutzZ is an unknown quantity at this point
I have a Mazda cx7, anyone know what
I have to do to get rid of the 2187 code?? I checked
The connections and cleaned the MAF still won't go
off. Ive installed a cpe cai,cpe catback and ets tmic. Got a
Feeling it needs more fuel at idle anyone know how to fix? It started after I installed the tmic
FreshcutzZ is offline   Reply With Quote
 Old 09-11-2012, 12:26 PM   #8
Chriscote's Avatar
Posts: 913   (View Stats)
Chriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the world
Groans: 137
Groaned at 17 Times in 7 Posts
my bpv was leaking, replaced with stock and it fixed my issue
Chriscote is offline   Reply With Quote
CEL P2187 Raglem MazdaSpeed 3/6 - Troubleshoot/Diagnostics 56 01-08-2013 09:46 PM
anybody install cabin air filter yet? gsrtype1 MazdaSpeed 3 - How-To's 46 03-11-2010 08:29 AM
Lean Idle After FMIC Install CODE P2187 Sphincter MazdaSpeed 3/6 - Turbo Induction 10 07-30-2009 12:11 PM
Flash of Genius film reveals dirty history of intermittent wiper Haltech Automotive News 0 09-23-2008 05:20 PM
Intermittent Boost Leak? phantom6294 MazdaSpeed 3/6 - Turbo Induction 2 08-28-2008 06:04 PM
Page generated in 0.50436 seconds with 24 queries
