Like Tree4Likes
 Old 10-12-2017, 02:04 AM   #41
Mazduhspeed6's Avatar
Posts: 149   (View Stats)
Mazduhspeed6 is just really niceMazduhspeed6 is just really niceMazduhspeed6 is just really niceMazduhspeed6 is just really niceMazduhspeed6 is just really nice
Groaned at 17 Times in 6 Posts
I know when I did my motor and started adding power and boost, I was getting high knock values and noise from needing to replace the fuel injector seals. I replaced those with corksport seals and all is well. Are you running all of that with no seals, it wouldn't be a bad idea to throw a set of aftermarket seals in, I prefer the corksport cause there's no other required shit with their seals. And I have pulled the injectors and reused their seals with no issues 2x. A lot of people use safe seals or whatever by cpe...whatever you do it would help to eliminate your stock seals as a possibilty.
2007 Mazda Speed6 GT
Power: rebuilt stock motor*
JBR full power path stage II intake w/JBR TIP*
ATP catted downpipe w/ second cat delete*
Corksport HPFP internals*
Corksport BeCuse injector seals*
Corksport Turbo*
Corksport 3.5 Bar MAP sensor*
Corksport EBCS*
Treadstone Tr8 w/ RPM CX racing piping kit*
Suspension: Corksport Lowering Springs
Brakes: Still stock
Driveline: Sure Motorsports R6*
Sure Motorsports Juggernaut*
Sure Motorsports Dreadnaught*
Sure Motorsports shifter bushings*
Corksport weighted Black shift knob
Electronics: Cobb Accessport V3 w/ tune by Will at PD tuning*Purple Drank Tuning*
Mazduhspeed6 is offline   Reply With Quote
 Old 10-12-2017, 05:35 AM   #42
alden's Avatar
Posts: 376   (View Stats)
alden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant future
Man, I hate KR. I was fine for months, hardly any knock at all cruising around town. Then to my surprise, I see a 3.9 KR, then 5.6 the next day...now almost every single day I'm seeing KR up to 3.9! Thankfully this is not during WOT, as I haven't gone WOT in a few weeks. But, what gives?!
Maybe I'll swap my plugs out? I'm fully bolted with stock turbo and run 1 step colder NGK's. I've read conflicting views on opinions of plugs relating to KR, but it's worth a shot I guess. Probably worth it for me to check out injector seals as well.
alden is offline   Reply With Quote
 Old 10-12-2017, 02:33 PM   #43
Jonb82's Avatar
Posts: 404   (View Stats)
Jonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the world
Groaned at 24 Times in 9 Posts
Custom tune or OTS?
Sent while probably pooping
CS TIP/SRI CS RMM CS Sexy Steering Wheel CS Springs & Struts CS Shirt Throw Shifter CS Shifter Bushings CS TBE CS Boost Tubes CP-e TMIC HKS BOV in resirc DM Vented OCC DM TMM DM PMM DM SSP Autotech Internals Custom E33 Freaktune
Jonb82 is offline   Reply With Quote
 Old 10-12-2017, 11:51 PM   #44
alden's Avatar
Originally Posted by Jonb82 View Post
Custom tune or OTS?
tuned by hypnotic tuning!
 Old 10-13-2017, 03:58 AM   #45
Pd tuning...something else I have been debating, while I've been thinking about doing another set of plugs because I'm still running the ones i tuned on, which i feel to those tend to be more abused from adjustment of afr and they were also in the motor under break in. But at around 10k on my motor, I started getting some knock on the highway at partial throttle at the same rpm everytime never anywhere else. Between 3k and 3.6k rpm cruising I'll get 3 to 5 degrees of knock, let off or gas it, it goes away.
So the fact it only happens at that one area of rpm, tells me it's prolly a vibration of some sort that's happening, I have never seen it under WOT. I have also theorized to myself if when you start to see that knock if that's a sign of the VVT phaser or solenoid whatever u wanna call it, going out. Because the day I started seeing it at those rpm ranges, I seemed to start hearing more of half second tick after long standing startups. Prolly just me correlating the two when there is no relation, just seemed coincidental.
Corksport Turbo*
Corksport EBCS*
Brakes: Still stock
 Old 10-13-2017, 04:04 AM   #46
From personal experience tho, when I did my motor, my mech that I had my car at didn't know I was waiting for my CS injectors seals, he put everything together. We went out to test with new stock seals, blew them right out, and was getting crazy knock when it would start to see boost. My CS beryllium seals came and sealed that shit right up. Haven't had an issue there since. And I actually have had to pull them out and reuse them with out a single issue. They say they are one time use, and if I was pushing 5 or 600 id replace them. But I'm only pushing around 350 and the original Corksport seals keep working.
Corksport Turbo*
Corksport EBCS*
Brakes: Still stock
 Old 10-13-2017, 11:19 AM   #47
xfeejayx's Avatar
Posts: 1,728   (View Stats)
Groans: 78
Out of curiosity, did you happen to do an oil change before your KR started happening regularly?
-Wetz
QFT
 Old 10-13-2017, 01:28 PM   #48
alden's Avatar
hmm, maybe some seals are in order for me. Thankfully I too have not seen knock during WOT. I would just love to cruise from my house to work without seeing like 3.9 or 4.5 registered KR, even if this knock isn't something to worry about.
Hmm, I actually did change my oil like 2-3 weeks ago, which would have been right around the time I started noticing the consistent KR. However, I can't say for sure I wasn't getting the knock before that. Why do you ask?
Last edited by alden; 10-13-2017 at 01:28 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-16-2017, 06:50 AM   #49
xfeejayx's Avatar
Groans: 78
I should have been more clear; did you change the type, brand, or viscosity of oil you use? It may be what's causing your part throttle knock. Read the linked article
Investigating Oil Composition, Direct Injection, & Low-Speed Knock
-Wetz
QFT
The Following 2 Users Say Thank You to xfeejayx For This Useful Post:
aackthpt (10-17-2017), speed23 (10-16-2017)
 Old 10-16-2017, 02:29 PM   #50
alden's Avatar
My apologies, I have not changed the type of oil. Routinely run Rotella T6 5w40.
 Old 12-09-2017, 01:54 AM   #51
pbjon's Avatar
Posts: 5   (View Stats)
pbjon is an unknown quantity at this point
same thing was happening to me, bought the car from california and drove down to el paso texas (no problems at all), when i got here, decided to give it some WOT and my check engine came on and read me a PO303 at first (cylinder 3 misfire) got really worried and changed the plugs to 3787 NGKs gapped at .30 (going to regap them tomorrow to a .28). still misfired. (shouldve tested the car out more in cali) then my v3 comes in and tells me that i have my knock at 5.70. 5.70!!!!!! i got really worried and just changed the oil to rotella t6 5w 40 just today. gave it a WOT on third gear and it stayed at 1.75 flat. i still feel like theres still something wrong with the car (fully bolted on stage 3). hopefully it was just the oil but i feel like motor mount might also lead the cause to the knock sensor detecting false knock and making your ap read more than what it should
also i forgot! the guy was running penzoil platinum 5w 30 before i changed the oil. hope this was also a bad cause to the knock and the misfire, probably not, but im reading on what else it couldve been lol
Last edited by pbjon; 12-09-2017 at 01:54 AM. Reason: MSF Database - Automerged Doublepost
pbjon is offline   Reply With Quote
STILL having knock retard! rorys speed MazdaSpeed 3/6 - Big Turbo Builds 11 02-15-2012 09:42 PM
knock retard after maf cal??? greenespeed MazdaSpeed 3/6 - ECU Computer Tuning 10 10-31-2011 06:45 PM
knock retard at wot Swearingen MazdaSpeed 3/6 - ECU Computer Tuning 14 04-22-2010 09:02 AM
Knock retard.. gone Doc MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-06-2008 11:45 AM
Knock retard!!! Eazy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 07-12-2008 05:35 AM
Page generated in 0.33449 seconds with 25 queries
