 Old 05-15-2018, 05:40 PM   #1
alden's Avatar
Posts: 397   (View Stats)
alden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant future
Default Knock under WOT
Hey guys,
I was hoping for some help with KR during WOT. My buddy has a 2012 speed, mods are CS intake/inlet pipe, CS bpv, res delete, and accessport running stage 1. He's getting pretty bad WOT knock at times, no clue what could be causing it. His compression checked out all good. Here are a few logs. Maybe some of you knowledgeable folks can help out.
datalog3.csv
datalog4.csv
alden is offline   Reply With Quote
 Old 05-16-2018, 11:38 AM   #2
Fstrnyou's Avatar
Posts: 2,148   (View Stats)
A lot of threads already on diagnosing KR.
Read them and come back later.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
The Following 2 Users Say Thank You to Fstrnyou For This Useful Post:
alden (05-16-2018), Thor Hammer (05-16-2018)
 Old 05-16-2018, 03:47 PM   #3
alden's Avatar
Expected that response. It started out of no where, right before he was about to buy full bolt ons, so we were hoping someone would be able to quickly look at the logs and see something that we're too dumb to notice. But thank you, he and I will continue reading.
 Old 05-16-2018, 03:55 PM   #4
Fstrnyou's Avatar
Is there E85 in your area?
That's textbook first thing to try if there's unexplainable KR. Confirm that it's actual knock before you go on a rabbit hunt.
Other rides:
History:
 Old 05-16-2018, 05:32 PM   #5
MoMS3's Avatar
Posts: 232   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
Did you see those AFR values in boost? They're ~13.5:1 at 14psi...yikes.
Originally Posted by alden View Post
Hey guys,
Attachment 235775
Attachment 235776
The first thing I'd check is the vacuum hose going from EBCS to inlet pipe, I had mine pop off and give me crazy knock like that due to unmetered air being let in. Something is causing it to run rather lean at WOT, like I say more than likely you've got a leak somewhere between the MAF and turbo inlet.
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
Last edited by MoMS3; 05-16-2018 at 05:32 PM. Reason: MSF Database - Automerged Doublepost
MoMS3 is offline   Reply With Quote
The Following User Says Thank You to MoMS3 For This Useful Post:
Pu Manchu (05-16-2018)
 Old 05-16-2018, 06:35 PM   #6
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,895   (View Stats)
Groans: 539
+20 LTFT, surprised there's no CEL for running lean, maybe your TIP is real loose on the turbo. 13.5afr @ wot is really bad news, stop beating on it and fix your afr
94 M
06 MS6
 Old 05-16-2018, 08:31 PM   #7
alden's Avatar
No E85 unfortunately However, we have tried multiple gas stations and all giving the same result.
We will check that this weekend, thank you!!
No CEL for running lean, just for the EGR, we just installed the EGR delete kit from Damond. During the install we made sure the TIP was tight on the turbo, but we'll double check that!
Thank you guys for the replies! I'll check back in Friday or Saturday and see if any of this has solved the problem. This forum rules.
Last edited by alden; 05-16-2018 at 08:31 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-16-2018, 09:04 PM   #8
Fstrnyou's Avatar
My bad. I can't read the logs on my phone.
Other rides:
History:
 Old 05-17-2018, 01:41 AM   #9
alden's Avatar
No worries man, any and all help is greatly appreciated!
 Old 05-17-2018, 06:09 AM   #10
Jeff23spl's Avatar
Posts: 1,620   (View Stats)
a pre-turbo leak or something wrong with the maf hosing or Maf cal ?
I don't have much references for a k04 but is 160-170g/s for 15-16 psi to be a correct and expected result for the stage 1 map ? It seem a bit low like if the maf isn't reading enough???
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
alden (05-21-2018)
 Old 05-17-2018, 06:28 AM   #11
5doorsoffury's Avatar
Posts: 1,070   (View Stats)
Groans: 74
Check the egr delete plug in the manifold. What size is that cs intake?
MECP
2012 BM
Rfinkle tune in progress
 Old 05-17-2018, 08:38 AM   #12
Jeff23spl's Avatar
yeah, i did the mistake of installing a plastic plug that came loose after few heat cycle...but in my case i did see it because my AFR was rich instead of lean.
Wife drive 2010 CX7
 Old 05-17-2018, 11:47 AM   #13
Fstrnyou's Avatar
Seconded.
g/s should top out in the mid 200's at those pressures on the k04.
Other rides:
History:
 Old 05-21-2018, 12:01 PM   #14
alden's Avatar
we'll check the EGR plug today, and the CS intake is the stock size I believe. It's their stage 2 power series SRI/TIP.
 Old 05-21-2018, 12:46 PM   #15
Fstrnyou's Avatar
Double check your MAFCAL tables. Something sounds screwy. I know you haven't touched them, but check anyways. Compare them to stock values.
As mentioned, lean at part throttle and WOT is typ a leak between MAF and turbo...or a screwed up MAFCAL.
What type of catch can set up do you have?
Other rides:
History:
alden (05-22-2018)
 Old 05-21-2018, 01:28 PM   #16
Groans: 74
Well tbh i would do a boost leak check at this point from the filter location to determin if you have a leak.
How to DIY Boost Leak Tester make that. Do the test and spray soapy water everywhere looking for bubbles. Then in 10 mins you will solve the problem. You will either have a leak or not. If there is no leak then there is the wrong tune loaded up since you are wayyyy off targets.
Once you determin there is no leaks then it is as simple as doing a maf cal.
MECP
2012 BM
The Following User Says Thank You to 5doorsoffury For This Useful Post:
alden (05-22-2018)
 Old 05-21-2018, 02:12 PM   #17
alden's Avatar
Seconded.
So given that its not reading enough, would swapping out my MAF into his car rule out that issue? Or does that not work? Should we recalibrate his MAF? It seems odd that it would all of a sudden fall out of calibration, no?
We did build a boost leak tester, we just need to get a compressor now! The one we had wasn't working.
He has no catch can at the moment. Not sure how to check the MAFCAL tables, but we will research and find out!
Just some more back ground info, his car was running flawlessly, even a bit rich, which is a lot more consistent with this platform. Literally out of no where, his car started running like this after he got his winter tires swapped over to his summers. It's just weird how it randomly started.
We took apart the intake up to the turbo and everything was all snug and tight. Might try putting the stock airbox back in, along with the stock BPV to rule out some stuff. Any other feedback would be appreciated!
Last edited by alden; 05-21-2018 at 02:12 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-21-2018, 02:55 PM   #18
alden's Avatar
Just an update, we just swapped my MAF sensor in his car, went for a drive, we did a wot log, just waiting for him to send it to me. When I watched the AFR during the wot run, it didn't hit over 11.9 though, so maybe his MAF is on its way out? Also, like MUCH less KR.
 Old 05-21-2018, 03:47 PM   #19
alden's Avatar
Updated log with my MAF sensor in his car. We cut it a little short, and started at 3K, we were pretty nervous of zoom zoom boom. Compared to the logs from before, this looks much better, however, I'd appreciate the input of people much smarter than me. lol
 Old 05-22-2018, 07:26 PM   #20
alden's Avatar
Final update. After switching my MAF sensor for his and seeing the result, we felt pretty confident that it was his MAF causing the problems. Today he picked up a new MAF and installed it. Voila! problem solved, and his KR is gone, and AFR is totally normal. Thank you guys for all the help and suggestions, it was greatly appreciated.
 Old 05-22-2018, 09:47 PM   #21
Fstrnyou's Avatar
Congrats on the fix. It looked like everything was pointing to MAF, but I didn't even think to consider a faulty sensor.
Other rides:
History:
alden (05-23-2018)
 Old 05-23-2018, 05:17 AM   #22
alden's Avatar
Thanks man! We didn't think so either, but we stumbled across a thread where a guy had similar issues and his MAF was going out, so we figured we'd try it! Hopefully no damage was done from the knock and messed up AFR.
Knock Knock. Listen to this video and tell me who's there... paoutdoorsman MazdaSpeed 6 - Engine, Transmission & Driveline 16 01-12-2016 06:57 PM
Plug and play knock sensor listening harness. Is it really knock? Turbo_Steve MazdaSpeed 3/6 - ECU Computer Tuning 36 04-16-2015 06:31 AM
Knock Knock Knock..Whose There? (<===total noob) thomas_cory2000 MazdaSpeed 3/6 - ECU Computer Tuning 158 06-12-2014 11:57 PM
Engine knock low speeds/low gear - false knock? Jra2011speed3 2010 MS3 - ECU Computer Tuning 5 12-13-2013 05:17 PM
Page generated in 0.41545 seconds with 26 queries
