Like Tree6Likes
 Old 09-26-2012, 12:41 PM   #1
DylanFYHN's Avatar
Posts: 641   (View Stats)
DylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the worldDylanFYHN is the leader of the world
Groaned at 41 Times in 22 Posts
Default Knocking sound on driver's side
So I installed my JBR chrome Molly the other day and I absolutely love it. Race car all day. But after 2 days I started noticing a slight problem. My car only has 5,000 miles on it, but the RMM started creating random knocking noises when I clutch into first to get rolling? Only if I don't rev high. If I rev over 2500k then it's smooth. But anything lower I get knocking noises under my feet...? Happens in reverse too. Andy ideas what it could be? (sorry if this has been asked)
DylanFYHN is offline   Reply With Quote
The Following 2 Users Say NO Thank You to DylanFYHN For This Un-useful Post:
Easter Bunny (09-26-2012), SofaKingAwesome (09-26-2012)
 Old 09-26-2012, 12:45 PM   #2
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Have you actually gotten under the car to check the mount? Post-Install
The Following 3 Users Say Thank You to helmetface For This Useful Post:
Nathan 6 (09-26-2012), Raider (09-26-2012), SofaKingAwesome (09-26-2012)
 Old 09-26-2012, 12:47 PM   #3
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
check the mount bro
Monotonous ONE is offline   Reply With Quote
The Following User Says Thank You to Monotonous ONE For This Useful Post:
 Old 09-26-2012, 12:49 PM   #4
DylanFYHN's Avatar
My car was on an actual lift 6 foot off the ground when I installed it. Haven't had the chance to check it out again, its only been installed for about a week now. A buddy of mine (shopety) is coming in town this week and we are gunna check it out. I just didn't know if anyone else has heard of or experienced this problem before? Funny thing is that after only 4,500 miles my OEM motor mount was ripped. (discovered this when I took it off)
 Old 09-26-2012, 12:56 PM   #5
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Did you torque it to spec, and use Loctite?
 Old 09-26-2012, 12:58 PM   #6
Nathan 6's Avatar
Posts: 82   (View Stats)
Nathan 6 is the leader of the worldNathan 6 is the leader of the worldNathan 6 is the leader of the worldNathan 6 is the leader of the worldNathan 6 is the leader of the worldNathan 6 is the leader of the worldNathan 6 is the leader of the worldNathan 6 is the leader of the worldNathan 6 is the leader of the worldNathan 6 is the leader of the worldNathan 6 is the leader of the world
Groaned at 6 Times in 2 Posts
Re-torque to 70 ft/lbs. and as @Raider said, use loctite.
2006 LPM MS6 @ 112k
COBB AP/SRI || CS TIP || AT Internals || M2 DP || MF CBE
CXR FMIC || JBR SSP || JBR weighted knob || Centric Blank Rotors
Hawk HPS Pads || PS Boost in Block8Head pod || Kenwood 12
Alpine M500 || XCarLink || CarLED Tails || VG Sharkfin
Nathan 6 is offline   Reply With Quote
 Old 09-26-2012, 12:59 PM   #7
Domino81's Avatar
Posts: 5,081   (View Stats)
The only thing mine did was create a squeaking chatter intermittently.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 09-26-2012, 12:59 PM   #8
leon78's Avatar
Posts: 2,595   (View Stats)
Put a little MAN on to her when you tighten it....prob solved
2013 Scion FR-S (Whiteout)
Less parking more racing
leon78 is offline   Reply With Quote
The Following User Says Thank You to leon78 For This Useful Post:
BOTTLEFED08 (09-26-2012)
 Old 09-26-2012, 01:00 PM   #9
DylanFYHN's Avatar
Good call to the both of y'all, thanks I'll have to try that out this weekend, I'll give feedback on this post after I do that this weekend to see if it solves the problem
 Old 09-26-2012, 01:01 PM   #10
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
@shopety2012, put your fucking dick beaters on this little girl's car and handle this.
Raider and BOTTLEFED08 like this.
 Old 09-26-2012, 01:07 PM   #11
DylanFYHN's Avatar
He is gunna help me, I just said that
cbspd3flip (09-26-2012), SofaKingAwesome (09-26-2012)
 Old 09-26-2012, 01:09 PM   #12
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
I had something similar happen after 5,000 miles with the mounts installed. The Horizontal bolt was a little loose so I torqued it down with a breaker bar and my shifter became a lot smoother and quieter than before. The other bolts I left a t 70 lbs.
Pickles Tune in progress
 Old 09-26-2012, 01:09 PM   #13
Raider's Avatar
Groans: 856
Whiney little faggot, aren't you?
If he was going to come fix it, then why even fucking post?
If you did not torque it to spec, nor use the Loctite, then you can kiss warranty goodbye.
The Following 5 Users Say Thank You to Raider For This Useful Post:
BOTTLEFED08 (09-26-2012), cbspd3flip (09-26-2012), lilred (09-26-2012), Nathan 6 (09-26-2012), SofaKingAwesome (09-26-2012)
 Old 09-26-2012, 01:11 PM   #14
DylanFYHN's Avatar
Originally Posted by himurax13 View Post
I had something similar happen after 5,000 miles with the mounts installed. The Horizontal bolt was a little loose so I torqued it down with a breaker bar and my shifter became a lot smoother and queiter than before. The other bolts I left a t 70 lbs.
Yeah see that's what I'm thinking my problem is. I didn't use loctite in the first place so that was my fault for being a dumbass haha. Besides that small problem, the mount is fantastic. Once I get going that knock goes away entirely. It's mainly when slowly feather into gear, rather than just starting fast. Pretty much like when I'm pulling up into the incline on my driveway is when it's the worst
 Old 09-26-2012, 01:12 PM   #15
Nathan 6's Avatar
I read that in a british accent and shit my pants laughing.
Raider likes this.
2006 LPM MS6 @ 112k
The Following 10 Users Say Thank You to Nathan 6 For This Useful Post:
cbspd3flip (09-26-2012), Crarrs (09-26-2012), gearhead750 (09-28-2012), Kyle Undefined (09-26-2012), lilred (09-26-2012), Mase (09-26-2012), Raider (09-26-2012), SofaKingAwesome (09-26-2012), tooslow10 (10-03-2012), xI Leveler Ix (09-26-2012)
 Old 09-26-2012, 01:16 PM   #16
COCKSTRONG
Groans: 890
@DylanFYHN, suck a cock
@Jonny Quest can join you.
 Old 09-26-2012, 01:20 PM   #17
DylanFYHN's Avatar
Yes, I'll suck a big one for you
 Old 09-26-2012, 02:16 PM   #18
Sideswipe Magnet
Kyle Undefined's Avatar
Posts: 3,378   (View Stats)
Kyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the world
Groans: 332
Groaned at 99 Times in 71 Posts
Yes, I'll suck your big one for you
Fixed.
BOTTLEFED08 likes this.
I would love to change the world, but they won't give me the source code. // Logic never changes, just the syntax. // To be the best, you've got to beat the best.
Black Mica 2008.5 Mazdaspeed 3 GT // Totaled by 18 wheeler // rfinkle2 pump toon 309 HP - 327 TQ // E85 toon 336 HP - 357 TQ // Too many mods to list
Emerald Green 2002 Miata
Mods:
Koyo 37mm Radiator // Tein Street Flex Coilovers // Flyin' Miata Front and Rear Sway Bars // 949 Racing Endlinks up front // 15x8 949racing 6UL Wheels // Toyo R1R tires // Hard Dog Roll Bar
Waiting list:
Full vinyl wrap
Events:
EMWNM '13'14 // MME '13'14 // MNM '14 // NATOR FL BBQ '13'14
LynzeCs bottom bitch.
I shall call LynzeC my sloot and she will be mine and she shall be my sloot. Come on, sloot. Come on, little sloot.
Kyle Undefined is offline   Reply With Quote
The Following User Says Thank You to Kyle Undefined For This Useful Post:
 Old 09-26-2012, 02:34 PM   #19
ibsir's Avatar
Posts: 108   (View Stats)
ibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant futureibsir has a brilliant future
I bet your bolt has backed out since initial install. Same happened to mine. Retourqued it to spec 2 weeks after initial install.... Problem solved
Str8 Triple Tapped
CS SRI~Autotech Internals~Res Delete~JBR RMM~AP V3
ibsir is offline   Reply With Quote
The Following User Says Thank You to ibsir For This Useful Post:
 Old 09-26-2012, 02:51 PM   #20
DylanFYHN's Avatar
Fixed.
Yeah that's what I meant, thanks!
 Old 09-26-2012, 04:38 PM   #21
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
So, I'm sitting here taking a shit reading this retardedly stupid thread. I'm ready to wipe my ass, so i set down the phone with intentions of telling you that i am dumber for having read this bullshit.
while wiping my ass, i got a little shit on my thumb. It's like i forgot how to wipe my ass.
This thread made me so dumb i can't even effectively wipe my ass without getting shit on myself.
And i blame you...
Probably sent from a toilet
it's fun to do bad things
The Following 9 Users Say Thank You to jack_hammer For This Useful Post:
Atlanta (09-26-2012), Dash08 (09-26-2012), Deldran (09-26-2012), Dralphy (09-26-2012), gearhead750 (09-28-2012), Kyle Undefined (09-26-2012), lilred (09-26-2012), Raider (09-26-2012), RayRay (09-26-2012)
 Old 09-26-2012, 04:50 PM   #22
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Bigger question who in the fuck let @DylanFYHN back on? @Raider are you responsible for this?!?!
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
 Old 09-26-2012, 04:56 PM   #23
Raider's Avatar
Groans: 856
He served his week ban. He pm'd me and apologized for posting.
DylanFYHN (09-26-2012)
 Old 09-26-2012, 05:28 PM   #24
silentwolf8's Avatar
Posts: 1,986   (View Stats)
silentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the world
Groans: 44
Well hes still being retarded as before.
Honestly who continues to drive their car with a motor mount issue. U should of checked that the first night it started happening. And dont give this i dont have time bull shit. If u have time to mod ur car, u need to make time for ur fuck ups.
ZOOM ZOOM left the Room
2013 SPW STi // COBB SRI w/Box // COBB BPV // UR Catless DP// UR CBE // COBB Lowering Springs // COBB Sway Bars // +1 NGK // DW65c FP
AWDTuning Tuned
silentwolf8 is offline   Reply With Quote
The Following User Says Thank You to silentwolf8 For This Useful Post:
uncorked11 (09-26-2012)
 Old 09-28-2012, 07:48 AM   #25
Snap Off's Avatar
Posts: 248   (View Stats)
Snap Off is the leader of the worldSnap Off is the leader of the worldSnap Off is the leader of the worldSnap Off is the leader of the worldSnap Off is the leader of the worldSnap Off is the leader of the worldSnap Off is the leader of the worldSnap Off is the leader of the worldSnap Off is the leader of the worldSnap Off is the leader of the worldSnap Off is the leader of the world
I'll just leave this here Bolt Torque: What Is It?
Take that bolt out. Throw it in the trash and go buy a new one. You have done one of two things
Fucked its couch or got really lucky and hit between 70 and 90.
Breaker bar is pretty vague but what I consider a breaker bar tight is some place around 180-240 tq.
I'm not trying to come off as a dick. I'd just hate to see a over stretched bolt fail on you.
2006 CSRT8
CAI, Tune
Snap Off is offline   Reply With Quote
 Old 09-28-2012, 11:52 AM   #26
himurax13's Avatar
Groans: 255
Well I was only able to tighten it about a quarter of a turn or so. My breaker bar is too long to turn more than an 1/8 of a turn before it hits the ground. I doubt I could get more than 90 lbs of torque while on my back with a breaker bar in one hand and an open end wrench in the other.
Snap Off (09-28-2012)
 Old 09-28-2012, 11:57 AM   #27
Raider's Avatar
Groans: 856
Ok, so OP has been keeping me up to date since we left his cornhole gaping.
He is trying to not get killed. He did check and bolts were tight, getting it back on a lift and re-torquing this weekend to make sure. If RMM is ok, then I am leaning to torn trans mount or passenger mount.
 Old 09-28-2012, 12:19 PM   #28
deadlandxtreme's Avatar
Posts: 1,117   (View Stats)
deadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the world
Groans: 82
Or there is a midget trolling him. Hmm, maybe that's where gremlins come from. Sorry for not being helpful, I saw 3 midgets on Razor scooters fly pass me at Lowes during my lunch break and it freaked me out.
2010 Mazdaspeed3- Installed Mods:- GT 3071 (Ported,polished, and coated by Grimmspeed) Polished and coated throttle body (Grimmspeed)TWM Performance Full Replacement Short Shifter Kit, Corksport FMIC (Upgraded size and coated by Calico Coatings), HTP 4" SRI, Forge V2 BPV, Corksport coolant hoses, NGK Iridum, COBB AP, Full Race DP (ceramic coated), Corksport hangers,JBR EGR block off, Autotech HPFP internals. Glowshift triple gauge pod, Aeroforce Interceptor dual gauges, STRI Imperial boost gauge.Stratified EBCS.RSB and Rear Camber Arms ( JBR ). Tein EDFC kit - Tein Super Street Coilovers . Enkei Racing RPF1 .GTSPEC bracing (front to rear)Corksport FSB..StopTech SS Brake Lines-SportStop Cross Drilled and Slotted Rotors-StopTech Street Performance Brake Pads.. Stratified Boost dial and Guardian Angel. JMF Intake manifold. Full Race Exhaust Manifold (ceramic coated). Damond Motorsports CC. SSP CC. PERM PCV Plate. 3bar MAP. , CP-E Triton full exhaust(Tuning provided by Stratified Tuning)
deadlandxtreme is offline   Reply With Quote
 Old 09-28-2012, 12:21 PM   #29
EdgeAutosport.com's Avatar
Posts: 6,209   (View Stats)
Tell him to remove the bolt that goes through the bracket that attaches to the motor.
We had the same exact problem with a car here at the shop and that bolt was tight but it was getting bound up causing the mount to shift and what not. Tell him to remove and put it back it and it should fix the issue
The Following User Says Thank You to EdgeAutosport.com For This Useful Post:
JBR (09-29-2012)
 Old 09-28-2012, 01:09 PM   #30
COCKSTRONG
Groans: 890
I finally had to take mine up to 100 ft/lbs after failing 3 times. Hasn't budged since.
 Old 09-28-2012, 01:20 PM   #31
Raider's Avatar
Groans: 856
I think I did 90 on mine with enough Loctite to make it look like a used tampon.
SofaKingAwesome (09-28-2012)
 Old 10-02-2012, 11:45 PM   #32
DylanFYHN's Avatar
So I got it up on the lift this past weekend to retorque the bolts and loctite them also. Dropped her down and gave her a drive (sounds naughty), no knocking whatsoever. Seemed to have fixed the problem so far. So I waited a few days to post to make sure it stayed the same and it's still going A Ok! Thanks for all the help and tips guys, I appreciate it
The Following 2 Users Say Thank You to DylanFYHN For This Useful Post:
JBR (10-05-2012), Raider (10-03-2012)
 Old 10-03-2012, 09:25 AM   #33
Raider's Avatar
Groans: 856
Glad it's fixed.
Now, about those pics....
 Old 10-03-2012, 09:45 AM   #34
DylanFYHN's Avatar
Glad it's fixed.
I will gladly let you come to my house and take them yourself lol. I love you raider, but I'd rather not throw up on myself O_O
If your patient to wait till my girlfriends turns 18, then I'll post some good stuff!
 Old 10-03-2012, 09:52 AM   #35
Raider's Avatar
Groans: 856
51 year old mom boobs will suffice. @shopety2012, get to work.
shopety2012 likes this.
 Old 10-03-2012, 10:25 AM   #36
OG Prostitute
shopety2012's Avatar
Posts: 1,055   (View Stats)
shopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the worldshopety2012 is the leader of the world
Groaned at 68 Times in 40 Posts
thats a long as way to go for some old tits
stock as fuck gay blue pu, still haz juan tranny and evox wheels in shocker yellow tho
currently forging a monster sr20det LS swap killer... brb
used to be the "best looking life partner blue ive seen" - Voltron
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
TEAM Dad -- FYCN
shopety2012 is offline   Reply With Quote
 Old 10-03-2012, 10:31 AM   #37
DylanFYHN's Avatar
That's what I'm saying! But hey, anyone one of y'all are welcome to come try! (not being a smartass)
 Old 10-03-2012, 10:41 AM   #38
OG Prostitute
@tooslow10 is closer though (;
TEAM Dad -- FYCN
The Following User Says Thank You to shopety2012 For This Useful Post:
 Old 10-03-2012, 11:23 AM   #39
Raider's Avatar
Groans: 856
This is all not my problem. None of it. Just get the job done (in a Paul Sr. voice from American Chopper).
 Old 10-03-2012, 11:38 AM   #40
OG Prostitute
with a mustache, like a sir
TEAM Dad -- FYCN
Knocking/ clicking sound from under car/ driver side Zbrit00x Gen2 MS3 General Discussion 8 08-23-2012 09:16 AM
full motor mount install.... now have knocking sound peter_parker8740 2010 MS3 - Engine, Transmission & Driveline 2 06-20-2012 06:21 PM
Knocking sound w/ video... RiceBurn2.3T CX-7 > Issues & Troubleshooting 54 08-03-2011 07:27 PM
knocking sound on acceleration, not ABS bzwyatt CX-7 > Issues & Troubleshooting 5 12-15-2010 07:05 AM
Knocking sound coming from rear differential on acceleration volodya84 MazdaSpeed 6 - Engine, Transmission & Driveline 3 04-23-2010 07:31 AM
Page generated in 0.55083 seconds with 37 queries
