 Old 07-23-2019, 05:34 PM   #1
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
Default Leaking from Clutch Hardlines
When I parked the my MS3 last week, the clutch pedal stuck to the floor and I found fluid leaking from the master cylinder hardline where it meets the master.
I just replaced both the master and slave and now I'm leaking from BOTH the hardline at the master and the slave. I haven't heard much about having to replace these lines, am I missing something here? Both are pressed into their respective cylinder with the retaining clip in place.
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A.
 Old 07-23-2019, 08:45 PM   #2
Sensei's Avatar
Posts: 318   (View Stats)
Sensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the world
I swapped out my slave cylinder when I replaced the clutch about 2 months ago. From what I recall the clutch line just slides into the slave cylinder and once it bottoms out it is held by the retaining clip as you described. If these cars used line nuts instead of the silly clips you could probably just tighten them up. It seems likely that the sealing surface on the old line is worn. The parts involved are so simple that if you're confident you got the line seated the best you can and it still leaks I'd just replace the line.
2009 MS3: Freektune 280/330, CS SRI+TIP, 3" Test Pipe, TR8 FMIC, AT internals, APv3, JBR SSP/CW/SB, JBR RMM 88a, JBR PMM 80, Koni FSD/Stock Springs
Sensei is offline   Reply With Quote
Clutch master cylinder leaking nate montoya MazdaSpeed 3/6 - ECU Computer Tuning 4 01-06-2018 12:57 PM
Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? Douggievee MazdaSpeed 6 - Engine, Transmission & Driveline 14 05-14-2015 10:44 AM
leaking break fluid from clutch line need help Roofis119 MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-20-2014 11:37 PM
Clutch stuck to floor, hydraulic fluid leaking Nate010 MazdaSpeed 3 - Engine, Transmission & Driveline 1 12-10-2013 06:45 PM
Leaking clutch line bova MazdaSpeed 6 - Engine, Transmission & Driveline 3 12-23-2011 10:09 PM
Page generated in 0.23482 seconds with 21 queries
