Like Tree27Likes
 Old 05-22-2012, 08:13 PM   #1
jack_hammer's Avatar
Posts: 6,821   (View Stats)
Groans: 549
Default low comp + leaky leak down = inj seals?
@Boost_creep was attempting to do an e-tune for me and we came across some knock. it just wouldn't go away. we tried everything but it persisted.
eventually, i did a compression test. initial results were not favorable. now, in hindsight i did not hold down the gas pedal properly. but these were what i got.
cyl 1: 182
cyl 2: 182
cyl 3: 165
cyl 4: 185
so, i went and bought a leak down tester. this is what i got, but it's wacky.
cyl 1: 15%
cyl 2: 30%
cyl 3: 50%
cyl 4: 2%
not convinced i had the leak down tester working properly, i decided to do the compression test again. this time, i held down the accelerator the entire time.
cyl 1: 190
cyl 2: 185
cyl 3: 172
cyl 4: 190
so, they were not the same numbers but the proportions were the same. this time i went and added 1/2 teaspoon of oil into cyl 3. then i retested the compression.
cyl 3: 178
i know the theory is that if you add oil and it increases compression, then you have bad rings. but this barely increased pressure.
on the other hand, i have read that if you have a leaky fuel injector seal, then you will have high loss on the leak down test.
questions:
is it possible that the leak down tests were accurate?
is it possible that replacing the injector seals will cure my problems?
is there something else i am missing?
thanks
<edit #1>
this is what i ended up deciding to do:
*clean valves
*install PTP seals & injector studs
*SURE 1/8" intake TIG
*replace the OEM retainer on my fuel pump b/c the one in there had some wear on it
<edit #2>
post installation test results
*massively reduced knock
*leak down
1 - 35 / 33 (5%)
2 - 33 / 24 (27%) through the oil filler
3 - 33 / 21 (37%) through the oil filler
4 - 33 / 32 (3%)
*compression:
1 - 185
2 - 182
3 - 170
4 - 187
it's fun to do bad things
The Following 3 Users Say Thank You to jack_hammer For This Useful Post:
ak_spray (06-12-2012), Boost_creep (05-23-2012), ganque (05-23-2012)
 Old 05-22-2012, 09:40 PM   #2
Posts: 12,651   (View Stats)
When doing the leakdown test, where was the leak? You can listen for it and see if it's coming from the crankcase (rings), intake manifold (intake valves), exhaust manifold (exhaust valves).
The Following 6 Users Say Thank You to Lex For This Useful Post:
Boost_creep (05-23-2012), jack_hammer (05-23-2012), rfinkle2 (05-23-2012), smoogs12 (05-23-2012), SPEED6 KILLAH (06-05-2012), themytb (05-23-2012)
 Old 05-23-2012, 06:18 AM   #3
Groans: 549
i could not figure out where it was leaking. i did not hear anything from the crankcase. how can you hear from the intake or exhaust valves?
in all honesty, though, i'm not 100% sure i did the test correctly. it's either that or they leak like a mofo.
the instructions said to put the regulator on the tester to be 10psi lower than the source. i put my compressor at 40psi and the regulator to 30psi. but when i connected it to the hose going into the cylinder, the gauge pressure dropped way lower than 30. however, the pressure on my compressor still showed 40.
i thought maybe i had missed TDC somehow (on 3 of 4 cylinders? seems unlikely, though)
see my illustration below. these may not be the exact numbers b/c i didn't write them down. however, you should get the idea.
The Following User Says Thank You to jack_hammer For This Useful Post:
 Old 05-23-2012, 06:25 AM   #4
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Best of luck getting this worked out. You are in good hands with Boost_Creep. He may be lesser known e-tune wise, but knows all of the tables in and out.
If you eventually decide to do the seals, have you seen the Toyota diesel option that seems to be working well for everyone?
The Following 4 Users Say Thank You to rfinkle2 For This Useful Post:
Boost_creep (05-23-2012), btstarcher (06-01-2012), jack_hammer (05-23-2012), SLOWHATCH (05-23-2012)
 Old 05-23-2012, 06:35 AM   #5
Police
ganque's Avatar
ganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the world
Best of luck buddy, I'll help you out when I get there. If it was a valve or a valve seal it would be smoking so I also agree on the injector seals theory.
SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQ
SOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW!
MS3 vs Focus ST vs Camaro LS1 ---> Click here
TEH MEXICAN'T PERM!
Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes
ganque is offline   Reply With Quote
The Following 2 Users Say Thank You to ganque For This Useful Post:
 Old 05-23-2012, 06:38 AM   #6
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
You can listen for an intake valve leak at the intake/throttle body, and you can hear exhaust valve leak if you listen at the end of you exhaust. Worn piston rings and that kind of stuff you would be able to hear air coming through the dip stick. And if its a head gasket or something like that you should get bubbles in your coolant tank.
rfinkle2 and leifmadsen like this.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 10 Users Say Thank You to smoogs12 For This Useful Post:
Boost_creep (05-23-2012), Constantin (06-04-2012), jack_hammer (05-23-2012), leifmadsen (09-05-2017), Lex (05-23-2012), rfinkle2 (05-23-2012), stockms3 (07-11-2014), themytb (05-23-2012), Tokay444 (05-23-2012)
 Old 05-23-2012, 06:47 AM   #7
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
I had been working from the assumption that if the injector seal was bad enough to show up in a leak down test you would be getting the primary symptoms- some KR, and be able to see fuel, maybe even hear it?
340hp / 371tq
The Following 3 Users Say Thank You to TiGraySpeed6 For This Useful Post:
 Old 05-23-2012, 07:17 AM   #8
smoogs12's Avatar
Groans: 423
@broncojd78 You did the LD test on the compression stroke right?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 2 Users Say Thank You to smoogs12 For This Useful Post:
 Old 05-23-2012, 07:29 AM   #9
Groans: 549
i am aware of the toyota seals, but thanks for checking. i had read a few posts in it before, but i just read the entire thing. i don't know that i'm convinced, though. i'm really tempted to go with the HPFPupgrade seals. the theory of "well if they fail i only wasted $8" is not something i buy. i enjoy working on my car, but i don't want to do the same job twice. but, being as cheap as i am, i'm considering them. i just haven't decided.
was definitely getting KR. not real high levels, but constant levels throughout my WOT logs. jason pulled 2 degrees of timing and it still knocked.
i did them at TDC. i had a long socket extension in the cylinder. i turned the crank and my wife told me when it got to TDC. then i would do the leak down test.
The Following 4 Users Say Thank You to jack_hammer For This Useful Post:
predapio (05-23-2012), rfinkle2 (05-23-2012), smoogs12 (05-23-2012), TiGraySpeed6 (05-23-2012)
 Old 05-23-2012, 07:43 AM   #10
smoogs12's Avatar
Groans: 423
Did you confirm that it was tdc on the comp stroke?
Your compression tests dont really seem to lend themselves to a 50% leakdown.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 4 Users Say Thank You to smoogs12 For This Useful Post:
Caldazar (06-03-2012), jack_hammer (05-23-2012), rfinkle2 (05-23-2012), themytb (05-23-2012)
 Old 05-23-2012, 07:45 AM   #11
Groans: 549
damn, i guess not. how do you do that?
 Old 05-23-2012, 07:55 AM   #12
smoogs12's Avatar
Groans: 423
The way I do it is just kind of "plug" the spark plug hole with something. I like to use something light like tissue paper.
The idea behind this is that if the cylinder is on its compression stroke it will move the paper do to the air being forced passed it. If its on the exhaust stroke you would not see the paper move due to the exhaust valve being open.
Edit:you could also determine it through the firing order of our engine (not 100% sure what it is)
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 3 Users Say Thank You to smoogs12 For This Useful Post:
Boost_creep (05-23-2012), jack_hammer (05-23-2012), themytb (05-23-2012)
 Old 05-23-2012, 08:04 AM   #13
Groans: 549
that sucks, because it is a pain in the neck to do everything to be able to do that test.
on the other hand, if it was bad rings, when i added the oil i would have expected to see a bigger increase in compression. so, doesn't that lend to the idea of the rings being OK?
at this point, i'm really leaning toward replacing the seals. and while it is disassembled, replacing the injector studs and cleaning the valves as well.
i am trying to make sure that there is not some red flag right now that pointing to piston rings, meaning that the injector seals are probably good and replacing is a wasted effort. if i have to, i will do the leak down test again. but i'm leaning toward just doing this to know for certain that i have done everything possible. for the relatively small expense of doing it and finding out 100%, it might be worth it, regardless of a new leak down test.
if the compression is legitimately dropping, i'll have to consider cutting my losses with the car and moving on. i'd rather not.
Boost_creep (05-23-2012), rfinkle2 (05-23-2012), smoogs12 (05-23-2012)
 Old 05-23-2012, 08:08 AM   #14
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
exactly this^ just place a small piece of tissue over the s.p. hole it will float up when on the comp stroke-- not sure why I repeated it, just want to seem smart to I guess.
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
themytb is offline   Reply With Quote
The Following 2 Users Say Thank You to themytb For This Useful Post:
 Old 05-23-2012, 08:16 AM   #15
rfinkle2's Avatar
Groans: 298
Firing order courtesy of SSinstaller:
TiGraySpeed6 likes this.
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
Boost_creep (05-23-2012), jack_hammer (05-23-2012), smoogs12 (05-23-2012)
 Old 05-23-2012, 05:08 PM   #16
Groans: 549
Ordered ptp/hpfpupgrade injector seals and stud kit. I am going to shoot to install next weekend.
Also snagged a SURE intake TIG on clearance.
Sent from my LG-MS690 using Tapatalk 2
Boost_creep (05-23-2012), predapio (05-23-2012), smoogs12 (05-23-2012)
 Old 05-23-2012, 09:43 PM   #17
POWERED BY POLSKA
themytb's Avatar
Groans: 38
Cleaned your valves yet? May want to nut that shit while you're in there. It works fanfuckingtasticly.
25%E85FREEKPERMED
 Old 05-24-2012, 04:35 AM   #18
Groans: 549
No i have not. However, that is most definitely on the to-do list. Well i probably won't media blast, but i will clean them.
 Old 05-24-2012, 04:46 AM   #19
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,162   (View Stats)
Groans: 793
Firing order is the same on all flat plane crank 4 cylinders, and the leak down test is best performed with the valve cover off.
You can see by cam orientation that your at tdc, and it's much easier to locate leaky valve seals.
TiGraySpeed6 and rfinkle2 like this.
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 7 Users Say Thank You to Tokay444 For This Useful Post:
Boost_creep (05-24-2012), Easter Bunny (05-24-2012), goHAMM (02-07-2015), jack_hammer (05-24-2012), rfinkle2 (05-24-2012), smoogs12 (05-24-2012), TiGraySpeed6 (05-24-2012)
 Old 05-24-2012, 12:01 PM   #20
POWERED BY POLSKA
themytb's Avatar
Groans: 38
I have done both the solvent and media methods, and honestly the walnut takes about the same time(I was using a way undersized compressor) but the results are in comparable.
Plus the smell of roasted walnuts the first time you fire it up afterwards is lovely LOL.
Sorry for being a dick and derailing the thread.
25%E85FREEKPERMED
The Following User Says Thank You to themytb For This Useful Post:
 Old 05-24-2012, 12:41 PM   #21
Groans: 549
you're not being a dick, you're bringing up a really good point about cleaning the valves. i only have a small pancake compressor that holds a couple gallons and has max pressure of 100psi. i am just reluctant to shoot matter into the heads. even if i "should" be able to get it out completely, why take the chance? i have read that methanol pretty much dissolves the carbon build up, so i am going to try to acquire some.
 Old 05-24-2012, 12:43 PM   #22
rfinkle2's Avatar
Groans: 298
Yellow bottle HEET = METH.
Boost_creep (05-24-2012), fooqr (06-01-2012), jack_hammer (05-24-2012)
 Old 05-24-2012, 12:48 PM   #23
Groans: 549
this?
Heet 28201 - Fuel Treatment | O'Reilly Auto Parts
 Old 05-24-2012, 12:51 PM   #24
rfinkle2's Avatar
Groans: 298
Yes sir. 99% methanol.
I spray it like it is going out of style. LOL
jack_hammer (05-24-2012), Tokay444 (05-24-2012)
 Old 05-24-2012, 12:52 PM   #25
Curious how the meth compares to denatured alcohol for cleaning the valves?
The DA worked well for me, but open to new ideas on the subject for sure
340hp / 371tq
 Old 05-24-2012, 12:54 PM   #26
rfinkle2's Avatar
Groans: 298
According to Daddy Chinkus, dentaured alcohol > meth.
I have been contemplating spraying some denatured alcohol occasionally.
TiGraySpeed6 (05-24-2012), Tokay444 (05-24-2012)
 Old 05-24-2012, 01:00 PM   #27
not sure that there is enough duty cycle time from spraying to get any real major cleaning benefit.
Keeping things clean may well be another story tho, I dunno.
340hp / 371tq
 Old 05-24-2012, 01:04 PM   #28
rfinkle2's Avatar
Groans: 298
Auto clean (if it works) > mani removal LOL. Sorry Bronco for the derail.
 Old 05-24-2012, 01:07 PM   #29
Groans: 549
i sent you a PM to avoid the derail, but whatever. i'll get this back on track once i get the seals installed...
how many miles would that $2.30 bottle last?
also, the cleaning benefit of meth is not to be discounted. sure, you get more power, cooler bats, etc... but the cleaning benefits are significant.
however, the expense of the set up and the risk of hydrolock are greater than the additional power or cleaning benefits, in my opinion.
 Old 05-24-2012, 06:27 PM   #30
Groans: 549
you got me looking at the differences between the meth kits and what you can / can't run.
according to the snow performance website:
• Isopropyl/Denatured Alcohols: These can be used, but are not as good as methanol. They have a lower BTU, or energy content, and a lower latent heat of vaporization (fancy way of saying how much heat they absorb) as well as a lower octane rating compared to methanol.
Snow Performance : FAQ gasoline
 Old 05-24-2012, 06:41 PM   #31
rfinkle2's Avatar
Groans: 298
LOL. I didn't mean to turn you onto meth / spark an interest. Daddy Chinkus once did a write-up comparing how effective a couple of cleaning fluids were on our valves and denatured alcohol had the best cleaning properties.
(IIRC, he used meth, denatured alcohol, b12 chemtool and seafoam).
jack_hammer (05-24-2012), TiGraySpeed6 (05-24-2012)
 Old 05-24-2012, 07:19 PM   #32
Ziggo's Avatar
Posts: 3,843   (View Stats)
I just used the b12 last weekend and it did a good job. Where in Dallas are you?
Ask Me About My:
jack_hammer (05-24-2012), rfinkle2 (05-25-2012)
 Old 05-24-2012, 07:40 PM   #33
Groans: 549
i have denatured alcohol and seafoam already. maybe i'll get the b12 and heet and do a comparison myself.
and i live in oak cliff.
 Old 05-24-2012, 07:59 PM   #34
Cobb did the same as part of their high mileage service bulletin- clicky-clicky
340hp / 371tq
jack_hammer (05-30-2012), rfinkle2 (05-25-2012)
 Old 05-24-2012, 08:18 PM   #35
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
Anybody think denatured 100% ethanol would work well? I have a ton of the shit at my disposal.
The Following User Says Thank You to I<3Groceries For This Useful Post:
rfinkle2 (05-31-2012)
 Old 05-30-2012, 11:14 PM   #36
Groans: 549
tomorrow / today / thursday - i'm going to get to work. replace the studs and seals, plus give the valves hell as best i can.
i'll let you guys know how it goes.
The Following 2 Users Say Thank You to jack_hammer For This Useful Post:
Boost_creep (05-31-2012), smoogs12 (05-31-2012)
 Old 05-31-2012, 10:47 PM   #37
Groans: 549
alright, so i had written a big post but then accidentally hit the "back" button and lost it all. so, i'm not writing it all again.
bottom line: not completed yet. valves were gross. 71000 miles. no EGR block off. no catch can. no meth. nothing. i've read a lot of the valve cleaning threads the last week or so. i did not see anything that looked worse than my valves.
had to use a combination of denatured alcohol, gun cleaning brushes, a screw driver, and walnut blasting. the meth made the buildup become a gross goo. i actually drove to harbor freight and bought the blaster and media before i finished the first valve. they were that bad. unfortunately, my 3 gal 100psi compressor didn't do very well for powering the blaster. but, i got everything sufficiently cleaned through fortitude and perseverance.
so, valves are cleaned. still need to remove the fuel rail and install the seals and studs.
is there any trick / tip to removing that? i started to try getting that removed, but it did not come right off. it was late so i did not fight with it. i just left it alone for tomorrow.
The Following 5 Users Say Thank You to jack_hammer For This Useful Post:
ak_spray (06-12-2012), Boost_creep (06-01-2012), rfinkle2 (06-01-2012), smoogs12 (06-01-2012), TiGraySpeed6 (06-01-2012)
 Old 06-01-2012, 03:10 AM   #38
smoogs12's Avatar
Groans: 423
@broncojd78 did you ever do another leak down test? Or are you saving that for once you are done with cables and seals?
Sent from my iPhone using Fapatalk.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following User Says Thank You to smoogs12 For This Useful Post:
jack_hammer (06-01-2012)
 Old 06-01-2012, 03:56 AM   #39
rfinkle2's Avatar
Groans: 298
I believe most guys use a combo of injector seal threads, but this is thanks to dougefresh_:
How To CPE Injector Seals + Studs + EGR Delete
Also, google "nicked" injector seal and you should come up with what seems to be a common thing to look out for when re-installing.
ak_spray (06-12-2012), Boost_creep (06-01-2012), jack_hammer (06-01-2012)
 Old 06-01-2012, 04:51 AM   #40
Groans: 549
No i did not retest. either this fixes it, or not. And then we go from there.
I read that thread before. I'm talking about removal of the fuel rail. When i pull, nothing happens. It does not want to budge. I don't think I'm holding my nose right. That's what I was asking about. or are there bolts that hidden?
I was thinking i might try removing the crows feet and trying to take our the rail and injectors at one time. Then i could just remove the injectors from the rail. Voila, injector removal tool. Haha
Leaky headlight MS3kid08 Mazdaspeed3/6 General Discussion 9 09-25-2018 10:47 AM
leaky, leaky wette460 MazdaSpeed 3/6 - Turbo Induction 16 09-09-2011 03:12 PM
Is my leaky DP the cause of this? Fatguy729 MazdaSpeed 3 - Engine, Transmission & Driveline 3 07-27-2011 08:02 AM
Leaky stock bpv LiEast MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 10-20-2009 04:25 PM
Page generated in 0.62002 seconds with 30 queries
