  • 1 Post By Djohns
 Old 09-13-2017, 05:13 PM   #1
Snyderg999's Avatar
Posts: 7   (View Stats)
Snyderg999 is an unknown quantity at this point
Default Many Problems
Hello, i am new here and haven't ever posted but I also couldn't find a thread related to ALLL of the problems i am having presently. Currently my fog lights are not working, my Abs and TSC lights are constantly on, and the push butten start doesnt turn the car off like it should, it goes straight to ACC. Mode and i have to overide it. I have taken my vehicle to the dealership yesterday and they said that my rear shocks are bad and need replaced but otherwise couldn't figure out why the push button was acting like it was or why the abs and tsc was on. I am going back in about a week to have my shocks replaced and will ask again to have the abs scanned because i dont beleive they did so the first time but evem then i do not understand why the pish button or fog lights are acting up also. I also have checked all of the fuses and relays with no luck of finding an issue and i also cleaned all of the wheel speed sensors/abs sensors but also do mot know where to find any grounding wires to check them. If anyone has any ideas to check before i take it back, it would be much appriciated.
Snyderg999 is offline   Reply With Quote
 Old 09-13-2017, 05:20 PM   #2
Djohns's Avatar
Posts: 3,883   (View Stats)
Groans: 105
Sounds to me like you may have a short somewhere. Did it randomly start doing this?
Oli likes this.
2010 black mica speed3
Soon:built motor
 Old 09-13-2017, 05:25 PM   #3
Snyderg999's Avatar
Yes, a couple months ago driving through the city. I do mot recal hitting any bumps or anything to ajar a semsor or amything of the sort when it happened thoough. Yet since then it has been a constant thing. I have also tried disconnecting the battery a handful of time to reset the sensors but to no avail.
 Old 09-13-2017, 08:35 PM   #4
Djohns's Avatar
Groans: 105
Paint a picture for me. It may help figure it out. Was it raining? Cold or hot day? In traffic? Was the car hot?
Soon:built motor
 Old 09-14-2017, 02:11 AM   #5
Snyderg999's Avatar
Around 70 degrees i would say, partly cloudy, not too much traffic, andthere was a slight breeze. I do not recall how het the car was though but i cant imagine it being too bad for the weather around it.
 Old 09-14-2017, 07:33 AM   #6
Djohns's Avatar
Groans: 105
Hm. Strange, it's not harsh conditions. I definitely still think you have a short somewhere that needs to be fixed.
Soon:built motor
 Old 09-14-2017, 03:50 PM   #7
Snyderg999's Avatar
Wpuld you happen to know where the grounding wires are located so i could check? Im unable to find anything about them anywhere
 Old 09-14-2017, 03:51 PM   #8
Djohns's Avatar
Groans: 105
I'll have to look when I'm out of class. There's a wiring diagram on here somewhere.
Soon:built motor
 Old 09-14-2017, 04:55 PM   #9
Snyderg999's Avatar
Thank you, anything at this point is appariciated.
 Old 09-28-2017, 01:25 PM   #10
Djohns's Avatar
Groans: 105
Did you ever get this figured out? I can't seem to find the wiring diagram on the forum, I'll have to check my computer when I get time.
Soon:built motor
 Old 09-28-2017, 04:19 PM   #11
Snyderg999's Avatar
Actually just yesterday i had figured everything out. I had taken it to the dealership a total of 4 times. 1st they gave me b.s. that my bad shocks were causing the abs light. When i went back after posting on this forum i asked for them to read the abs light because they didnt the first time and to check all of the grounds for shorts. Then i bought a service/repair manual which confirmed it was eitger short or one of tge sensors. When i picked it back up they told me my right rear abs sensor wasnt reading and that all of the wires were fine, didnt beleive them but i went to change it out myself and i found that the ground wire going into the conection that plugs into the sensor was completely torn out and was unrepairable. I took it back in a third time to see what they could do and just confirmed that they must have not checked all of the wires and couldnt find a connector. I ended up having to buy one to replace it and took it back in so they could handle it. After the repair the lighta had gone away tland the ignition is completely fine. Only thing wrong now is that my fog lights are not working still, but im starting with replacing my relay to see if it had just gone bad.
 Old 09-28-2017, 06:24 PM   #12
5doorsoffury's Avatar
Posts: 941   (View Stats)
Groans: 72
Groaned at 7 Times in 6 Posts
Sounds like that shop dosent know there thumb from there ass hole.
MECP
2012 BM
Rfinkle tune in progress
 Old 09-28-2017, 06:39 PM   #13
Snyderg999's Avatar
No Kidding. Scary part is that was an actual mazda dealership service department dping all of the work.
Official: Fisker Q&A sheds light, lots of light, on Karma problems, lots of Karma problems Haltech Automotive News 0 08-23-2012 01:50 PM
AC problems~! LiEast MazdaSpeed 3 - Engine, Transmission & Driveline 0 06-09-2011 03:37 PM
AC problems help! LiEast MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 05-24-2011 06:55 PM
will these fit my car with no problems?? 18psiWhiteMS3 MazdaSpeed 3/6 - Wheels & Tires 5 06-11-2009 04:09 PM
Page generated in 0.31674 seconds with 22 queries
