 Old 10-10-2015, 12:01 PM   #1
Mazdaspeedmike07's Avatar
Posts: 11   (View Stats)
Mazdaspeedmike07 will become famous soon enoughMazdaspeedmike07 will become famous soon enough
Default mazdaspeed 6 crank no start
ok yes ive read my ass off and even retimed the motor also. lets start with when i bought the car. bought it as a crank no start car because it was super cheap. thought i could fix it pretty easy. the dealer took it to mazda and they said it needed a crank sensor because the ecm wasnt seeing a crank siganl. so the dealer had someone put a new crank sensor on it and still wouldnt start. i figured it wasnt installed correctly and thats why it wouldnt start. so i locked the crank in place with the engine pinning tool and it looks like someone had been in the motor before because the 20th tooth was about 4 teeth off from where the sensor was. so i locked the cams in place with the service tool and locked the crank and took the crank bolt off and moved the crank pulley in position. still no start it only sparks maybe one time and then it doesnt spark anymore it just cranks and dumps fuel into the motor. only thing i havent tried is replacing the cam sensor. would this cause a no spark situation? all cylinders have compression and both in tank pumps are working putting 65psi with the key on. my scanner is also seeing an rpm signal. im a diesel tech so these mzr motors are a little new to me and ive been reading on the common failure points of these motors. any help would be appreciated thanks.
Mazdaspeedmike07 is offline   Reply With Quote
 Old 10-10-2015, 12:15 PM   #2
frothy's Avatar
Posts: 1,067   (View Stats)
Did you pull the timing cover and replace the friction washers and crankshaft bolt when you retimed the engine?
 Old 10-10-2015, 12:27 PM   #3
yes i did. so my next question when im cranking the engine what should my fuel pressure be? ive read somewhere around 1000 psi but my scanner only says 75psi then when i crank it the pressure jumps around going down to almost zero. i also figured out the fuel pump on the right side in the tank is not working. could the pcm see the drop in fuel pressure and cause the motor not to start? it almost starts but seems like now that it doesnt have enough fuel
 Old 10-10-2015, 12:43 PM   #4
frothy's Avatar
If you haven't already, check the connection in the picture below, to your starter.
That sucker is notorious for developing corrosion and creating startup problems.
 Old 10-10-2015, 12:59 PM   #5
well the starter is brand new and thats one of the things i checked earlier. it cranks over good and fast also and almost sounds like its going to start but like is running out of fuel
The Following User Says Thank You to Mazdaspeedmike07 For This Useful Post:
frothy (10-10-2015)
 Old 10-10-2015, 09:21 PM   #6
mxlplx71's Avatar
Posts: 3,265   (View Stats)
Groans: 128
Take the back seat bottom out and listen for the intank pump.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 10-11-2015, 09:48 AM   #7
well for some reason i thought there was2 pumps in the tank but i think theres only one in which case the pump works. the only thing i havent changed is the cam sensor. do you think that could be the problem
Hard Start, Long Crank, Rough Idle red ghost MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 10-07-2014 10:24 PM
Long Crank at cold start maikell77 2010 MS3 - Troubleshoot/Diagnostics 4 03-13-2013 07:54 PM
Page generated in 0.27069 seconds with 22 queries
