 Old 06-09-2018, 12:26 AM   #1
bkxtrakrisspy's Avatar
Posts: 6   (View Stats)
bkxtrakrisspy is an unknown quantity at this point
Default MS6 replacement ac compressor issue
Short story, had a leak in the system. High pressure line was replaced and not 20 minutes after picking the car up the AC compressor gives it up. (This was like 2 weeks ago) Drop it off at another shop that my buddy owns, they replaced the entire ac compressor, drove it another 15 minutes, parked the car and i don't start it up again for 4-5 hours. Come back and ac is hot again, compressor doesn't kick on nor do the fans turn on. I swapped a relay and checked fuses but they all seem ok. Of course there is no pressure in the lines because nothing is kicking on. Ideas????
I've searched but I can't find anything like this, even tho I'm sure it's happened before.
bkxtrakrisspy is offline   Reply With Quote
 Old 06-09-2018, 07:09 AM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
have you had they system pressure tested again?
 Old 06-11-2018, 06:22 PM   #3
Update
So took it to the shop this morning and it was a bad O-Ring on one of the hoses leading to the compressor. Replaced, recharged and good to go!
HOW-TO: MS6 A/C Compressor Clutch & Bearing Replacement GroceryGtr MazdaSpeed 6 - How-To's 14 10-11-2018 10:26 AM
Yet another A/C compressor issue Inzane81 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 08-03-2016 02:25 PM
AC Compressor Replacement robander3 Mazdaspeed3/6 General Discussion 24 10-23-2014 02:46 PM
2008 mazdaspeed 3 AC compressor replacement notoriousdoa MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-06-2012 04:38 PM
Lucked out with A/C compressor replacement! btstarcher Mazdaspeed3/6 General Discussion 4 06-20-2012 09:26 PM
Page generated in 0.23980 seconds with 21 queries
