Like Tree2Likes
  • 1 Post By superskaterxes
  • 1 Post By AtTheDriveIn
 Old 08-24-2012, 07:11 AM   #1
Rokusek's Avatar
Posts: 5,551   (View Stats)
Default MS6 Transmission issues... NEED HELP!
Hey guys, a local member has some issues right now with his transmission. He doesnt know a lot about cars so im trying to help and get as much info as i possibly can before we get to much farther into it.
so heres the issue...
A week ago cruising down the highway mildly getting on it, he goes to shift from 4th to 5th, comes out of 4th just fine then as hes going into 5th the stick stops as if 5th doesnt exist. he slows down presses the clutch in and nothing. wont go into any gear period!
We pull over car still running, tries to put it in all gears and nothing. the clutch has little to no resistance but springs back when you let off. at the top end of the peddle from 0-1.5 maybe 2 inches in the clutch has mild vibes.
So we turn the car off, resistance comes back to the clutch and the transmission goes into each gear with ease. no issues WTF!!!!
we bled the clutch slave cylinder, no juice. tried to put the car in gear by hand and the trans with car running to see if it was the cables, no juice.
so we tow the car back to my house to trouble shoot then next morning. disconnected the ECU did a hard reset and let the car sit over night.
next morning still nothing. he talked to a master tech at mazda that said it could be the master or slave cylinder but because the clutch sprung back after releasing with the car on it cant be the cylinders.
Other possibilities, we think maybe a bent clutch fork, the throw out bearing slipped off the fork, or the clutch is fucked (worse case senerio).
right now im at the point to where we are gonna have to pull the transmission out but do not have a place to do it at this moment in time. luckily he doesnt need his car right now because he lives and works on base. but we are in a time crunch because he is leaving for Germany in November.
thats all i can think of that we have done and the possibilities of what could be the problem.
Thanks for your help.
@djuosnteisn @superskaterxes @chimmike @robry @Downmented @Captain KR @06Speed6 @SpeedSixx @Raider @Daddy Chinkus @phate @Dano @NJSPEED3 @SPEED6 KILLAH @AtTheDriveIn @FORZDA 1 @RhoadBlock @ms6ms6
please tag anyone else that may have a clue here. for these are all the names i can think of right now.
Thanks again for your help
Paul
aka "Roku"
Monotonous ONE (08-25-2012)
 Old 08-24-2012, 07:22 AM   #2
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
bent clutch fork
The Following 3 Users Say Thank You to Raider For This Useful Post:
Darksun280 (08-24-2012), Downmented (08-24-2012), NJSPEED3 (08-24-2012)
 Old 08-24-2012, 07:35 AM   #3
chuckms6's Avatar
Posts: 1,618   (View Stats)
bent clutch fork
this or friction material broke off the clutch and is wedged in there. just had that issue on a bmw
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
 Old 08-24-2012, 08:13 AM   #4
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
clutch fork is toast
Carry on citizens....
Pump Gas Champ 10.9 @ 128
10.7 @ 133 auto 1G DSM
2013 C6 GS (Retirement vehicle)
TwitchTV: CooperSheepsTTV
 Old 08-24-2012, 08:21 AM   #5
Rokusek's Avatar
Clutch fork huh... Guess i better start looking for a HOW-To, @Raider do you know if there is one? if not i guess i can make one if this is the case.
 Old 08-24-2012, 08:47 AM   #6
at the very least you can pull the boot off the fork and look inside there with a flash light.
Rokusek likes this.
 Old 08-24-2012, 08:57 AM   #7
Rokusek's Avatar
I knew there was more than one reason i loved you
@Raider i spoke to soon on the how-to, knowing damn well i obviosly didnt search hard enough for it. but i didnt find one however i did find @MATT DAMOND 's How-To Clutch swap, so gonna read a little more hopefully tomorrow i will dig more into it.
Ill post pics of what we see through the boot!
 Old 08-24-2012, 09:29 AM   #8
chuckms6's Avatar
this is why im saying the clutch disc is bad
 Old 08-24-2012, 09:32 AM   #9
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
AtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the world
Sucks to hear what happened. Let us know when you're going to work on it. l'll give a hand. I have no clue so this could be so this can be learning experience.
Rokusek likes this.
AtTheDriveIn is offline   Reply With Quote
 Old 08-24-2012, 10:42 AM   #10
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Seems like you guys got everything under control here. Moving along, best of luck.
700HP CLUB
11.479@124mph
#DIX
The Following User Says Thank You to Downmented For This Useful Post:
Rokusek (08-24-2012)
 Old 08-24-2012, 12:28 PM   #11
Speeeeeed
06Speed6's Avatar
Posts: 6,519   (View Stats)
+3 clutch fork. Its definitely not a trans problem so that is your hood news.
2006 Mazdaspeed 6
 Old 08-24-2012, 01:48 PM   #12
chuckms6's Avatar
Originally Posted by 06Speed6 View Post
...so that is your hood news.
lol
The Following 2 Users Say Thank You to chuckms6 For This Useful Post:
06Speed6 (08-24-2012), radioflyer (08-24-2012)
 Old 08-24-2012, 01:51 PM   #13
Rokusek's Avatar
Ok so the guy who owns the car was supposed to comment on this earlier but he didn't
Tristan! Fucker @89T
He card me today while I was at work and said the peddle started to take longer to retract. He said it would stick for a monent the slowy come up a little then once it was moving it popped up. so there is some lag in the peddle itself. He found a new master/slave cylinder for around $50. He's gonna pick those up in the morning then we will swap those out and hope that fixes it. Keep you guys posted will also inspect the clutch fork via through the boot thanks @superskaterxes
 Old 08-24-2012, 03:14 PM   #14
89T
89T's Avatar
Posts: 599   (View Stats)
89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world
Hey my bad haha i was calling around and looking up parts and shit then it was time for school but yea its my 6 thats throwing a hissy fit haha
2007 Mazdaspeed 6 Black
Total # laps on Nürburgring: 3 Total # Crashes on the ring : 1 Fastest Lap on the ring 11:16
Pulling motor and transmission to build!
2002 VW Golf GTI 337
Daily
CAI/Franken Turbo F21/2.0 Coil Pack conversation /550cc injectors/Black Forrest SMIC/High flow Downpipe with muffle/resonator delete
2002 VW Golf GTI blue
Wife's Car
Custom SRI/Rear Muffler Delete/Blisten Heavy duty shocks and springs/Motegi Racing Wheels
89T is offline   Reply With Quote
 Old 08-24-2012, 03:31 PM   #15
89T
89T's Avatar
Oh also forgot this part this is the 3rd time this has happend to first 2 times the car fixed its self
Daily
Wife's Car
 Old 08-24-2012, 03:45 PM   #16
Speeeeeed
06Speed6's Avatar
If it comes up super slow it may be a master/slave issue. Check your fluid level first.
2006 Mazdaspeed 6
 Old 08-24-2012, 03:49 PM   #17
Rokusek's Avatar
fluid level was golden even after a simple bleed of the system, we will find out tomorrow for sure once we swap them out.
 Old 08-25-2012, 03:19 PM   #18
Rokusek's Avatar
well the bad news... it wasnt either of the cylinders... pulled the boot off the clutch fork and chunks of the disk fell out... so new clutch here we come...
thanks guys for all your help
chuckms6 (08-25-2012)
 Old 08-25-2012, 10:24 PM   #19
memin's Avatar
Posts: 990   (View Stats)
Damn sorry to hear that, how many miles on the clutch?
 Old 08-25-2012, 11:23 PM   #20
Rokusek's Avatar
76k
 Old 08-26-2012, 12:44 AM   #21
Matx's Avatar
Posts: 1,681   (View Stats)
Lol at least it made it to VA Tristan cant ask more than that.
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
The Following 2 Users Say Thank You to Matx For This Useful Post:
89T (08-26-2012), Rokusek (08-26-2012)
 Old 08-26-2012, 05:52 PM   #22
89T
89T's Avatar
Yea i went from TX to CO then here to VA then she gave up on life and shattered
I got very lucky on the borrowed time that was given to me.
Daily
Wife's Car
Transmission issues dodd9966 MSP - Engine, Transmission & Driveline 0 03-24-2012 12:15 AM
Report: Ford Mustang under investigation for transmission issues Haltech Automotive News 0 08-08-2011 08:50 AM
transmission issues? speed3po MazdaSpeed 6 - Engine, Transmission & Driveline 4 12-11-2009 09:09 PM
İCopyright 2008 ; 2014 Cymru Internet Services LLC | FYHN™ Autosports HQ
Page generated in 0.42003 seconds with 30 queries
