 Old 03-15-2019, 10:45 PM   #1
Speed-6's Avatar
Posts: 2   (View Stats)
Speed-6 is an unknown quantity at this point
Default Mazdaspeed 6 Won't Crank/Start
Hello so i have read just about every thread on google of what it could be and i just can't figure it out.
2006 MS6 ignition turns everything (radio, lights, Climate blower, etc) works but car will not crank over. i have tried both key-less and spare key to turn it over, battery is good also have a jump box connected. i can hear the relay click but nothing happens. so i tried adjusting the white connector signal wire on the starter motor that seems to be a common culprit and nothing, so i figured i would test it and found there is no signal at all coming from that wire with the key turned to start, but if i run a jumper wire from the signal terminal on the starter to the positive terminal on the battery the motor cranks instantly and spark it confirmed from the coils. any ideas why the signal wire isn't sending signal?
2006 MazdaSpeed 6
Speed-6 is offline   Reply With Quote
Ms6 won't start no crank Kevopg MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 12-10-2016 04:58 PM
No crank, No start 570msp MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 10-23-2015 01:03 PM
Crank But No Start Pagan47 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 10-21-2015 07:32 PM
mazdaspeed 6 crank no start Mazdaspeedmike07 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 10-11-2015 09:48 AM
Page generated in 0.23341 seconds with 20 queries
