 Old 11-23-2016, 05:39 PM   #1
Kevopg's Avatar
Posts: 120   (View Stats)
Kevopg is a name known to allKevopg is a name known to allKevopg is a name known to allKevopg is a name known to allKevopg is a name known to allKevopg is a name known to all
Default Ms6 won't start no crank
Car won't start I just replaced my oil cooler gasket got everything back together let the car warm up to temp and then it started bogging out and then died. No crank and can't read codes access port says not connected. Tried different battery but no go, any ideas??
Kevopg is offline   Reply With Quote
 Old 11-24-2016, 12:20 AM   #2
Qual1ty's Avatar
Posts: 56   (View Stats)
Qual1ty will become famous soon enough
Groaned at 5 Times in 2 Posts
Turn key and all lights come on as usual just no crank? Have you rechecked all connectors? Check engine light on? See if you can get the codes read.
Its not just a love for mazda, or things awd turbo, but a love for all things automotive. Build it right, respect.
Qual1ty is offline   Reply With Quote
 Old 11-24-2016, 06:21 AM   #3
Dropen's Avatar
Posts: 38   (View Stats)
Dropen will become famous soon enough
Did you check fuses?
Maybe you short circuit something w/o fuse and you mess up the battery.
Dropen is offline   Reply With Quote
 Old 11-24-2016, 02:29 PM   #4
Kevopg's Avatar
Not battery or fuses.
 Old 11-24-2016, 08:41 PM   #5
Varomnia's Avatar
Posts: 441   (View Stats)
Varomnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the world
Can you video you attempting to crank it? Could be like 20 things. Spark plugs being possibly the cheapest, but need to see it for a better guess.
ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar
Varomnia is offline   Reply With Quote
 Old 11-25-2016, 01:39 AM   #6
jm211's Avatar
Posts: 943   (View Stats)
jm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the world
Groans: 52
I assume the car would start prior to replacing the oil cooler gasket. I would recommend starting with anything you touched when replacing that gasket.
Black Mica 2006 Speed6 GT | 62,000 Miles
Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1
ms6db.com I'm Registered. Are You?
jm211 is offline   Reply With Quote
 Old 11-27-2016, 07:17 PM   #7
cjbevington's Avatar
Posts: 27   (View Stats)
cjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to beholdcjbevington is a splendid one to behold
What connections did you have to break from the harness? I know the throttle body connector is relatively close to that area. If that's not connected, you could have problems. How long did it run before it shut off?
cjbevington is offline   Reply With Quote
 Old 11-27-2016, 07:20 PM   #8
Kevopg's Avatar
About 5 min just got up to temp.
 Old 11-27-2016, 07:27 PM   #9
What about the instrument cluster? Is it functioning properly? Trying to get an idea if it is just not starting or if the whole car is dead.
 Old 11-28-2016, 09:12 AM   #10
Kevopg's Avatar
Will take video when I get home. Cluster seemed the same, it clicks under the dash when turning the key.
What would cause the ap to not connect?
 Old 11-30-2016, 05:32 PM   #11
Kevopg's Avatar
Replaced all fuses with new and the car started for 5-10 secs. Sounded like crap now the same prob again. Only one fuse is blowing ENG IN. Looking into it.
 Old 11-30-2016, 06:17 PM   #12
This might be a dumb suggestion, and it may only be for the earlier gen Cobb AP's. Anywho, I know that my connector to the AP can actually be installed backwards...it will fit just fine but you won't have any power, which would produce your issue. I scratched my head for awhile and felt really dumb, but I never did it again!
Also, I did a quick look and saw an ENG INJ fuse in the main fuse panel - is that the one your referring to? If you're having trouble getting power to the injectors that could definitely give you the issues you're describing.
Last edited by cjbevington; 11-30-2016 at 06:17 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-30-2016, 06:37 PM   #13
Kevopg's Avatar
Its the ENG IG 15amp fuse. I've also had problems with the fan coming on every time the key was in the on position. I might have found the problem just need some more fuses before i can try.
 Old 12-01-2016, 09:31 AM   #14
Kevopg's Avatar
Got new fuses in again and put the key in the on position and one of my coil packs started smoking bad. I'm sure that pack is fried so need new one, no clue on what the issue is.
 Old 12-10-2016, 05:58 PM   #15
Kevopg's Avatar
Fixed. Replaced coil pack, disconnect all connectors from fan to harness and reconnected.
The Following User Says Thank You to Kevopg For This Useful Post:
RX-187 (12-28-2016)
No crank, No start 570msp MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 10-23-2015 02:03 PM
Crank But No Start Pagan47 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 10-21-2015 08:32 PM
mazdaspeed 6 crank no start Mazdaspeedmike07 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 10-11-2015 10:48 AM
Hard Start, Long Crank, Rough Idle red ghost MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 10-07-2014 11:24 PM
Long Crank at cold start maikell77 2010 MS3 - Troubleshoot/Diagnostics 4 03-13-2013 08:54 PM
Page generated in 0.33940 seconds with 25 queries
