MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() | ![]() | #1 | ![]() |
![]() Join Date: Mar 2019 Location: Germany
Rep Power: 11 ![]() ![]() Thanks: 4
(Thread Starter) | ![]() ![]() ![]() The car is Misfiring or Sputtering on cold starts, which seems to cure mostly after the cold start procedure. After that i get couple small backfires on idle, on a stop or redlight. Definately on Cold Start the worst. The car is lightly modded and got a pro Tune with the Accesport on it. No Engine Codes are shown, sadly. Mods are shown in my signature. Already changed following parts: -injectors cleaned with Upgrade gaskets -All Spark Plugs (SILTR-6A7G) and Coils (also NGK) -Intake Manifold and Throttle Body gasket PTFE -Exhaust Manifold Gasket, and both Gaskets on Turbocharger -Coolant Temperature Sensor -PCV Valve Vaccuum seems perfect, fuel pressure also and there seems no Oil in the breather hoses, like if there are broken ringlands. Tested the Compression on cold engine which is 130-140 psi across the cylinders. Cylinder 2 doesnt react as much as the others, when ich pull the Plug on the Coil unforunately so it seems to run on 3 cylinders only. Surprisingly it drives without feeling an issue. I found lots of similar Threads over the last year till now but no real answer or solution for this problem. For reference i would take a thread from a member here, which also made a couple videos. Puff of blue smoke and engine stutters Furthermore i attach an cold and warm starting logfile. Hopefully you guys can help an hopeless guy from germany. greets
__________________ HM-Upgrade K04 Turbocharger, 3" Corksport Catted DP, 3" FMS Catback Exhaust, HG-Motorsport HPFP Internals, Upgraded TMIC, Silicone Turbo Inlet Pipe+Neck, Silicone Intercooler Hose, Simota Podfilter, GFB Mach 2 BPV, Primary EGR Delete Kozmic, PTFE Intake and Throttle Gasket, Throttle Coolant Delete, Cobb Accessport V3 Last edited by ghost-rider; 07-28-2019 at 02:08 PM. |
![]() | ![]() | #2 | ![]() |
![]() Join Date: May 2012 Location: Greensboro NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 751
| ![]() ![]() ![]() did you check for boost leaks? is your VTCS deleted? not having that in your car will cause random misfires on cold starts for sure.
__________________ ![]() 06 VRM Speed 6 W/Navi 05 Mazda Family Truckster FREEKTUNED\\Cobb AP\\Autotech Internals\\Eibach Pro Springs\\Sure SRI+TIP\\Street Unit TP\\CPE RMM\AWR 88 Duro TMM\\Forge V1\\JBR Shortcut\\JBR SSB\\CPE & Sure Rear Diff Mounts\\Unicorn Blood (Rotella T6) twitter.com/djern instagram.com/djern facebook.com/djern |
![]() | ![]() | #3 | ![]() |
(Thread Starter) | ![]() ![]() ![]() yeah i disassembled and assembled everything and put silicone hoses with t-bolt clamps to be sure. It not VTCS deleted, i checked the grommet unter the Vaccuum chamber and the hoses are good too. Flappers move easily by hand. I dont see a leak in the STFT too
__________________ HM-Upgrade K04 Turbocharger, 3" Corksport Catted DP, 3" FMS Catback Exhaust, HG-Motorsport HPFP Internals, Upgraded TMIC, Silicone Turbo Inlet Pipe+Neck, Silicone Intercooler Hose, Simota Podfilter, GFB Mach 2 BPV, Primary EGR Delete Kozmic, PTFE Intake and Throttle Gasket, Throttle Coolant Delete, Cobb Accessport V3 |
Display Modes | |
Misfire. Hard start. Jumpy idle. P0300 | Fitbkeco | MazdaSpeed 3 - Engine, Transmission & Driveline | 39 | 08-30-2018 02:45 PM |
Stalling at cold start, p2187, high fuel trims, hesitation/sputter | Badger_ | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 01-13-2018 02:10 PM |
Getting misfire code on cold start | TWOptSL0W | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 21 | 05-12-2015 06:52 AM |
what's your idle on cold start? | drag0nfire | Mazdaspeed3/6 General Discussion | 15 | 04-15-2012 02:41 PM |
Misfire on Cold Start | superskaterxes | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 14 | 07-03-2011 09:30 PM |
