 Old 09-10-2011, 10:52 AM   #1
chris29mil's Avatar
Posts: 108   (View Stats)
chris29mil is a glorious beacon of lightchris29mil is a glorious beacon of lightchris29mil is a glorious beacon of lightchris29mil is a glorious beacon of lightchris29mil is a glorious beacon of light
Groaned at 44 Times in 22 Posts
Default Need Help Diagnosing this Noise on Startup!
Ok, car has been making a metallic noise similiar to loose change on startup recently. I did some research on the forum and decided its most likely the vvt actuator. since car is still under warranty, i took it to the dealer. They confirmed my suspicions and said it was the vvt actuator, or so I thought. after changing both the actuator, the timing chain and timing chain tensioner, its still making the noise on startup!!!! I am completely lost now, the noise is still there but it does seem like the pitch has changed slighly. I recorded a video and it does seem to come from the HPFP area. I have a CP-e pump and i have had it for about 5k miles or so. I logged some pressures and my pressures are still very strong. can anyone help me with this?
Note that the noise is only there for a short time, then it goes away and i wont hear it again until the car has sat for at least 6 hours or so to completely cool down.
2008.5 BLACK MS3, COBB SRI and AP,Turbosmart BPV, SU test pipe and full MM set, AWR sway bar endlinks F/R, TurbineTech Front MM, CPE HPFP, JBARONE SSP and Heavy Shift Knob, H&R Springs and 15MM spacers, SPC Rear Camber Arms, PERM TUNED by Sean, TurboXS DP, GRIMMSPEED 3Port EBCS,Corksport TIP, ETS TMIC, Corksport Boost Tubes, DENSO ITV22's, Black EMBLEMS/DEBADGE.accepting donations!
chris29mil is offline   Reply With Quote
 Old 09-10-2011, 01:36 PM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,157   (View Stats)
Groans: 792
Vvt is a loud tick tick tick tick on startup as the pin misses the it's seat a few times.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 09-11-2011, 08:16 AM   #3
asall667's Avatar
Posts: 1,017   (View Stats)
asall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the world
Groans: 56
Groaned at 37 Times in 18 Posts
yea i could have tod you thats not VVT as I had the VVT failure and had it fixed under warranty. take it back in to the dealer what are you waiting for? Idk about the FP internals, I would go back to stock and see if the sound goes away. If it does, u found ur issue, if not...dealer is ur best friend!!
2007 CBM MS3 GT 66K
Mods:
--Cobb SF SRI--Corksport TIP-- Speed Daddy FMIC Piping w/ TR8 Core--CPE 75A RMM--Test Pipe--Both res delete--TWM Short Shifter--Custom Fabric wrapped A pillars & Side Pillars--Gunmetal PC Genpu Wheels--Mazdaspeed Red Calipers (front & rear)--Laminx Fog Overlays--Foglight Mod--3M Gloss Black Roof--Custom Mudflaps--Evil Flying M--CPE Triple Gauge Pod--Propsort Boost-Oil Temp-Oil Pressure Gauges--Prosport Sammich Plate--SU Oil Spin On Conversion--Magnetic Drain Plug--Raceland Coilovers--SPC Rear Camber Arms--15MM H&R Spacers--Hawk HPS pads--Turbosmart Plumb Back BPV----
New VVT as of 50K miles Thanks Young Mazda
New K04 Turbo as of 57K miles Thanks Young Mazda
asall667 is offline   Reply With Quote
 Old 09-12-2011, 12:55 PM   #4
chris29mil's Avatar
I have had my car at the dealer twice and they have yet to figure it out. each time they have had it for almost a week and cannot seem to figure it out. I would go back stock for fuel pump but I bought a complete pump and had to return my old one for a core. Im to the point that Im just going to wait until whatever is making that noise fails and then it will be easier to track down the problem or sell it, which ever comes first.
Startup issue -- need help! easaly MazdaSpeed 3/6 - ECU Computer Tuning 9 04-10-2011 06:40 PM
Need help diagnosing something bad with axle. dsmluck MazdaSpeed 3/6 - Suspension & Brakes 6 07-31-2010 09:54 AM
Need help diagnosing weird coolant temp readings Addikted To Boost MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-09-2009 09:17 PM
Lotus and Harman partner on noise-cancelling, noise-creating tech Haltech Automotive News 0 04-16-2009 05:00 PM
Page generated in 0.26472 seconds with 22 queries
