 Old 01-20-2011, 06:25 AM   #1
meicalnissyen's Avatar
Posts: 1,151   (View Stats)
meicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the world
Default Need a more reliable 12v source
So I have need for drawing a few amps while the car is running, and I found a great fuse to tap, (in the fuse box underhood, row closest to bumper, second one in from fender)
comes on with keystart, stays on 10 sec after shutdown. Been using it for a year
except it will randomly energize the circuit when no one is near the car! I've heard of this type of problem with foglight mods as well
I've caught it on rare occasions in the past, but I upgraded the fan recently and it now pops on more often, to the point where I physically disconnect at night.
Its gonna leave me stranded someday with a dead battery
can any one reccomend a cure, or alternate source ?
I really want to avoid a separate switch
A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch
meicalnissyen is offline   Reply With Quote
 Old 01-20-2011, 06:36 AM   #2
SSinstaller's Avatar
Posts: 3,827   (View Stats)
Groans: 51
Use a relay off the battery. Trigger it with the Cig lighter circuit.
Soon to be installed:
ST manifold w/ port injection : Raduim Engineering PCV Plate : Radium Engineering PCV valve : Radium Engineering Fuel filter : Aeromotive FPR : DCR VVT : TI Automotive F90000262 Fuel Pump : NX 15718 : Split Second AIC
laxplayermjd (03-08-2011)
 Old 01-20-2011, 07:57 AM   #3
So you mean, I take it, to wire a separate high current relay to my fan, and tap the switched side of the cig circuit to the trigger terminal of the new relay ?
 Old 01-20-2011, 09:43 PM   #4
2zz mr-s
dooderek's Avatar
Posts: 5,114   (View Stats)
Groans: 239
Tap off ignition, btw can I ask what for?
 Old 03-03-2011, 03:45 PM   #5
Default 12v
hmm where do you mean by ignition? lottsa ign fuses there
its for the water pump and fan for the intercooler
Currently, I have added the relay, and am back to tapping the fuse I have been using for a year, with the relay I thought I had it beat, but after a couple weeksI caught it kickin on again. just twice in a month, random, like before but still has the potential to do it
 Old 03-03-2011, 08:38 PM   #6
2zz mr-s
dooderek's Avatar
Groans: 239
Tap into the ignition wires, grab a multi and test for your 12v, if your a 07 speed 6 I got a diagram somewhere I can post. As to your current problem, I unno, probaly some ectoplasmic ghost shit. But I'm tapping all my gauge power from ign (clump of wires you unplug from the steering colonum)
The Following User Says Thank You to dooderek For This Useful Post:
meicalnissyen (03-08-2011)
 Old 03-08-2011, 11:56 AM   #7
Right, I liked the part of the fuse I am using where it stays on for 10 sec after shutdown, but I'll take anything that stays off at this point
I have a speed three, GT 07
some of the fog light mods had similar ghostie troubles
 Old 03-08-2011, 02:08 PM   #8
2zz mr-s
dooderek's Avatar
Groans: 239
well with the proper relay you can have it do that running from a 12v but ya so much nicer to have it readily avaible from a fuse lol
Best/Reliable Way To Get Negitive Camber RacerX78 MazdaSpeed 3/6 - Suspension & Brakes 59 04-06-2011 08:44 AM
Reliable mods Speeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 28 01-26-2011 07:26 PM
reliable manifold? k0m MazdaSpeed 3/6 - Turbo Induction 2 04-06-2010 09:27 PM
Reliable shop in NoVA/DC/MD vbt101 MazdaSpeed 3 - Engine, Transmission & Driveline 0 03-22-2010 11:02 PM
Page generated in 0.28193 seconds with 22 queries
