  • 1 Post By blackms3_71
 Old 10-21-2015, 09:33 PM   #1
570msp's Avatar
Posts: 102   (View Stats)
570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold
Default No crank, No start
Long story short, My dip stick housing came loose and was spitting oil out from under the car. I loosened the mounting bolt that on the Intake Manifold and shoved the housing back into the oil pan. Put everything back together, and now the car won't start. No crank, no firing. Headlights turn on, don't dim. Dash lights turn on don't dim (all while turning the key) The starter just isn't firing. I checked all the plugs near where I was working on the IM and they are all plugged in snug. Fuses seem OK but didn't get to pull every single one. The car will start and run if pushed started.
AT this point after an hour in the cold I'm frustrated and can't focus on diagnosing it. I figured I'd give it tonight and sleep on it, collect some info and tackle it tomorrow.
Any advice would be greatly appreciated.
Edit: also want to point out that my AP shows no codes
2006 Mazdaspeed 6 rebuilt with v6 rear end
CPE TMIC || Cobb SRI + TIP || Grimmspeed 3 port EBCS || Forge BPV V1 || UR Test Pipe || CPE Single Exit Exhaust || JBR heavy shift knob and shifter bushings || JBR RMM || SU short throw || Corksport Stubby antenna || Glowshift boost and voltage gauges || CS Mudflaps
570msp is offline   Reply With Quote
 Old 10-22-2015, 05:36 PM   #2
570msp's Avatar
So I got it started and it's all peachy now. Last night I wasn't thinking logically becasue I was so mad but I went right for the starter tonight. Unplugged it, cleaned it, and plugged it back in and worked fine. Seems as though it got oil on that and decided not to work or I accidentally bumped it while wrestling with the dip stick housing.
 Old 10-22-2015, 08:08 PM   #3
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
Common problem. Its the singal wire for the starter. If this happens again and it will. Move it around and start ur car.
A fix is to take it off clean it really good then use di grease to keep it from corroding out
sbcfc07 likes this.
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
blackms3_71 is offline   Reply With Quote
 Old 10-23-2015, 10:21 AM   #4
570msp's Avatar
thanks for the tip. I'll probably do that as preventative maint before the winter hits
 Old 10-23-2015, 02:03 PM   #5
Same here lol i been putting it off for to long.
Crank But No Start Pagan47 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 10-21-2015 08:32 PM
mazdaspeed 6 crank no start Mazdaspeedmike07 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 10-11-2015 10:48 AM
Hard Start, Long Crank, Rough Idle red ghost MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 10-07-2014 11:24 PM
Long Crank at cold start maikell77 2010 MS3 - Troubleshoot/Diagnostics 4 03-13-2013 08:54 PM
Page generated in 0.26413 seconds with 21 queries
