 Old 04-05-2017, 11:13 AM   #1
cam1391's Avatar
Posts: 326   (View Stats)
cam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the worldcam1391 is the leader of the world
Groaned at 26 Times in 14 Posts
Default oil consumption
Okay so after lots of searching and lots of attempts to solve this, i am still eating a quart every 400 miles or so. So far i have replaced my turbo with a bnr s4 v2 and replaced the god damn pcv valve (both of which helped slightly). Im trying to find a compression/leakdown tester and will post results when im able. Im thinking its a valve seal as it only visibly burns oil for a second on startup and on decel. There is no oil buildup on the spark plugs and all four look identical. The constant smoking stopped after the pcv and turbo were replaced. I attached a short video of a cold start. I appreciate any input!
cam1391 is offline   Reply With Quote
 Old 04-05-2017, 11:18 AM   #2
cam1391's Avatar
Spark plug picture.
 Old 04-05-2017, 11:28 AM   #3
Thor Hammer's Avatar
Posts: 1,435   (View Stats)
Groans: 133
Went big turbo without doing comp test first? That seems risky but hey....racecar. How many miles on the motor?
Waiting for Install: BNR S3/HTP 3.5 Intake/Damond OCC/ CS Injector Seals/ WMI/MAPerformance Rev3 Intake Manifold
 Old 04-05-2017, 11:35 AM   #4
cam1391's Avatar
I did one a while back and had 175-180 across the board. I needed a new turbo reguardless and wasnt going to spend money on another pos oem oil puker. It had was definately shot. Engine has 106k, rotella t6 at 3k intervals since 40k.
 Old 04-06-2017, 01:52 PM   #5
ms6tats's Avatar
Posts: 32   (View Stats)
ms6tats is on a distinguished road
Nuts man. These motors love oil. Mine to. Has 184000km can't find the issue
Sent from my LG-H831 using Tapatalk
ms6tats is offline   Reply With Quote
The Following User Says Thank You to ms6tats For This Useful Post:
Jakeypoo (04-14-2017)
 Old 04-06-2017, 06:05 PM   #6
sheston's Avatar
Posts: 1,844   (View Stats)
Man, you've got so much valve train noise, it sounds like a circular saw
Didn't look like a quart every 400 miles. Do you see it out back when you go WOT?
 Old 04-09-2017, 09:38 AM   #7
cam1391's Avatar
Valvetrain is silent. I hardly ever see smoke. Doing compression and leakdown today.
Valvetrain is pretty much silent, There was a weed whacker running in the background. I hardly ever see smoke, only sometimes on decel.
Last edited by cam1391; 04-09-2017 at 09:39 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-09-2017, 12:03 PM   #8
cam1391's Avatar
Compression results are 185 185 185 185. Perfectly even across the board. Still trying to find a leakdown tester
 Old 04-09-2017, 06:28 PM   #9
sheston's Avatar
I assume you have looked all over the engine bay for a leak? Valve cover, timing cover, oil pan, turbo..... doesn't really look to me like you are burning that much
I guess my joke was too subtle, about the valve train noise. The weed wacker sounded like a circular saw :-)
 Old 04-09-2017, 09:25 PM   #10
Fstrnyou's Avatar
Posts: 1,489   (View Stats)
Is there not a Harbor Freight nearby? I see 2 in Jacksonville.
2006 MS6 GT - 152k Miles
Versatuner, 3-bar MAP, ITV22's
Russian Bushings in Back, Magnaflow CBE
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/Stage 2 OCC
Forged build ongoing. Manley H-Tuff & 2618, King Bearings
Other rides:
History:
 Old 04-10-2017, 03:39 PM   #11
cam1391's Avatar
Terribpe excuse but i just got back from out of town and im broke for another week. If a local nator guy has one i can use, otherwise ill do so this weekend. Thanks for the input guys.
Oh and yeah all the seals are dry, oil residue is from that god damn shifter shaft that i need to replace the seal on.
 Old 04-14-2017, 07:39 PM   #12
uh60gunner209's Avatar
Posts: 106   (View Stats)
uh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud of
Groaned at 8 Times in 3 Posts
Mine eats about the same amount of oil with no leaks or smoke
uh60gunner209 is offline   Reply With Quote
 Old 04-16-2017, 09:30 AM   #13
nizzy's Avatar
Posts: 15   (View Stats)
nizzy is an unknown quantity at this point
maybe you should check your pcv system. valve could be stuck open and blowing oil
EDIT- just reread your post and must of overlooked the pcv part. disregard this.....
nizzy is offline   Reply With Quote
 Old 04-16-2017, 11:48 AM   #14
Majin's Avatar
Posts: 112   (View Stats)
Majin has much to be proud ofMajin has much to be proud ofMajin has much to be proud ofMajin has much to be proud ofMajin has much to be proud ofMajin has much to be proud ofMajin has much to be proud ofMajin has much to be proud ofMajin has much to be proud of
I have heard of a similar issue and it ended up being that the oil control rings were getting all gummed up on high mileage motors.
Modifications: APv2//Damond PMM//HTP 3.5 SRI//JBarone RMM//3.25 TMIC with CS tubes//Autotech HPFP//Manzo 3" Catless downpipe//Matt D OCC Stage 2//Defi Boost Gauge//NGK Plugs//Koni FSD//Injector seals
Awaiting purchase: too much to list
"My mind is the space where my Id, Ego, and Anima all come together to exchange cookie recipes!"
Majin is offline   Reply With Quote
 Old 04-16-2017, 11:49 AM   #15
nizzy's Avatar
Whats considered high miles on these motors?
 Old 04-16-2017, 12:04 PM   #16
Majin's Avatar
IIRC, it was along the lines of motors after 115 to 125k and up.
 Old 04-18-2017, 07:52 PM   #17
mazda62006's Avatar
Posts: 49   (View Stats)
mazda62006 is a glorious beacon of lightmazda62006 is a glorious beacon of lightmazda62006 is a glorious beacon of lightmazda62006 is a glorious beacon of lightmazda62006 is a glorious beacon of lightmazda62006 is a glorious beacon of light
Groaned at 4 Times in 2 Posts
I have the same issue. I guess later in the year I will open the engine up and see what is going on
mazda62006 is offline   Reply With Quote
 Old 06-01-2017, 04:02 PM   #18
ssspencerjr's Avatar
Posts: 11   (View Stats)
ssspencerjr is an unknown quantity at this point
I'm having the exact same issue. I went from 133,703 miles (fresh oil change, full on the dipstick) to yesterday at 136,170 and the dipstick is right on the low oil marker. This was after changing my PCV valve as a hail mary fix.
Looking for any ideas as well.
ssspencerjr is offline   Reply With Quote
 Old 06-07-2017, 04:23 PM   #19
Design's Avatar
Posts: 1,885   (View Stats)
Groaned at 9 Times in 5 Posts
Standard troubleshooting:
1. Remove intake, IC and plugs; inspect for oil, including piston heads.
2. Idle car for 3 minutes; inspect for smoke.
3. Remove PCV hose at IM; inspect for one way flow.
4. Perform compression/leadkdown.
- Smoke at idle = turbo
- Smoke at cold startup and/or while deaccelerating = valve seals
- Oil in intake = turbo or plugged PCV
- Oil on piston heads and/or plugs = Plugged PCV, rings or ringlands
- Low compression/high leakdown = compression rings/ringlands
- Smoke out exhaust after switching from cruise to WOT = oil control rings or ringlands
Stock cats hide a lot of the smoke issues while driving. GL.
09 CWP MS3 GT
Ownership & Build Thread
Design is offline   Reply With Quote
 Old 06-12-2017, 08:55 PM   #20
mazda62006's Avatar
Well, I finally got the engine apart. I was losing a quart of oil and less than 200 miles. Change the turbo because I was getting oil out the cold side and into the intake. Has good compression in all cylinders. Here is the verdict from what I can see. Oil control ring and all four pistons are clogged. everything else looks good. Check out the pictures and tell me what you think. I right at 123k miles got the car with 116K.
The Following User Says Thank You to mazda62006 For This Useful Post:
Design (06-12-2017)
 Old 06-12-2017, 09:13 PM   #21
Design's Avatar
I can't tell from the photos but did you have gunk/carb deposits come off the bottom rings when you inspected them? Any blockages in the oil passages?
Certainly seems like they're passing oil from the bottom up...
09 CWP MS3 GT
 Old 06-12-2017, 10:25 PM   #22
mazda62006's Avatar
Yes, the bottom rings are gunked up with carbon. There are tiny holes in the rings but blocked by carbon. See picture with one of them unblocked
Design (06-12-2017)
 Old 06-12-2017, 10:38 PM   #23
Design's Avatar
Our former local So Cal builder Jordan Keifover had a box full of gunked up piston rings. Not completely blocked, but getting there.
I don't think the community realizes how big of an issue this really is. I think a lot if this is masked by failed motors as the symptoms are completely hidden, aside from rapid oil consumption.
09 CWP MS3 GT
 Old 06-21-2017, 07:11 PM   #24
mazda62006's Avatar
Here is what the underside of my head looks like. The intake is gunk up with oil deposit. I'm guessing this is from my old turbo that was passing oil. The exhaust looks normal. I'm right at 123,000 miles. Off to the machine shop for cleaning. sorry for the bad photos
Oil consumption PLEASE HELP ms6tats MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 12-27-2016 09:56 PM
Serious oil consumption Tiner MazdaSpeed 3 - Engine, Transmission & Driveline 3 07-31-2016 06:50 PM
Oil Consumption Big Dog Mazdaspeed3/6 General Discussion 0 01-21-2015 10:47 AM
Oil consumption Neubreed MazdaSpeed 3 - Engine, Transmission & Driveline 72 07-01-2014 10:21 PM
oil consumption?? MS6Blaze MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 02-13-2014 06:19 PM
Page generated in 0.41139 seconds with 31 queries
