Like Tree2Likes
  • 2 Post By Bingo
 Old 03-20-2017, 06:06 AM   #1
kh00054's Avatar
Posts: 8   (View Stats)
kh00054 is an unknown quantity at this point
Default Oil Leak - Thoughts on Source?
I need to put the car on ramps to look at it more closely, but has anyone else had a oil leak on the driver side that dripped behind the wheel? Motor has 94k and is all stock.
kh00054 is offline   Reply With Quote
 Old 03-20-2017, 08:49 AM   #2
AwAfrican's Avatar
Posts: 1,032   (View Stats)
Can you see any oil looking in your engine bay if your filter is out?
2013 Black MS3
 Old 03-20-2017, 10:23 AM   #3
Bingo's Avatar
Posts: 659   (View Stats)
Groaned at 9 Times in 7 Posts
I have the same leak. Mine appears to be coming from the steering rack, but it's not major enough for me to do something about it.
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Moog endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges.
 Old 03-20-2017, 12:02 PM   #4
fgh821007's Avatar
Posts: 1   (View Stats)
fgh821007 can only hope to improve
Groaned at 3 Times in 1 Post
What kind of oil can I use for a mz3 65 000 miles?
Enviado desde mi iPhone utilizando Tapatalk
fgh821007 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to fgh821007 For This Un-useful Post:
g00s3y (03-20-2017), Thor Hammer (03-20-2017), Vansquish (03-20-2017)
 Old 03-20-2017, 12:05 PM   #5
Bingo's Avatar
There's nothin wrong with this thread up until the post above. Can we we just pretend it's not there and move on? I would like this conversation to continue.
 Old 03-20-2017, 02:35 PM   #6
AwAfrican's Avatar
Facepalm....
Edit: if you had read your welcome email you would have found this thread... Everything you could hope to know about fluids MS6 Fluid Notes & DIY Pictures
2013 Black MS3
 Old 03-20-2017, 03:29 PM   #7
Thor Hammer's Avatar
Posts: 1,232   (View Stats)
Groans: 84
I smell a troll.
I don't use oil, I use KY jelly. Sometimes I spring for silicone based lubes when I don't blow all my money on banging escorts.
Waiting for Install: Damond OCC/ CS Injector Seals/ WMI/
monkey.bones.007 (03-20-2017)
 Old 03-20-2017, 04:10 PM   #8
g00s3y's Avatar
Posts: 2,077   (View Stats)
Groans: 410
Couple quarts of this will do perfect. It says mazda on the bottle and it's oil, can't get better than that.
Why, the leak isn't major enough for you to do anything about it, so why worry?
Last edited by g00s3y; 03-20-2017 at 04:10 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to g00s3y For This Useful Post:
AwAfrican (03-20-2017), monkey.bones.007 (03-20-2017)
 Old 03-20-2017, 05:13 PM   #9
Bingo's Avatar
Because I've yet to see a thread addressing this issue and quite honestly I don't know what's wrong or if it'll get worse. Even if it's not enough for me to rush into it this second, I'd prefer to still gain some knowledge/information about a potential problem as that's what this forum's about. A thread like this doesn't deserve dumpster fire status because the OP posed a legitimate question, and this could still serve as someone's help in the future.
AwAfrican and Speed3Pedro like this.
 Old 03-20-2017, 06:43 PM   #10
SpoolinSpeed3..757's Avatar
Posts: 41   (View Stats)
SpoolinSpeed3..757 is just really niceSpoolinSpeed3..757 is just really niceSpoolinSpeed3..757 is just really niceSpoolinSpeed3..757 is just really niceSpoolinSpeed3..757 is just really nice
Not entirely sure if I'm correct here but are the control arm bushings liquid filled? If so then it's probably time to replace them. Mercedes uses a liquid filled bushing much like that one. Do you have any abnormal sounds coming from the front end?
Sent from my SM-G930P using Tapatalk
SpoolinSpeed3..757 is offline   Reply With Quote
 Old 03-21-2017, 09:43 AM   #11
kh00054's Avatar
Default Update
I put the car on ramps last night expecting to find oil spewed everywhere and didn't see a drop minus what was in the picture. Turbo oil return line was dry as was the bottom of the trans and engine. ....I haven't noticed any abnormal sounds from the front end, but if the bushing is oil filled then it might be time to replace it.
Boost leak testing, possibly Wastegate/Actuator leak AgentWh0 2010 MS3 - Troubleshoot/Diagnostics 0 08-04-2015 12:29 PM
Need a more reliable 12v source meicalnissyen MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 03-08-2011 03:08 PM
Need ignition source to tap Qtip MazdaSpeed 3/6 - Car Audio & Electronics 10 11-17-2010 12:02 PM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 01:06 PM
Finding Source of Oil Leak, Are Octane Ratings Real?, Bearing Problem on Honda Civic, HCCI Engine, Another Bogus 'Gas Sa Haltech Automotive News 1 07-11-2008 06:13 PM
Page generated in 0.33719 seconds with 27 queries
