 Old 10-12-2017, 07:37 AM   #1
Mazstor's Avatar
Posts: 32   (View Stats)
Mazstor will become famous soon enoughMazstor will become famous soon enough
Default Opening ECU Rom File
I bough a MS6 used a little over a year ago that had a few upgrades on it. i did notice that there was a lose of power for a split second during wot. I changed out alot of things including the injectors, fuel pump internal etc. changing the fuel pump reduce the frequency of the cuts ( i suspect it is fuel cut) but it still happens during 4th gear pulls. I upgraded the intank fuel pump to something that flowed more (325lPH) to be exact. This actually fixed the issue for a while where there was no fuel cut. Im in upstate New york and the tempreture is unstble (fall weather) so on colder days the fuel cut issuse would start again and some times not at all. Im not sure what tune is on the car but it seems to hold steady at around 18 psi (stock turbo) and times spikes to 20.5. I did get a cobb acess port but ofcourse i cant log without installing it to the car. i did try out the best ots map cobb offered and i had no fuel cut issues no matter the temp. I wasnt impress with it, i copied the tune file that came with the car and saved it. its in a .rom format... is there anyone out there that can view this file and help identify what its actually doing? the car is full bold on cpe catted downpipe and magnaflow catback exhaust. This tune seems to be pushing the limits of the k04 but i have no idea if its load based or boost based etc. (rom file attached)
Mazstor is offline   Reply With Quote
 Old 10-12-2017, 07:52 AM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,800   (View Stats)
Groans: 535
Groaned at 178 Times in 115 Posts
https://www.cobbtuning.com/products/...da-accesstuner
06 MS6
 Old 10-12-2017, 10:48 AM   #3
g00s3y's Avatar
Posts: 2,117   (View Stats)
Groans: 428
TL;DR?
I'd help but I can't even begin to read that.
 Old 10-12-2017, 11:30 AM   #4
Mazstor's Avatar
Originally Posted by g00s3y View Post
TL;DR?
yeah.. if it was in a .hex format or .bin i know there are some software out there that could work. but .rom seems to be a cobb thing only... make sense since the accessport saved this file.
ATR MS6 AP V3 Install File BrandonM
Cobb ATR Support
5 05-26-2016 01:21 AM
VD - problem with log file EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 3 11-18-2013 12:33 PM
File recovery USMCEvan Computers & Technology News 12 08-19-2011 01:47 PM
Cobb ATR Help File Haltech MazdaSpeed 3/6 - ECU Computer Tuning 0 12-03-2010 03:53 PM
Page generated in 0.24919 seconds with 23 queries
