 Old 09-02-2019, 11:09 PM   #1
Exclus23's Avatar
Posts: 3   (View Stats)
Exclus23 has a little shameless behaviour in the past
Exclamation P0011 P0016 Stalling, rough idle, dragging sound
I have a 2006 Mazda 3S hatchback with 192,000 miles that is throwing a p0011 ("A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)) and p0016 (Crank/Cam Position Correlation – Bank 1 Sensor “A”)
Also threw a p0138 (O2 Sensor Circuit High Voltage (Bank 1, Sensor 2) previously but hasn't come back.
I noticed the CEL then the car developed a rough idle later in the day. It died while at a stopsign on the way home and wouldn't stay running until the 3rd restart. Then died as soon as I got into the driveway as I stopped in the driveway. It also developed a loud dragging sound about halfway through the drive as if the calipers were sticking. At first it was fairly quiet but became much louder as the drive went on and after the car stalled and was restarted. The noise only occurred while driving.
What steps should I take to diagnose this? What parts should I order? I checked the oil and while low, it was registering on the dipstick just around the min line. The car does burn oil and is often what appears to be significantly low (down 1+ quarts when checked after a few weeks or changed).
Are these threads relevant?: Strange P0011 Cell
Replacing timing chain
Thank you
Exclus23 is offline   Reply With Quote
VVT rattle on start+ p0011, p0016 codes CLL4545 MazdaSpeed 6 - Engine, Transmission & Driveline 3 10-29-2017 06:55 AM
My 2008 Speed 3 will not hold an idle and rides rough at low rpm and low idle Dgms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 11-23-2016 03:42 PM
Stalling at idle Kellz MazdaSpeed 3/6 - Troubleshoot/Diagnostics 36 03-03-2014 01:45 PM
Almost stalling at idle Mandinca MazdaSpeed 6 - Engine, Transmission & Driveline 20 02-26-2013 07:01 AM
timing related codes - fml - p0011, p0012, p0016 phillyb MazdaSpeed 3/6 - Troubleshoot/Diagnostics 31 11-03-2010 04:14 PM
Page generated in 0.23405 seconds with 20 queries
