 Old 04-05-2010, 01:17 PM   #1
11cruzito11's Avatar
Posts: 824   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
Default P0012 CEL Code
Hello eveveryone,
So today I went and did a drive on my MS3, everything seemed okay. Once I get home and park the car and let it idle the car felt like turning off and the Oil light starting blinking. I then turn off the car and go check my oil level. Oil level is fine, then I go to the DH and check for codes and I see this, P0012: A Camshaft Position - Timing Over-Retarded (Bank 1). I reset my battery by disconnecting the negative cable then turn on the car and let it idle for a couple minutes. Car idles fine then I drive around the block and CEL P0012 pops right back on. My car idles and drives good but I keep on getting this code, any suggestions?
Thanks,
11cruzito11 is offline   Reply With Quote
 Old 04-05-2010, 01:21 PM   #2
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
Neutral  -1 score
The Following 2 Users Say Thank You to phillyb For This Useful Post:
11cruzito11 (04-05-2010), djuosnteisn (04-08-2010)
 Old 04-05-2010, 01:42 PM   #3
JMEngineer's Avatar
Posts: 2,122   (View Stats)
JMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the world
Groans: 32
Groaned at 19 Times in 15 Posts
You have poo in cylinder #12
2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list...
2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch
-GTX2867R Coming Soon
JMEngineer is offline   Reply With Quote
The Following User Says Thank You to JMEngineer For This Useful Post:
Snotrocket (09-13-2016)
 Old 04-05-2010, 02:42 PM   #4
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Take the camshaft sensor out and wipe the goo off of it.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 04-07-2010, 04:57 PM   #5
JumpingJackson's Avatar
Posts: 967   (View Stats)
JumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the world
possible causes: jumped timing, CMP sensor issue, VVT actuator issue, OCV (oil control valve) that controls the VVT actuator. the PDF phillyb shows what to check.. But the fact your oil pressure light is blinking should point you in that direction.
JumpingJackson is offline   Reply With Quote
The Following User Says Thank You to JumpingJackson For This Useful Post:
 Old 04-07-2010, 05:22 PM   #6
is there a way to verify the VVT actuator is working? The oil pressure light only came up once and it went away. I'm gonna check the timing tomorrow to see if it didn't jump.
 Old 04-07-2010, 05:42 PM   #7
SSinstaller's Avatar
Posts: 3,953   (View Stats)
Groans: 58
This is one of those situations where stocking out and going to the dealer might be worth the time...
It's most likely an OCV or VVT actuator issue, unfortunatly there isn't much you can do to troubleshoot this yourself...
Soon to be installed:
 Old 04-07-2010, 07:25 PM   #8
would jumped timing cause this code? it looks like my #1 cylinder at TDC is not lining up with the cams and the crank pulley white mark, it's like 1 whole tooth off.
 Old 04-08-2010, 08:33 AM   #9
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Didn't you have oil squirter issues as well? If an oil squirter was missing or something, it could drop the oil pressure quite a bit IMO, and possibly affect OCV and VVT stuff.
It's also probably worth while to verify the timing on the motor if you have any doubts at all. It can be done in the car.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 04-08-2010, 09:13 AM   #10
My oil squirter issues were fixed, I even pulled down my oil pan to see if all 4 squirters was still there.
I got the Cam alignment tool today from SUMark and I have verified my timing is off by a whole tooth on the Crankshaft sensor, the white mark is one tooth below the sensor, would this be a possibility?
 Old 04-08-2010, 09:22 AM   #11
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
www.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the worldwww.cp-e.com is the leader of the world
Groaned at 115 Times in 51 Posts
Time to RETIME the motor.
www.cp-e.com is offline   Reply With Quote
 Old 04-08-2010, 09:24 AM   #12
That's what I'm gonna do tomorrow I'll redo the timing and take it from there.
 Old 04-08-2010, 09:27 AM   #13
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
I think you should verify oil pressure.
the VVT and OCV are both directly related to oil pressure.
The Following User Says Thank You to socks For This Useful Post:
 Old 04-08-2010, 09:33 AM   #14
Once I retime the motor, I can verify that. Do I need a oil pressure gauge to do that? Is there a specific range of pressure?
 Old 04-08-2010, 10:24 AM   #15
Captain
Groans: 79
Originally Posted by 11cruzito11 View Post
...I have verified my timing is off by a whole tooth on the Crankshaft sensor...
Definitely a possibility lol.
www.permtuning.com
felt (04-08-2010)
 Old 04-20-2010, 08:12 AM   #16
Forgot to update thread, re-timed engine and P0012 has not came back.
Car is running perfect now.
The Following User Says Thank You to 11cruzito11 For This Useful Post:
djuosnteisn (04-20-2010)
 Old 04-20-2010, 08:21 AM   #17
phillyb's Avatar
Groans: 1,940
i've thrown this code recently too.
how does one retime engine?
 Old 04-20-2010, 08:33 AM   #18
I threw this code because I time'd the engine wrong, I know JumpingJackson threw P0011 and P0016 when his timing chain broke off and jumped timing.
To do the timing you need the following:
Cam Alignment tool
TDC timing peg
crank holding tool (i needed this)
to check your timing on your car you do the following:
- Place #1 cylinder at TDC.
- take off your valve cover and verify (at least the exhaust cam) that the cam slots are centered. also, the lobes in the intake/exhaust cam should be facing each other in a backwards V position.
- the crank pulley should have a tooth painted white (if not there is a grove/space in the pulley without tooths. start from there and count backwards until you hit the 20th tooth. that's the timing mark tooth. make sure that tooth is lined up straight to the crank sensor.
hopefully i'm giving you the right directions.
The Following 3 Users Say Thank You to 11cruzito11 For This Useful Post:
Jackis (10-06-2011), phillyb (05-08-2010), spnkr21 (05-26-2010)
 Old 10-06-2011, 05:52 AM   #19
Jackis's Avatar
Posts: 428   (View Stats)
Jackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the world
Time to revive that.
After I decided to make proper timing on my engine (first time after rebuild - we put the timing "as we could" lol), it became totally messed up. I did everything what I should (according the quideness) - and after we made it, car runs very stupidly, especially before 3K, MAP pressure raised twice and I threw P0012 once.
What I shall do tomorrow - I shall check again all the timing and check VVT actuator. What is annoying me - raised vacuum at idle. By raised - I mean actually that I had 30kPa of absolue pressure, now I have 60kPa on idle! But on lifting the gas when driving it is 30kPa which is nice, and when I put neutral or push the clutch - it goes back to bad 60kPa.
May be someone will come here and just say: "Hey I know where the shit is, just change something". By something I mean not the car
Does your MS3 start when it's -30C (-22F)?
Forged, bolted, tuned, gtx30/tial/ewg. Thanks.
Jackis is offline   Reply With Quote
 Old 10-12-2011, 10:44 AM   #20
Jackis's Avatar
Just FYI.
Managed that. When torquing crank pulley, one must put the pulley in place because it slips the direction opposite to lock bolt. So we just redid it from the scratch and now it it fine.
And don't forget to rotate the cam once, just to get know if your valves are not touching the piston lol
 Old 03-17-2014, 07:25 AM   #21
buckeyepost's Avatar
Posts: 295   (View Stats)
buckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond repute
Cruising at 65mph today and my DH knock retard started pumping up in the 7's then the car shut off. Tried to crank it on the side of the highway and it tried to turn over but couldn't. Don't want to fuck it up by trying again... sounds like it might need retimed by reading through this post???? Just replaced timing chain, vvt actuator, tensioners, etc last fall at 100k miles... clocking about 107k now I think.
07 MS3 GT {DD} \\ 295whp 328wtq (pre E mix) \\ Cobb AP {Stage 2} \\ MS CAI & CBE \\ ATP DP/MP {catless} \\ Corksport TMIC \\ SURE TIH \\ TurboSmart Kompact BPV \\ AutoTech FP internals \\ Denso ITV22's \\ SU RMM \\ Ralco STS\\ Hawk HPS pads \\ StopTech rotors \\ Sensen dampers \\ Moog swaybar links \\ DashHawk \\ 225/45 Kuhmo Ecsta XS's on 18x7.5 Momo S-five's \\ 205/60-16 Dunlop Winter Sport 3D's on steelies
1:3 E85 mix Dizzy tuned by Boost_creep
...... sold :-(
buckeyepost is offline   Reply With Quote
 Old 04-28-2014, 11:30 AM   #22
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
I am going to guess by now you have found that your timing fully slipped and you now have bent valves and had to replace bent valves and re time motor
 Old 04-29-2014, 06:28 PM   #23
It is seized up in my barn and havent had the time or money to take it apart yet, so from what your saying its possible the engine can be ssaved/ rebuilt? Otherwise im stuck with a used $3300 motor if i can even find one? Probably just fixing this thing and selling it. I need a truck anyway....sad
...... sold :-(
 Old 06-17-2016, 12:19 AM   #24
MS3jAY's Avatar
Posts: 13   (View Stats)
MS3jAY will become famous soon enough
Not to thread hi-jack. But when 11cruzito11 said a backwards V. Does this mean the lobes of the crankshafts are facing towards the center of the engine? An Upsidedown V??
Just want some clarification as i'm in the same boat. However my issue isn't dropping oil pressure but rather getting a popping sound from Cyl #1 about 5-6K RPM. I don't rev that high until i can resolve this issue.
Thanks!
MS3jAY is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f293/p0012-cel-code-53108/
Mazdaspeed 6 Common Problems - AE Autos This thread Refback 12-18-2015 04:06 PM
p0012 2009 mazda This thread Refback 11-17-2015 06:43 PM
mazda 6 code p0012 - Answers Search This thread Refback 04-09-2014 05:36 PM
P2006 code SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 09-25-2015 06:32 PM
Color code rtaylor60 Appearance - SILVER 2 04-12-2010 11:50 PM
Please help trouble codes P0012,P2187,P2088!!!!!!!!!!!!! gt5 MazdaSpeed 3/6 - Turbo Induction 7 02-25-2010 06:43 PM
Code U2064? SharkDiver MazdaSpeed 3/6 - ECU Computer Tuning 13 01-08-2009 08:18 PM
EGR Code pbblaster MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 10-28-2008 04:18 PM
Page generated in 0.43081 seconds with 33 queries
