Like Tree8Likes
  • 1 Post By 5doorsoffury
  • 1 Post By Fstrnyou
  • 1 Post By aackthpt
  • 1 Post By soulitified
  • 1 Post By TroyK
  • 1 Post By TroyK
 Old 06-05-2017, 12:29 PM   #1
soulitified's Avatar
Posts: 31   (View Stats)
soulitified is a jewel in the roughsoulitified is a jewel in the roughsoulitified is a jewel in the rough
Default P0304 Idle & WOT / High KR
CONCLUSION: To save you some time, I have fixed this issue. It was my 4th cylinder fuel injector that went bad. Grommets were broken as well, bouncing around inside the fuel rail.
Hey all – so after a month & a half of research and troubleshooting, I am posting.
(I know there are tons of threads on this topic, but I can’t seem to narrow mine down)
[Mods are in my sig] 97k miles. It all started with a bad batch of gas…I got stuttering under boost after 25 miles after fill up. Not knowing it was the gas, I changed out the plugs, swapped the coils around, added two gallons of E85. Still getting a CEL.
I ran out that tank of gas, and got some genuine 91 octane, no ethanol. Car ran great for about 50 miles. Problem persisted.
The CEL is popping up at idle and flashing under WOT. I've only gone WOT to record logs..which I'm seeing very high KR. 5.0+
Thinking it could be injectors, I started removing everything for that process. My mechanic was able to soak my IM, and EGR tube, so those are spotless. The top right bolt (in front of cyl#4) holding the IM on, I discovered that bolt was broken. Some adhesive all over it. Hoping that was the culprit creating a giant leak, I replaced that bolt. Discovered my PCV hose was just a normal silicone hose and was pinched shut. Replaced that with the proper OEM hose.
Went to pull the injectors and before I even got the first torx bolt loose, I broke my bit...I said fuck it (because I found that broken bolt, I really thought that was my problem) I got everything back together and the problem is still there. Part of me thinks the injectors are fine because FP in my logs seem normal..but I could be wrong.
I put the stock heat range plugs in and the start up is definitely better, and the idle is smoother..still a CEL at idle.
I need some advise where I should look next. Datalogs are below as well as a condensed list of things I have tried. (sorry for the long post, I wanted to get as much info out as I could before I posted a "hey I got a P0304!!!")
Things I've tried...
-Moved and check coils, misfire stayed in Cyl#4 (resistance is 1.8)
-Checked all tubes around intake and IC
-Changed plugs and gapped at 0.028 (NGK IL TR6A-8G)
-Cleaned IM
-Cleaned TB
-Cleaned EGR Tube
-Cleaned MAF
-Replaced PCV Hose
-Replaced battery and terminals (due to significant corrosion build-up)
-Changed oil 200 miles ago
-Compression test showed...
D: 180, 184, 184, 180
W: 180, 184, 184, 180
First photo showing old plugs. Second is the current plug for the 4th cyl. Third is the broken IM bolt. Then PDF's of my logs. Wasn't sure the best format for those, so I have a few available.
08 Mazdaspeed3 [GHOST TUNED]
ACT: 6 Puck
Autotech: HPFP Internals
BF Goodrich G-Force Comp-2 [225/40/18]
Cobb: AccessPort, FMIC Piping v2, SRI
CS: Injector Seals, TIP, EBCS
Damond: EGR Delete, RMM, PMM, 2 OCC's & PCV Plate
Eibach: Sportline Springs
Enkei GSR's
GoFastBits: TMS Dualport BOV
JBR: IM/TB Coolant Delete + Gaskets, RSB + Tru-Torsion Billet Bracket/Bushings
Koni: Yellows Struts
Manzo: Downpipe
Megan Racing: Camber Arms
Racing Beat: CBE w/ Muffler Delete
Treadstone: TR8 Core
Whiteline: ALK, Bumpsteer Kit, Poly Bushings, Rear Endlinks
Last edited by soulitified; 07-10-2017 at 11:48 AM. Reason: Added milage, oil change // added what fixed my problem
soulitified is offline   Reply With Quote
 Old 06-05-2017, 01:32 PM   #2
g00s3y's Avatar
Posts: 2,128   (View Stats)
Groans: 439
Nevermind, didn't read...
 Old 06-05-2017, 02:41 PM   #3
just HOPING this isn't a fkn zoomzoom boom situation.
ACT: 6 Puck
Enkei GSR's
Manzo: Downpipe
 Old 06-05-2017, 08:08 PM   #4
Fstrnyou's Avatar
Posts: 2,231   (View Stats)
Run a few tanks with fuel system cleaner. I had a recurring misfire code and after a few bottles of cleaner, it hasn't come back. I used Lucas brand.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 06-06-2017, 06:45 AM   #5
5doorsoffury's Avatar
Posts: 1,086   (View Stats)
Groans: 74
Ok so maby the kr from the bad gas caused cylinder pressure to spike to the point where the injector seals are loose/crappy. Loose inj seals will cause kr and you do have high milage. Soooo i would put in 1 gallon of e85 on a full tank and see if the kr is there while doing a WOT log. I know you ran ethonol but you never stated if the kr was there only that you had a cel. Did you clear the cel inbetween all these fixes? If it is then its mechanical if not its gas related. E85 even a gallon should raise the octane enuf to narrow down the source of the kr.
BTW if you pull the injectors you need to replace the injector seals anyway so good thing that torx bit broke. Get a proper set not thay crappy shit you find hanging above the parts counter guy.
soulitified likes this.
MECP
2012 BM
Rfinkle tune in progress
The Following User Says Thank You to 5doorsoffury For This Useful Post:
soulitified (06-06-2017)
 Old 06-06-2017, 07:58 AM   #6
Would a compression test show that kind of mechanical failure? I yielded great results so i hope I'm in the clear there.
I've been constantly clearing the cel. Sometimes I can drive 15 miles with nothing, then it pops back up.
I will put in a gallon of eth, and run some more logs. If it's the seals, the KR should minimize, proving the seals are bad?
I've been wanting to go this route, but I haven't due to reading negatives about doing so, and I know some people just don't believe in it...but yet it helped you and plenty others. Shit has me stumped.
I'm gunna try a gallon of eth in hopes that does the trick.
ACT: 6 Puck
Enkei GSR's
Manzo: Downpipe
Last edited by soulitified; 06-06-2017 at 07:58 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-06-2017, 09:07 AM   #7
Fstrnyou's Avatar
If KR remains with some E in the tank, you are experiencing false knock caused by a mechanical issue, which could be leaking inj seals.
Other rides:
History:
 Old 06-06-2017, 09:54 AM   #8
That would be ideal. I have CS seals in the box, just waiting on my mechanic currently. I'm confident I could do it, but it'd be my first time fkn with injectors and I don't want to take the chance of fkn that up.
Thanks for all the input btw - really appreciate you taken the time to help me troubleshoot.
ACT: 6 Puck
Enkei GSR's
Manzo: Downpipe
Last edited by soulitified; 06-06-2017 at 09:54 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-06-2017, 10:18 AM   #9
Fstrnyou's Avatar
I did mine in my driveway. Wasn't too bad. I'm sure there is a tutorial thread somewhere here. I used Toyota seals though, so it's only a matter of time before they fail and I get to do it again.
All of my injectors popped right out. Others need to use a puller tool if there's a good bit of corrosion.
Other rides:
History:
 Old 06-06-2017, 07:16 PM   #10
I ran 1 gallon of e85. Here are the logs..all forth gear, 2500rpm's to 6K.
Without boost everything seems fine. No cel. But the first time I got into boost the cel came back (P0304). This was without e85, just warming up the car prior to filling.
After 1 gallon of e85 I ran 5 logs. They progressed as I went, the first two logs I got a cel in the middle of pulling. Around 4/5krpm. I stopped and cleared the cel after the second log. My last 3 logs were better. No cel during my pulls. But after letting off the cel would come back each time. I cleared the cel after the 3rd, 4th and 5th logs.
It looks like I'm getting KR right around 10-13psi WOT
-I'm on the OTS Stage 1 91 map btw
ACT: 6 Puck
Enkei GSR's
Manzo: Downpipe
 Old 06-07-2017, 08:56 AM   #11
Groans: 74
You are really lean and bats are high. It looks like real knock since it decays. I would do a maf cal maby a valve cleaning. 12.5 afr 125 bats 12 degrees of timing at 5 k when knock hits
MECP
2012 BM
soulitified (06-08-2017)
 Old 06-07-2017, 02:25 PM   #12
Would a loose MAF cause this? Not necessarily the knock. My MAF seems to be seated just fine, but I have noticed when screwing it back in the bolts won't go tight like on my other vehicles. There is minimal play, but still there nonetheless.
ACT: 6 Puck
Enkei GSR's
Manzo: Downpipe
 Old 06-07-2017, 03:32 PM   #13
aackthpt's Avatar
Posts: 1,450   (View Stats)
aackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the world
If you're replacing injector seals, get the injectors cleaned too. If you can't be down for the time, buy a set of injectors on the used market and send them off for cleaning ahead of time.
2013 'speed3, silver
Stage Bro
aackthpt is offline   Reply With Quote
The Following User Says Thank You to aackthpt For This Useful Post:
 Old 07-10-2017, 11:44 AM   #14
For those of you following this thread or having similar/identical symptoms...
It was my 4th cyl fuel injector that went bad. The grommets were broken as well, bouncing around inside the fuel rail (causing KR?)
Since then (800 miles on the new injector so far) everything has been running great. Car is back to normal. Pulls hard, no cuts, no stuttering, no cel's...I will attach some logs when I get home.
tomek CX7 likes this.
ACT: 6 Puck
Enkei GSR's
Manzo: Downpipe
The Following 2 Users Say Thank You to soulitified For This Useful Post:
aackthpt (07-10-2017), TroyK (03-13-2018)
 Old 03-13-2018, 06:41 PM   #15
TroyK's Avatar
Posts: 34   (View Stats)
TroyK has a spectacular aura aboutTroyK has a spectacular aura about
Dude thanks so much for posting your results after the issue was resolved. I've been going down the same exact path as you did, and I'm about ready to pull the injectors and check cyl4... First going to check with E85 and/or Lucas fuel system cleaner. Will post results.
TroyK is offline   Reply With Quote
 Old 03-17-2018, 01:37 PM   #16
TroyK's Avatar
Update since I said I would: E85/Lucas fuel cleaner did nothing, misfire on cyl4. New OEM plugs, nothing changed. Compression results: 160 160 150 160 (rebuild this summer will bring those #'s up). Swapped coils on 3&4, and same time swapped plugs on 2&4; misfire stayed on cyl4. Ended up following Jimmer307's injector replacement how-to. New injector on cyl4, now runs like a dream. No stutter, no CEL.
The Following User Says Thank You to TroyK For This Useful Post:
Db09ms3 (03-19-2018)
 Old 03-19-2018, 08:25 AM   #17
That's good to hear man, I'm glad my experience helped.
My car is not a fan of the 91oct in my area (or that I was acquiring) So i ended up tuning on 93oct and its been great.
[moral of this is: also find good fuel] lol
ACT: 6 Puck
Enkei GSR's
Manzo: Downpipe
 Old 03-19-2018, 03:38 PM   #18
TroyK's Avatar
Yeah. I was driving back from a trip to Colorado when the first small misfires started happening. Some of the gas stations in West Nebraska and East Colorado (aka middle of nowhere) that I went to were definitely suspects for the bad fuel source.
The very day I got home, I started getting heavier stutter. The next day, misfire CEL. Next time I'll be filling up more frequently so I'm not forced to refuel at the shady pumps.
 Old 03-20-2018, 09:10 AM   #19
I will also be routing my trips accordingly..
www.find93.com
ACT: 6 Puck
Enkei GSR's
Manzo: Downpipe
High Idle Tomas MazdaSpeed 3/6 - Troubleshoot/Diagnostics 58 04-10-2018 05:55 AM
High fuel trims at idle sdg_3mps MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 32 07-28-2012 06:51 AM
High Idle that1rowdyracer MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 11-08-2011 04:17 PM
Funny High Idle mtlms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 18 11-07-2011 12:55 PM
high idle bieberhole69 MazdaSpeed 6 - Engine, Transmission & Driveline 12 11-22-2010 04:46 AM
Page generated in 0.41558 seconds with 26 queries
