| MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() | | #41 | ![]() |
| (Toe-kay) ![]() Join Date: Jan 2011 Location: Oakville Ontario Canada
Rep Power: 8679 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,666
Groans: 501
| Not Ranked : 0 score
__________________ ![]() ![]() Tokay Racing BeCuse Seals. BeCuse you need these. Demodded. Mwho? |
![]() | | #42 | ![]() |
| Terboh Slayer ![]() Join Date: Dec 2010 Location: San Antonio, TX
Rep Power: 1047 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
Groaned at 22 Times in 17 Posts
What other 20th tooth is there?
__________________ Intake, etc. #heritage |
| The Following 2 Users Say Thank You to bmylez For This Useful Post: | dougefresh_ (05-20-2012), Tokay444 (12-18-2011) |
![]() | | #43 | ![]() |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 3915 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,863
After my timing slipped, the ecu would still target 10* with out issue, just the fueling was off (not hold stoich, but the trims would stay well with in reason...talk about a head scratcher). The minuet I checked and moved the sensor position with the mechanical timing the car went back to holding stoich at idle just fine. For safety measure I did not drive the car again. I am currently installing an entire new timing assembly.
__________________ I am my own After Market Company. Worlds First Port Fuel Injected MazdaSpeed 3 A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. |
| The Following User Says Thank You to SilverDemon For This Useful Post: | dougefresh_ (05-20-2012) |
![]() | | #44 | ![]() |
Well, Scott, here's the thing. You said your trims were within reason but not holding stoich. My trims are sometimes normal, sometimes way whacked out, but the rich at idle does give a clue. How do you know it slipped a tooth? Do I need to remove the timing cover to check this? Anything else I can look at? And the fact that my timing at idle is as high as 14*...what does that mean???
| The Following 2 Users Say Thank You to bmylez For This Useful Post: | dougefresh_ (05-20-2012), SilverDemon (12-18-2011) |
![]() | | #45 | ![]() |
Ooohh... I don't know...My ignition timing read out on the dash hawk did not move, always stayed ~10*...I know weird... hahah It did not slip entire tooth on the reluctor wheel on the crank pulley, it went from being in the center of the 20th tooth, the bottom of the 20th tooth, when the #1 piston was at TDC. You mentioned that you aligned the sensor, but then you also mentioned that you do not have the timing tools. Checking the timing and aligning that sensor cannot be done (at least accurately) with out at least the timing peg and a 6mm bolt long enough to fit through the crank pulley. After I aligned the sensor, I pulled the valve cover off and could see that the cams were off enough that I did not need to install the plate. I kept throwing the random misfire code since the ECU thought the timing was advanced farther than it really was. I think I was on the verge of thrashing the valves in the head ARRRGG!!! EDIT: Do you have the EGR pipe still piped up to the intake mani? A slightly stuck EGR may cause the whacky trims at time.
__________________ I am my own After Market Company. Worlds First Port Fuel Injected MazdaSpeed 3 A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. | |
![]() | | #46 | ![]() |
Not trying to blame Dustin, but he said all I needed to do was line up the hole in the crank pulley with the hole in the block. Are you telling me that when I lined up the holes, I wasn't necessarily at TDC? If that is the case, I am getting a timing pin ASAP. Fuck...
![]() | | #47 | ![]() |
Alright, I'm gonna have a timing pin overnighted. I doubt this will solve all my problems, but if my timing isn't right (which it surely isn't at this point), then it will mask any other problems.
![]() | | #48 | ![]() |
Groans: 501
Get new crank bolt and friction washers as well.
![]() | | #49 | ![]() |
Well...there is no way to tell if the #1 piston is at TDC with out the timing peg. If you are aligning the sensor just based off the hole in the block behind the pulley, then yes, there is no way to be sure that it is at TDC. How many times have you aligned the sensor this way? Because if the sensor keeps needing to be adjusted, then something is moving... I would get it checked soon....
![]() | | #50 | ![]() |
The only reason I've adjusted the sensor is that I was dumb the first time I moved it and thought, "Well, since I only have one bolt to secure it, I'll eye it the best I can." That was back in...March I think. Car ran pretty well. I even switched from SB to AP and made good power. No abnormalities. I just started having all these issues after all my BT setups failed miserably and my k04 died. So now I've swapped to working k04, car runs weird sometimes (I've detailed it all in my thread in this section). So the reason I've had to adjust the sensor more than once is I moved it to begin with, then everyone freaked out on me so I tried to correct it. I just misunderstood what Dustin told me.
| The Following User Says Thank You to bmylez For This Useful Post: | dougefresh_ (05-20-2012) |
![]() | | #51 | ![]() |
Hahaha... OK, I think all dustin was saying is that you can check to see if any thing is moved. Since you have moved it, it would be great to just double check if everything is back in line. No harm if everything lines back up!! Keep us updated!!
![]() | | #52 | ![]() |
No, I can show you his post. He was telling me how to re-align the crank sensor, but he assumed I knew that I had to get to TDC before putting the crank pin in. Not his fault, just assumptions on both sides. I already know the sensor is not lined up correctly...I'm running 14* at idle sometimes!!! Also, what do you use to hold the crank pulley in place to remove the crank bolt? Not sure if there is a cheaper option out there...
![]() | | #53 | ![]() |
| Not Ranked : 0 score ![]() I have a very similar tool to this one. The difference is the one I have has adjustable pin locations. EDIT: The first pic I posted was the wrong pulley holding tool.... I removed that pic....sorry
![]() | | #54 | ![]() |
Why must it be so expensive? ![]() You have a link for which one you bought?
![]() | | #55 | ![]() |
| Not Ranked : 0 score http://www.mazdaspeedforums.org/foru...ey-tool-98467/ He found one that is much better than the one I have
![]() | | #56 | ![]() |
Groans: 501
iPhone URL: Sealey Crank Pulley Holder Tool Ford Duratec - VS4736 Browser URL: Sealey Crank Pulley Holder Tool Ford Duratec - VS4736 Download eBay Mobile D'oh Look at this on eBay: Sealey Crank Pulley Holder Tool Ford Duratec - VS4736 Sealey Crank Pulley Holder Tool Ford Duratec - VS4736 | eBay There.
__________________ ![]() ![]() Tokay Racing BeCuse Seals. BeCuse you need these. Demodded. Mwho? Last edited by Tokay444; 12-18-2011 at 05:15 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | dougefresh_ (05-20-2012), SilverDemon (12-18-2011) |
![]() | | #57 | ![]() |
| Veblen Goods ![]() Join Date: Jan 2009 Location: Dania Beach, FL
Rep Power: 2112 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,364
I just went down to crank the engine to check it but it won't start. God damn motherfucker. During the day I'll see what I put back together wrong.
I think one bolt alone can hold the sensor in place. But to be safe, you should drill a lil deeper in the hole they fucked up and re-tap the hole to see if you can get a screw to hold, The screws are not that long and I believe there is enough meat in the block to drill about 5mm deeper. Take a tap with no starting thread so you can cut the thread all the way to the bottom of the hole. You might have to sacrifice a tap to do this by grinding the starting thread of . I believe its M6.
__________________ ![]() GHEY THUNDER | |||
| The Following 2 Users Say Thank You to Tomas For This Useful Post: | dougefresh_ (05-20-2012), SilverDemon (12-18-2011) |
![]() | | #58 | ![]() |
Groans: 501
Maybe that won't work. Says 1.8/2.0 duratechs
![]() | | #59 | ![]() |
That is a hell of a lot cheaper than the OTC part number.... I saw a price of $216 from the link I posted.....
![]() | | #60 | ![]() |
| Not Ranked : 0 score It sure looks it will work... but not willing to gamble $140 just to find out... Shit, I need to start making these tools....
![]() | | #61 | ![]() |
Shit esse. Put the fucker in 6th gear and take an impact gun to that crank bolt> crank pulley tool.
![]() | | #62 | ![]() |
__________________ I am my own After Market Company. Worlds First Port Fuel Injected MazdaSpeed 3 A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. Last edited by SilverDemon; 12-18-2011 at 05:36 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #63 | ![]() |
Scott: So you're not entirely sure that will hold the crank correctly or it should work well enough?
__________________ Intake, etc. #heritage | |
![]() | | #64 | ![]() |
Groans: 501
First acquire left hand helix drill, then worry about drilling.
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | SilverDemon (12-18-2011), Tomas (12-18-2011) |
![]() | | #65 | ![]() |
| Not Ranked : 0 score No, I am not totally sure the tool in the link will work for our application. It resembles the style I borrowed, but it does not look as beefy. I went out to the garage to look for part numbers on the tool I have, no luck. I will ask my buddy tomorrow where he bought it. The last thing I want is for you to get ass hole deep in this, and then find out that the tool will not work.
![]() | | #66 | ![]() |
Groans: 501
| Not Ranked : 0 score SPEED6 KILLAH had a good ford tool. Took a Johnson bar.
| The Following User Says Thank You to Tokay444 For This Useful Post: | SilverDemon (12-18-2011) |
![]() | | #67 | ![]() |
| Will fuck up ur day ![]() Join Date: Feb 2010 Location: Parrish, FL
Rep Power: 3380 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,742
Groans: 409
Groaned at 205 Times in 121 Posts
| dude, this is what I fuckin told you! Didn't I tell you the FSM page to refer to and everything in shout?!!
__________________ 07 MS3 bone stock? The original Genpoo Hater GTX3076r FenderRollerRental Rent a fender roller, or MZR DISI Timing tools! Turismo Vids - Store your car vids and pics here! Blog your builds too!
![]() | | #68 | ![]() |
Yup... and that tool is over $200...
![]() | | #69 | ![]() |
Groans: 501
Ah.
![]() | | #70 | ![]() |
Here's the post: http://www.mazdaspeedforums.org/foru...ml#post1148293
| The Following User Says Thank You to bmylez For This Useful Post: | chimmike (12-19-2011) |
![]() | | #71 | ![]() |
Oh.
![]() | | #72 | ![]() |
Replaced the cranks sensor. Still not working. I will start looking at mechanical problems. I know fuel pressure is there so I will start with spark plugs and coils.
| The Following User Says Thank You to Tomas For This Useful Post: | dougefresh_ (05-20-2012) |
![]() | | #73 | ![]() |
Rep Power: 8454 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,990
Groans: 31
I would check to see if you have a spark signal before replacing coils and plugs. Tappin
__________________ 2010 Speed3---GTX2867 // SURE 3" Intake // HTP 3" inlet pipe // Ultimate Racing DP/TP // Corksport CBE // KMD v2.1 hpfp internals // Devils Own WMI // COBB FMIC // 3bar map sensor // GFB dual port BPV // JBR 70 duro RMM // MD Dual OCC // Drag DR-34 18x8 // Nitto Neo-gen 235/40 r18 // NJSPEED3 Ported Intake Manifold // JBR TIGS Perm Tune by the Freek ![]() 417hp/395tq 12.903@117.33 Street tires and shitty 2.25 60ft |
| The Following User Says Thank You to atvfreek For This Useful Post: | dougefresh_ (05-20-2012) |
![]() | | #74 | ![]() |
I am sick of paying the over rated prices of OTC tools....so I did something about it!
| The Following 5 Users Say Thank You to SilverDemon For This Useful Post: | atvfreek (12-21-2011), BlueStreak (12-23-2011), dougefresh_ (12-21-2011), Tokay444 (12-21-2011), Tomas (12-21-2011) |
![]() | | #75 | ![]() |
ok. Problem fixed. It wasn't the CKPS as suspected. So this is what a loose clamp can do. 12 hours of work and $70 in parts for being an imbecil. I didn't tie down the worm clamp on the turbo outlet all the way and while at the track was loosing pressure and running rich pretty much constantly while on boost. Unfortunately given that I assumed a slipping clutch instead of operator error, the plugs got so fouled while going WOT all the time that the car was probably not igniting in one of the cylinder at all. To my defense, the car felt identical in this condition to a slipping clutch. I should have known though that the clutch ussualy won't start slipping till its hot while at the track the vehicle showed this condition of slowly rising and falling RPMs while WOT even when cold. I can only guess the P0335 code will appear if one of the cylinders isn't firing properly. What's strange is I would have guessed I should have also gotten a P0300... misfire code.
| The Following 2 Users Say Thank You to Tomas For This Useful Post: | dougefresh_ (12-23-2011), SilverDemon (12-23-2011) |
![]() | | #76 | ![]() |
Weird man... glad you tracked it down. Good info
| The Following 2 Users Say Thank You to SilverDemon For This Useful Post: | dougefresh_ (05-20-2012), Tomas (12-23-2011) |
![]() | | #77 | ![]() |
| Not Ranked : 0 score djuosnteisn chimmike Got my TDC pin and I FINALLY fixed the crank sensor correctly, hahaha. After putting the pin in, I was off by prolly 1/3 - 1/2 a tooth, which is obviously a big deal. I also remembered to air gap it correctly. Pulled out my feeler gauge kit and used a .508mm and .487mm plate or some shit. The spec is .5 to 1.5mm, so I shot for the middle.
| The Following 2 Users Say Thank You to bmylez For This Useful Post: | atvfreek (12-31-2011), dougefresh_ (05-20-2012) |
![]() | | #78 | ![]() |
![]() Join Date: Sep 2008 Location: NorCal
Rep Power: 360 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 390
Groaned at 5 Times in 2 Posts
Can you make me one?
__________________ Cobb AP, 504whp 492wtq | |
| The Following User Says Thank You to 11cruzito11 For This Useful Post: | SilverDemon (12-31-2011) |
![]() | | #79 | ![]() |
Yeah, and what's your price?
| The Following User Says Thank You to bmylez For This Useful Post: | SilverDemon (12-31-2011) |
![]() | | #80 | ![]() |
I actually thought about making another one so the guys could borrow it, or making a few to sell.... let me do some checking on material and what not and see if I can come up with something.
| where is the Throttle Position Sensor? | vballbwing | MazdaSpeed 6 - Engine, Transmission & Driveline | 4 | 10-06-2011 09:05 AM |
| need a how to on setting tdc to replace crank sensor | turd burglar | MazdaSpeed 3 - How-To's | 4 | 08-26-2011 06:06 PM |
| Clutch pedal position sensor | DISITRB | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 06-11-2010 09:31 PM |
| Does anyone know where to find the Camshaft position sensor!!! | gt5 | MazdaSpeed 6 - Engine, Transmission & Driveline | 9 | 02-28-2010 06:36 PM |
| Camshaft Position Sensor Retarding | dukebrown | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 08-01-2009 12:06 AM |
