| MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() | | #81 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to dougefresh_ For This Useful Post: | STiKiLLa (06-27-2014) |
![]() | | #82 | ![]() |
(Thread Starter) | Not Ranked : 0 score ^Everything's not fine, lol. I bent a rod a couple weeks back, and threw this code earlier that day. It may have nothing to do with it, but it still bothers me. I talked to the dealer about it, and there's a flowchart diagnostic for the CKP sensor that they use to diagnose P0335, and I asked him to email me a copy of it. As soon as I get it, I'll post it in here.
![]() | | #83 | ![]() |
![]() Join Date: Mar 2008 Location: Jacksonville, NC
Rep Power: 2469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 810
Groans: 60
| Not Ranked : 0 score ![]() ![]()
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks |
| The Following 5 Users Say Thank You to SSinstaller For This Useful Post: | crazyp (01-17-2012), djuosnteisn (10-11-2012), dougefresh_ (01-17-2012), meicalnissyen (07-10-2012), Tokay444 (01-17-2012) |
![]() | | #84 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well my car is up and running, but I'm throwing this damn code again, but now every mile. The car runs fine... there may be some metal bits in my oil after honing or from the piston scraping the cylinder wall after it bent. I'm just going to deal with it for now, and then after I change my oil at 500 miles, see if it improves any. If it's just as bad, I may bring it to the dealer and have them fix it under warranty. I just hate having a cel light up, in case another pops up, I'd have no idea. So that kinda sucks, especially considering we tore down the motor and reassembled everything this weekend, lol.
![]() | | #85 | ![]() |
| Not Ranked : 0 score I just started throwing this code after installing the JBR 3.5" intake. I have no other symptoms. I relocated the ECU so I'll run thru the multimeter checks, but my suspicion is this is a grounding issue, that something is spoofing the MAF to spike enough voltage to read 2g/s after which the ECU looks for the CKP sensor and doesn't see it and throws the code.
| The Following User Says Thank You to Ziggo For This Useful Post: | atvfreek (07-10-2012) |
![]() | | #86 | ![]() |
| Not Ranked : 0 score I verified all the electrical connections last night. I don't have a milli-ohm meter or a scope so I can't evaluate the quality of the ground, but I realized I don't really have to since I can directly log MAF voltage. So what I did this morning was log the MAF voltage with the key on, engine off and engine cold at hot idle and with the key on engine off at hot. I can't look at the logs till this evening as my laptop is currently dead, but the live data showed both KOEO measurements at .7-.8V and the warm idle (950 rpm) a/c off @ 1V What does this mean? It means that all cells of the MAFCAL up to ~.9V should be zero. I will look at my tune tonight, but I believe I have a couple cells in the .7-.9V range that are greater than 2g/s, which means that the ECU is expecting to see the CKP sensor responding before the engine is started. The larger the MAF, and the higher % of scaling done for e85 will make this problem more apparent. Note: all MAFs should baseline at the same voltage, but your idle voltage will vary based on the MAF size. If your MAF gets so large that the idle voltage is on top of the base voltage, you are going to have to raise the idle till it gets above the base voltage. Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk Last edited by Ziggo; 07-10-2012 at 07:53 AM. |
| The Following 15 Users Say Thank You to Ziggo For This Useful Post: | 802MS3 (06-03-2013), altaprecision (04-28-2016), atvfreek (07-10-2012), Cheapspeed (03-02-2018), djuosnteisn (10-11-2012), dougefresh_ (07-10-2012), Enki (11-01-2013), fooqr (07-10-2012), JBR (07-10-2012), JMEngineer (05-01-2015), JSmith (09-29-2014), MD1032 (09-08-2015), qkrthnu2 (01-22-2015), snailD (03-31-2013), Tokay444 (07-10-2012) |
![]() | | #87 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score @dougefresh_ I think ziggo has this figured out. It makes perfect sense. Especially since you are running a 4" intake and have scaled your maf even further for the intake leak you have. This is an easy adjustment to try.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 3 Users Say Thank You to atvfreek For This Useful Post: |
![]() | | #88 | ![]() |
| Not Ranked : 0 score @Ziggo here is a scaled maf curve for the JBR. Good call man. This is from .31-.9v... With a normally scaled maf, the .35v is only .2 or so. Code: 0.00 0.04 0.05 0.11 0.16 0.25 0.34 0.48 0.59 0.76 0.91 1.10 1.32 1.55 1.80 2.06
| The Following 5 Users Say Thank You to atvfreek For This Useful Post: | djuosnteisn (10-11-2012), dougefresh_ (07-10-2012), JBR (07-10-2012), Tokay444 (07-10-2012), Ziggo (07-10-2012) |
![]() | | #89 | ![]() |
| Not Ranked : 0 score I am scaled up another 22.5% to compensate for my e85 mix as well. Zigatapatalka
| The Following 4 Users Say Thank You to Ziggo For This Useful Post: |
![]() | | #90 | ![]() |
![]() Join Date: Jun 2010 Location: corpus christ, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,316
Groans: 68
Groaned at 22 Times in 9 Posts
| Not Ranked : 0 score I havent had this code pop up in months now. Would cooler air make the maf fluctuate also? Thats when I use to the the code once a week, when it was cooler or very humid out
__________________ 2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC |
| The Following User Says Thank You to crazyp For This Useful Post: | dougefresh_ (07-10-2012) |
![]() | | #91 | ![]() |
The MAF sensor just detects how much cooling a resistor is getting. Denser, cooler air will cool the resistor more even with the car off. Will have to revisit this when it's cold out and see how much of a difference it makes. It's why I took KOEO measurements with the car cold and hot, but I don't know if there will be enough variance in temperature to show the effect. Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
| The Following 6 Users Say Thank You to Ziggo For This Useful Post: | atvfreek (07-10-2012), crazyp (07-10-2012), djuosnteisn (10-11-2012), dougefresh_ (07-10-2012), JBR (07-10-2012), Tokay444 (07-10-2012) |
![]() | | #92 | ![]() |
| Not Ranked : 0 score Attached are a few logs. With the baseline maf voltage at .67 it shouldn't cause the MAF to report >2g/s but I am going to give the following edit a try anyway. ![]()
| The Following 5 Users Say Thank You to Ziggo For This Useful Post: | djuosnteisn (10-11-2012), dougefresh_ (07-10-2012), fooqr (07-10-2012), JBR (07-10-2012), qkrthnu2 (01-22-2015) |
![]() | | #93 | ![]() |
| Not Ranked : 0 score 2 days, 6 key cycles, and no CELs thrown yet. Before it was happening every other key cycle or so. Since I am not a post whore I won't keep posting updates unless it happens again, so assume the fix works unless you hear otherwise.
| The Following 6 Users Say Thank You to Ziggo For This Useful Post: | atvfreek (07-12-2012), dantes5823 (07-25-2012), djuosnteisn (10-11-2012), dougefresh_ (07-12-2012), Plimmer (06-28-2014), Tokay444 (07-12-2012) |
![]() | | #94 | ![]() |
![]() Join Date: Feb 2011 Location: Irvine,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 346
| Not Ranked : 0 score Just threw p0335 and p0245, I'm in same intake. I'm going to try this
__________________ 2010 ms3-sold ww evo x -385/360 |
![]() | | #95 | ![]() |
(Thread Starter) | Not Ranked : 0 score I zeroed out my maf a/b from 0-.9v, and haven't thrown this cunt code since (~200 miles). Thanks again @Ziggo!
| The Following 5 Users Say Thank You to dougefresh_ For This Useful Post: | altaprecision (04-28-2016), atvfreek (08-05-2012), JMEngineer (05-01-2015), rfinkle2 (02-02-2013), Ziggo (12-17-2012) |
![]() | | #96 | ![]() |
Groans: 793
| Not Ranked : 0 score And brown.
| The Following User Says Thank You to Tokay444 For This Useful Post: | dougefresh_ (08-05-2012) |
![]() | | #97 | ![]() |
![]() | | #98 | ![]() |
Groans: 793
| Not Ranked : 0 score I know all's aboot that.
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | dougefresh_ (08-05-2012), rfinkle2 (02-02-2013) |
![]() | | #99 | ![]() |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Not Ranked : 0 score Ok, gonna have to dig this thread up because my car is having some serious problems. Went to the track Friday night to just get some 4th gear datalogs in, did about 4 pulls that night, and last pull of the night the car just went haywire. Basically, I made it through the run ok, but in the return lane my AFR's went into the 8's - 9's and the car cant make it over 5 mph without spitting and sputtering. I reflashed another map, but it didn't help. Towed the car home and started trying a few different things: 1. Fuel pressure was dropping with a warm car, engine off, so I figured the rail valve was busted. Swapped it, nothing. 2. Figured maybe an injector was stuck since the fuel pressure was dropping, and I already swapped rail valves and the pressure can only leave the rail one of two places. Checked spark plugs and they're all fouled. 3. Got a datalog and realized car is idling at 1.5v - 1.9v which explains my stupid rich condition, and car threw the po335 (CKP circuit whatever) code. 4. replaced MAF and flashed another map in for shits and giggles and the AFR's were stable and MAF volts were 1.1 just like they were supposed to be, fucking sweet! Touch the gas pedal and the car bucks, sputters and we're right back to a 9.1 AFR -_- 5. Figured maybe throttle clip was busted, because the car was very sluggish to react to throttle input (likely due to stupid Rich AFR's) but after swapping throttle bodies (im sure you've noticed all my friends drive mazdas by now) its still doing the same shit. Basically the only thing I can think to do is pull the CKP and clean it but I have no idea where it is, or where to even start looking if that doesn't fix anything. Basically I know the MAF is the culprit ... I just don't know why, so any help would be greatly appreciated. Thanks.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
![]() | | #100 | ![]() |
The ckp is external to the engine and is right at the crank pulley.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following User Says Thank You to atvfreek For This Useful Post: | helmetface (06-02-2013) |
![]() | | #101 | ![]() |
@Tokay444; I believe you said ignition should be 10* Stock? In my datalog it was like -1, -2* and the car was idling at .7, .8, almost .9 load. I cant say ive ever logged idle for anything other than MAF cal so I only looked at those regions, do these parameters seem crazy out of whack and point to anything?
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. Last edited by Voltwings; 06-02-2013 at 07:40 PM. | |
![]() | | #102 | ![]() |
| Not Ranked : 0 score Sorry, I don't know how to add this Datalog to my previous post.
![]() | | #103 | ![]() |
Groans: 793
| Not Ranked : 0 score Yeah you should be idling at 9-11* ignition. What are your trims? The ckp a magnet, so it's possible it's picked up some shavings.
| The Following User Says Thank You to Tokay444 For This Useful Post: | Voltwings (06-02-2013) |
![]() | | #104 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score Ok, lets go down this road...it slipped timing or the sensor is misaligned because it loosened up, or it has metal shavings stuck to it....to fix this type of issue, you would need the timing tools right? Based on this thread it appears that you cannot simply uninstall the sensor, clean it, as you need to properly align it and air gap it right?
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #105 | ![]() |
Its been suggested my car jumped timing, as my logged values do not reflect my commanded values, however, in my mind if you mechanically skip 1* you should always be off by 1* right? Not so in my case if that's what actually happened, compare my logged vs commanded for idle and free revving. Idle (note, idle load is higher than free revving??) ![]() Free rev
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
![]() | | #106 | ![]() |
| Not Ranked : 0 score Here is the information in the factory manual concerning removing the sensor, installing a new one, and inspecting the sensor.
| The Following User Says Thank You to mrmonk7663 For This Useful Post: | Voltwings (06-02-2013) |
![]() | | #107 | ![]() |
Groans: 793
| Not Ranked : 0 score Look into primary o2, though it doesn't entirely explain the p0335.
![]() | | #108 | ![]() |
| Not Ranked : 0 score MAF voltage is reading too high. It explains all the other problems so until you sort that out don't go bothering anything else. Zigatapatalka
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | djuosnteisn (06-03-2013), rigor (06-03-2013) |
![]() | | #109 | ![]() |
Groans: 79
| Not Ranked : 0 score Idle spark advance won't be on target unless the car is idling smoothly. If your MAF is all haywire, and AFRs are in the 9's... the spark advance is pretty much worthless. My guess is a grounding issue probably. Or a weak battery or something. Crazy things happen when the battery is near dead.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | Voltwings (06-03-2013) |
![]() | | #110 | ![]() |
![]() Join Date: Feb 2011 Location: Nellis AFB , NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 336
Groaned at 92 Times in 11 Posts
| Not Ranked : 0 score Dude, im not gonna lie here, and I could be very well wrong, however. I just looked at your log and this is the same EXACT fucking BULLSHIT i just went though about 2 months ago. I had never tossed a code or had a single damn problem with my car. I drove it to work, typical day, car sat in the lot all day. I get out to my car 9 hours later, start it, and for no goddamn reason , my AFRs are stuck at 8.XX , STFT pegged at -25, and the car is trying its hardest not to drown itself in gas and stall. I didnt let it sit around long enough to throw any codes however. Car was bucking like a fuckin bronco.... I got home, RE-flashed my tune, and the problem seemed to go away. But it came back about a day later. Only thing i could think of was that maybe i had gotten a batch of leaded 110 instead of 104 ( i mix race gas, its my solution to alaskan pump 90), and that maybe my 02 sensor had had enough, so i bought another one through rock auto for 101 bucks shipped. Problem free since. Trims are normal as can be, however, i do notice that sometimes by STFT will go from a high negative value, then jump completely opposite to the same value, only positive. It does it every so often, but AFRs are spot on, and the car runs normally. I dont know what caused it to be honest, but your log is IDENTICAL to mine. Same timing, same AFR's, everything. It cant be coincedental... * edit, i did pull the MAF and clean the shit out of that thing as well. *And my Densos were pretty much fried as well.
__________________ --Cobb Sri--Cobb Tip--Cobb Airbox--Cobb Fmic--Cobb Bpv--Cobb Turbo-back----Cobb V3 Ap--Cobb Rmm--Jbr Pmm--Jbr Tmm--Cobb Sts----6510's--Autotech's--KW V2'S--Jbr Fsb--Jbr Rsb--STOPTECH Sport Kit--E30 FREEKTuned -- |
| The Following User Says Thank You to x09MS3GT For This Useful Post: | Voltwings (06-03-2013) |
![]() | | #111 | ![]() |
Groans: 793
| Not Ranked : 0 score Check wiring harness isn't rubbing on tip/intake clamp.
![]() | | #112 | ![]() |
| Not Ranked : 0 score His O2 sensor wiring harness rubs up against the EWG...he has a piece of heat wrap on it...think that over time the heat got to the wires and messed them up or shorted out the sensor?
![]() | | #113 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score purge valve messing up causes super rich at idle i just pulled mine off sprayed some light lube in it, and that was 40000 miles ago ,still working great ill post a vid in a minute
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan Last edited by rigor; 06-03-2013 at 07:51 PM. |
![]() | | #114 | ![]() |
Groans: 40
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
| The Following 3 Users Say Thank You to rigor For This Useful Post: |
![]() | | #115 | ![]() |
(Thread Starter) | Not Ranked : 0 score As a minor update, I've never thrown P0335 since doing the maf adjustment that @Ziggo; suggested a ways back.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to dougefresh_ For This Useful Post: | rigor (06-03-2013) |
![]() | | #116 | ![]() |
Groans: 40
| Not Ranked : 0 score ya that definitely sets the crank code for some reason ![]() and while the purge valve is out, give it a good suck / blow to attempt to free it, or tap it on one end than the other....
![]() | | #117 | ![]() |
| Not Ranked : 0 score thanks.
| The Following User Says Thank You to Voltwings For This Useful Post: | rigor (06-03-2013) |
![]() | | #118 | ![]() |
| Not Ranked : 0 score Good news, cleaning the purge valve seems to have corrected the idle, back to 1.1 volts as it should be, bad news is any throttle input at all bogs the car so I am now going to attempt cleaning the CKP.
| The Following User Says Thank You to Voltwings For This Useful Post: | rigor (06-04-2013) |
![]() | | #119 | ![]() |
Groans: 793
| Not Ranked : 0 score Primary o2.
![]() | | #120 | ![]() |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
| Not Ranked : 0 score Subbed to read later because I'm throw this too Sent from my XT907 using Tapatalk 2
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f293/p0335-crank-position-sensor-circuit-malfunction-95282/ | ||||
| p0335 crankshaft position sensor a circuit malfunction l5 - Answers Search | This thread | Refback | 04-16-2014 10:04 PM | |
| need a how to on setting tdc to replace crank sensor | turd burglar | MazdaSpeed 3 - How-To's | 7 | 12-22-2015 11:09 PM |
| where is the Throttle Position Sensor? | vballbwing | MazdaSpeed 6 - Engine, Transmission & Driveline | 4 | 10-06-2011 10:05 AM |
| Clutch pedal position sensor | DISITRB | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 06-11-2010 10:31 PM |
| Does anyone know where to find the Camshaft position sensor!!! | gt5 | MazdaSpeed 6 - Engine, Transmission & Driveline | 9 | 02-28-2010 07:36 PM |
| Camshaft Position Sensor Retarding | dukebrown | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 08-01-2009 01:06 AM |
