 Old 01-13-2020, 12:56 AM   #1
Rh2racing's Avatar
Posts: 5   (View Stats)
Rh2racing can only hope to improve
Groaned at 4 Times in 1 Post
Default P2006 Cel ok to bypass?
Ok so with the cel p2006 intake tumblers stuck closed, is it ok to rig it si they are always open? I know some people delete them. Mine is a different issue. The screw holding the plunger broke off in the threads. I think the previous owner was monkeying around with it. Would it be ok to just rig it so it's always open? I understand it may trigger a p2007or something but I'm trying to get my speed back to running. I'll deal with that later.
Rh2racing is offline   Reply With Quote
 Old 01-13-2020, 06:40 AM   #2
Jeff23spl's Avatar
Posts: 2,198   (View Stats)
as a temporary option, you can just attach them open for now and drill the broken screw later....
the vtcs close half of the intake path at low rpm, i read it would increase low end torque. When it is stuck close i did experience a lost in max power but never tried to force them open.... Many run without them when they are in need of more intake flow with large turbos....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 01-13-2020, 10:46 AM   #3
Rh2racing's Avatar
The part that goes down that the sensor rides on, is that the actuator that holds the vtcs open? (Where the arm is)
 Old 01-13-2020, 02:17 PM   #4
Police - Grammarhead
Vansquish's Avatar
Groans: 1,910
The pale green doohickey with the plastic plunger arm is the VTCS actuator (the thing that moves the arm of the VTCS flapper).
Jeff23spl (01-16-2020)
 Old 01-16-2020, 06:29 AM   #5
Jeff23spl's Avatar
https://images-na.ssl-images-amazon....N1tPL._AC_.jpg
this is the actuator but after a second look, i think the bad screw just hold the limit switch feedback that tell the ecm if the vtcs are open or closed. you could even drill a third screw in the middle if you cannot get the other one out, it doesn't take much clamping force to keep it there....
http://i.imgur.com/eRmseV5.jpg
Wife drive 2010 CX7
Vansquish (01-16-2020)
 Old 01-16-2020, 06:40 AM   #6
Vansquish's Avatar
Groans: 1,910
You have a couple of options. You can either drill out the screw and re-mount the limit switch bracket (and the switch) using that first hole, or use the secondary screw hole (in the foreground of your picture) to mount the limit switch without using the first hole at all.
Here's a post in a thread about fixing P2006 on our cars.
Now what..P2006
And here is a whole thread with excellent and detailed pictures showing you how to fix your issue.
How To: Fix CEL P2006
How To: Fix CEL P2006 kdotspeed MazdaSpeed 3 - How-To's 39 06-11-2019 11:32 AM
Now what..P2006 LemonWrath MazdaSpeed 3/6 - Troubleshoot/Diagnostics 31 11-01-2017 07:32 PM
MS6 P2006 CEL just came on tmaiorca MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 12-28-2015 02:49 PM
P2006 CEL on Azlander MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 10-25-2013 09:33 AM
CEL On- P2006 supracelica32 MazdaSpeed 6 - Engine, Transmission & Driveline 6 03-23-2010 05:41 AM
Page generated in 0.26567 seconds with 23 queries
