 Old 08-28-2019, 12:36 PM   #1
bkxtrakrisspy's Avatar
Posts: 10   (View Stats)
bkxtrakrisspy is an unknown quantity at this point
Default P2188 help
I've been fighting with this code for months now. I've replaced/cleaned just about everything on the car that the forum has suggested to change except the fuel injector seals. All clamps are tight and everything visually looks in good shape.
It's an 06 MS6 with 176k and full stock motor. It will turn on randomly while driving around and almost every time after I get gas. The car runs great and has no sputters under load, but it will drop to ~500 RPM at idle randomly but its very rare that it does this.
I took these screen shots only 70 miles after pulling the negative battery cable to reset the computer. Could it possibly be an 02 sensor? Will getting the injectors professionally cleaned help? Any suggestions at all will be greatly appreciated.
bkxtrakrisspy is offline   Reply With Quote
 Old 08-28-2019, 01:37 PM   #2
Police - Grammarhead
Vansquish's Avatar
Groans: 1,909
Are you sure that the car is entirely stock and healthy? Do you have an aftermarket intake? Do you have an aftermarket bypass or blowoff valve?
If the car is rich at idle, that suggests a possible post MAF (probably post turbo) leak of some sort and/or an O2 sensor issue and/or a purge valve issue.
 Old 08-29-2019, 03:26 PM   #3
Yea its stock. I replaced the purge valve about two months ago, cleaned the MAF, and replaced the spark plugs, but the CEL proceeds those replacements. Although the MAF is secure and not move-able, the screws holding it down are not super tight when attached to the air box. I feel like they could be stripped since it is just plastic.
I'll dig in there again and check if anything is loose or a possible tear/pinhole leak somewhere. Thank you for giving me a little bit of direction to where the leak could be instead of me wasting time looking in the wrong places.
 Old 08-29-2019, 03:56 PM   #4
Db09ms3's Avatar
Posts: 530   (View Stats)
Db09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the world
Groans: 103
Any exhaust leaks or TIP coming loose off the turbo? MAF O-ring torn? Any tune-up?
Stockish
Db09ms3 is online now   Reply With Quote
 Old 09-17-2019, 11:22 AM   #5
I've checked there too and nothing that I can see. I need to do a boost leak test but I don't have a compressor. It seems possible with a bike pump, but I haven't gotten to it yet.
I went driving around last night and was watching the numbers. Cruising was +8.5~ and idle was around +12. The cel is currently gone, and it frequently comes and goes. Like it will be on for 3-4 days then off for 2 weeks.
It did the idle dip to sub 500 rpm last night, I thought it was going to stall for a second.
 Old 09-18-2019, 03:08 AM   #6
Again today was cruising around running errands. Ltft Idle was 3.9 and cruisin was 7.9. is it supposed to bounce around this much? I know it depends on the temperature, and it's cooling off here in Vegas pretty quickly.
P2188 CEL. Bad O2 Sensor? GuilteeConscience MazdaSpeed 3/6 - Troubleshoot/Diagnostics 22 06-16-2017 05:30 PM
P2188/P0401 BlackBettyMS6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 12-04-2013 08:22 PM
got p2188 haskms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 02-27-2012 10:39 AM
P2188 Kydizzle MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 03-12-2011 09:11 PM
Page generated in 0.43466 seconds with 23 queries
