Like Tree4Likes
 Old 04-04-2011, 09:55 PM   #1
cbspeed3's Avatar
Posts: 203   (View Stats)
cbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond reputecbspeed3 has a reputation beyond repute
Default Part throttle knock question???
I am getting 6.0 part throttle knock when cruising and very slightly letting off the throttle. If I let off throttle completely it goes to 0.0. If I hold the throttle steady when it starts to get knock retard it slowly goes to 0.0, but if I let off slightly it goes to 6.0 again. If I go wot even if it's reading 6.0 kr it goes to 0.0 instantly. Just wanted to know if anyone else has seen this and is it the normal pt knock I've read about. I never get more than 0.7 to 1.0 of kr at wot.Needed you guys input. I've been monitoring things since I changed timing chain and tensioner. Tryin to see if this is the norm
knarfies likes this.
cbspeed3 is offline   Reply With Quote
The Following User Says Thank You to cbspeed3 For This Useful Post:
knarfies (03-16-2012)
 Old 04-05-2011, 03:40 AM   #2
bova's Avatar
Posts: 3,815   (View Stats)
Groans: 45
forget about it, it's perfectly normal at part throttle. its just the car adjusting timing for mpg's.
search there are plenty of threads like this.
Worbit likes this.
The Following 3 Users Say Thank You to bova For This Useful Post:
knarfies (03-16-2012), laxplayermjd (04-05-2011), Marchy (09-13-2012)
 Old 04-05-2011, 05:56 AM   #3
cbspeed3's Avatar
Thanks! That's what I found searching the forum. Just like to hear it from fellow msf members. Lot of you all have much more knowledge about the idiosyncrocies of this little fagwagon than I. I knew some pt knock was normal but wasn't sure how much,cause I didn't start monitoring till my timing chain slack was causing a shit ton of audible kr and stuttering, so I have never seen what the kr is suppose to actually be doing.
 Old 04-05-2011, 08:38 AM   #4
laxplayermjd's Avatar
Posts: 779   (View Stats)
laxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the world
its been posted about numerous times, theres debate on if it false knock or true knock. ive tried adjusted timing which never got it to go away. its completey random when it occurs.
I only worry when its large amounts like 6-7 degrees. Make me wonder. inthe mean time i just let off the gas when it does it then get back on
2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune
laxplayermjd is offline   Reply With Quote
 Old 04-05-2011, 08:52 AM   #5
bova's Avatar
Groans: 45
there is no need to let off and the reason why changing timing does nothing cause the ecu still wants to maximize timing for fuel efficiency until it hits that point of knock then it backs off. by letting off you don't let the ecu learn that timing at part throttle so it will just continue the process. this is why I stopped monitoring knock or monitoring at all unless i'm really beating on the car.
4G63 (04-05-2011)
 Old 04-05-2011, 08:54 AM   #6
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
FORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the world
Sounds like the OP has something loose under the hood.
`07 Speed6 Sport Tit Gray Sleeper Express... SOLD
`11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG
`12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan
`12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket
`17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy
FORZDA 1 is offline   Reply With Quote
The Following User Says Thank You to FORZDA 1 For This Useful Post:
AtTheDriveIn (04-07-2011)
 Old 04-05-2011, 11:19 AM   #7
cbspeed3's Avatar
Nothing loose. Checked everything more than a few times. If I'm at a constant cruz it doesn't get kr. Only does it when I let off throttle from a steady Cruz. Like when you top a hill and have to let off a little to maintain your speed, it goes to 6.0 kr and drops to 0.0 kr over the next 5 to 6 seconds. I thought it was random at first but the more I studied it I saw the pattern. I can almost make it knock on command by modulating the throttle like I explained above. Just curious if you guys get the same shit.
 Old 04-05-2011, 11:30 AM   #8
[MSF STIG]
FORZDA 1's Avatar
Originally Posted by cbspeed3 View Post
.... I can almost make it knock on command by modulating the throttle like I explained above. Just curious if you guys get the same shit.
Uhm, no.... If you are SURE there is nothing vibrating (resonant frequency, not flopping loose) then you may be running real lean at part throttle.
A few deg of KR once in a while (not at WOT) is fairly normal, but 5-6 sounds a bit excessive to me.
 Old 04-05-2011, 01:12 PM   #9
cbspeed3's Avatar
Fuel ratios look good. 14.7 for light throttle and cruzin. Goes to 0.0 kr instantly if I go wot. Never get above 1.0 kr at wot. Only wit the slight depression og the pedal is when I get it. It might not be 5 to 6 second, just guessing. It goes down by increments. 6.0, 5.0, 3.5, 2.8,........ Till it hits zero. I will not get kr again unless I let of the pedal just a bit, it's like a kr sweet spot. Fuel trims are within +\-7%. The only lean I ever see is when I punch the gas hard I will get 15.0 for a split second and then the afr drops like it should and I don't get any knock during acceleration.
 Old 04-05-2011, 04:02 PM   #10
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,157   (View Stats)
Groans: 792
When cruising the engine will start at 6 degrees of knock retard and count backward to zero. This is not the engine knocking. It is the ecu maximizing spark timing. Knock is audible.
jreiden1 (09-18-2014), radbrad (09-09-2012)
 Old 04-05-2011, 07:10 PM   #11
cbspeed3's Avatar
Ok I toke you fellas advice and started to look for loose shit under hood. Didn't find anything so I looked deeper since I just replaced timing chain and tensioner I pulled the valve cover just to take a look. Everything looked good and right when I was bout to button everything up I noticed the vvt solenoid was loose, the 10pm bolt that holds it down was backed out about 1/8 inch or so. Tightened it down and put it back together. First thing I noticed is my ltft's went from-6.0 to 1.3 at idle and all other break points started to change as well. And the pt kr is much better. I will check back in after a few more miles to let it continue to relearn. But I think that was the issue. Funny cause I never touched that bolt before today
The Following 2 Users Say Thank You to cbspeed3 For This Useful Post:
FORZDA 1 (04-06-2011), MPSdriver (03-10-2012)
 Old 04-06-2011, 02:46 AM   #12
Tokay444's Avatar
Groans: 792
Sweet. But the ecu is programmed to count backwards from 6 degrees of knock retard to zero at part throttle cruising to maximize efficiency. Good find though. Probably aided in preventing some other kind of catastrophic failure.
 Old 04-06-2011, 05:20 AM   #13
cbspeed3's Avatar
Yeah, I'm sure a bolt bouncing around in the valve train wouldn't be too good
 Old 04-06-2011, 02:32 PM   #14
[MSF STIG]
FORZDA 1's Avatar
Told ya so! Nah Nah Na Nah Nah! I've found many of the PT KR issues are indeed "false". There are many things under the hood that can buzz/rattle at various resonant freqs and be heard by the knock sensor...
 Old 04-06-2011, 04:19 PM   #15
Tokay444's Avatar
Groans: 792
Not to be rude, but I bet he'll still get 6 degrees of timing retard counting down to zero at part throttle cruising. It's just what the ecu does.
The Following 5 Users Say Thank You to Tokay444 For This Useful Post:
Ckmazdaspeed3 (04-06-2011), DoMiNic (07-24-2013), jreiden1 (09-18-2014), manelscout4life (04-06-2011), SofaKingAwesome (02-08-2012)
 Old 04-06-2011, 07:02 PM   #16
[MSF STIG]
FORZDA 1's Avatar
Not being rude either, but whadda you wanna bet? 6 deg of KR is NOT "normal".
The Following 3 Users Say Thank You to FORZDA 1 For This Useful Post:
I Love Brownies (04-06-2011), SIXual Panda (04-07-2011), Toddy22587 (04-07-2011)
 Old 04-06-2011, 07:21 PM   #17
I Love Brownies's Avatar
Posts: 3,791   (View Stats)
I Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the world
Groans: 371
Groaned at 62 Times in 39 Posts
+1^^^^^
I Love Brownies is offline   Reply With Quote
 Old 04-06-2011, 10:03 PM   #18
cbspeed3's Avatar
Yes I still get 6.0 pt kr, but it counts down almost instantly and it doesnt do it as much as before. My ltft's went from -5.5 at idle to -1.6, fuel trims at all the other break points got closer to zero as well. I think the solenoid for vvt was so lose it wasn't adjusting timing correctly. Got the same wacky fuel trims when vvt and timing chain was bad on my car. Thanks everyone
 Old 04-07-2011, 03:04 AM   #19
Tokay444's Avatar
Groans: 792
I have a completely stock motor on a stock tune, and when cruising on the highway, my dashhawk routinely displays 6-5-4-3-2-1-0 in the knock retard field. It's not knock. It's timing being pulled by the ecu for fuel maximization and a lot of people know about it. It's not that your car is knocking. The sensor isn't hearing any knock at all most likely. It's just what the ecu does to save you gas. But I digress.
DoMiNic likes this.
 Old 04-07-2011, 05:40 AM   #20
cbspeed3's Avatar
You could be right, it is labeled knock ratard. It could just be the ecu pulling timing. Will we ever really know if it's knock or timing being pulled to prevent knock?????
 Old 04-07-2011, 05:46 AM   #21
bova's Avatar
Groans: 45
if you actually had knock that high you would hear it
The Following 2 Users Say Thank You to bova For This Useful Post:
SofaKingAwesome (02-08-2012), Tokay444 (04-07-2011)
 Old 04-07-2011, 05:57 AM   #22
Tokay444's Avatar
Groans: 792
I thought that it was common knowledge that the ecu pulls timing like this at cruising between 2800 and 4500 rpm to maximize economy.
 Old 04-07-2011, 08:06 AM   #23
[MSF STIG]
FORZDA 1's Avatar
I have a completely stock motor on a stock tune.....
I'm going to step out of this thread and leave you guys to yourselves. I should have known better.
 Old 04-07-2011, 08:17 AM   #24
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
A great way to solve this issue is to log kr, closed loop etc, and compare logs @ light load and part throttle conditions.
 Old 04-07-2011, 08:23 AM   #25
Toddy22587's Avatar
Posts: 41   (View Stats)
Toddy22587 is a splendid one to beholdToddy22587 is a splendid one to beholdToddy22587 is a splendid one to beholdToddy22587 is a splendid one to beholdToddy22587 is a splendid one to beholdToddy22587 is a splendid one to beholdToddy22587 is a splendid one to beholdToddy22587 is a splendid one to behold
My dashhawk is on and monitoring knock every time i drive and i've never seen this backwards count from 6. maybe the australian ECU is different
Toddy22587 is offline   Reply With Quote
 Old 04-07-2011, 08:27 AM   #26
Tokay444's Avatar
Groans: 792
Cruise steady at 120km/h in sixth for about ten minutes and watch it.
 Old 04-07-2011, 08:30 AM   #27
rfinkle2's Avatar
Groans: 298
See @Tokay444 's post above.
 Old 04-07-2011, 01:00 PM   #28
cbspeed3's Avatar
The only audible knock I have heard is when timing chain and vvt was bad and it registered 8.0 on my dashhawk. And this happened several times and it was always 8.0. So you may not hear 6.0 kr.
Arpitbull likes this.
 Old 04-07-2011, 01:07 PM   #29
cbspeed3's Avatar
I think the ecu advances timing, to increase fuel economy, until it detects knock, then it pulls timing back. It rides the edge of the knock threshold for fuel economy. I knew this before I made this thread. I was just curious if other people was seeing it (kr) as I described, the count backward from 6 to 0.
Just paranoid since the timing chain vvt issues I've had.
Last edited by cbspeed3; 04-07-2011 at 01:07 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-07-2011, 01:14 PM   #30
Tokay444's Avatar
Groans: 792
I see 6 counting down to zero every time I cruise steady at about 3000 rpm. If I floor it, or let go, it goes immediately to 0.
mayer (04-05-2012)
 Old 05-28-2011, 01:10 PM   #31
Zak
Zak's Avatar
Posts: 84   (View Stats)
Zak is just really niceZak is just really niceZak is just really niceZak is just really niceZak is just really nice
UP!
When I'm getting this part throttle Knock and then going WOT, my car still knock! That's should turn back to 0° in OL, does it?
But when I WOT again, no Knock!
Do you know what cause this issue?
Zak is offline   Reply With Quote
 Old 05-28-2011, 01:19 PM   #32
Tokay444's Avatar
Groans: 792
english please.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 05-28-2011, 01:24 PM   #33
Zak
Zak's Avatar
Sorry for my bad english, I live in Europe...
 Old 12-12-2011, 07:00 AM   #34
speedms6's Avatar
Posts: 825   (View Stats)
sorry to revive, but was just doing some reading, and this is the exacttttt same tihng that happens to me, jsut good knowing its normal
 Old 12-19-2011, 10:38 AM   #35
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
I wanted to add to this thread. I am with the theory that PT kr is caused by too much timing advance.
I recently started increasing low load timing to improve mpg which resulted in high counts of pt kr.
 Old 12-19-2011, 11:03 AM   #36
if that is the case. We would have to pull up to 6 degrees timing in low loads,And determine if when it occurs its only use the CL timing table. Could be using the part throttle timing.
It seems everything i try to catch it in a log it never happens.
Edit: it occured quite a bit on me on my trip to ny for the holiday, it only seemed to occur before reaching full operating temp, usually around 170 from what i could tell by monitoring the dashhawk. Almost did it everytime i hit the on ramp after a nap. Ive noticed it most commonly just before full operating temp on my ways to work in the morning. And it does not occur in the summer months for me. I feel its related to ambient temps, and coolant temps, as well as possible timing
 Old 12-19-2011, 11:12 AM   #37
Tokay444's Avatar
Groans: 792
I have cruise know for almost my entire drive to work every moning.
3200rpm in 6th.
Just repeats the backward count from 6 every kilometer or so.
Sometimes it doesn't start as high as 6, and sometimes it doesn't get to zero before it jumps back up and starts counting down again.
I only see low events of WOT kr with 91 octane and never any WOT kr with 94.
Demodded.
The Seals
Docnox (12-20-2011)
 Old 12-19-2011, 01:48 PM   #38
strange because i never get it while on cruise control. its always shortly after a shift in higher guys, withing 5 secs of a shift when slowly on the gas.
i cruised at that for about 4 hrs at a time the other day with not one once of knock.
 Old 12-19-2011, 06:41 PM   #39
Tokay444's Avatar
Groans: 792
I have never once turned cruise control on.
Demodded.
The Seals
 Old 12-19-2011, 06:51 PM   #40
ABSpeed3's Avatar
Posts: 698   (View Stats)
ABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the world
Groans: 133
Groaned at 7 Times in 4 Posts
I have never seen that level of PT knock in 6th gear cruising. I have probably driven 500 highway miles in the past week, and my AP was monitoring knock the whole time. I never witnessed the backwards countdown Tokay mentions.
08.5 CWP MS3 GT
PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC
ABSpeed3 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f293/part-throttle-knock-question-76934/
Ticking from motor. Help please This thread Refback 07-24-2013 10:36 AM
HOW TO: Eliminate Part-Throttle Knock Completely and Forever! aaronc7
Cobb ATR Support
7 07-18-2009 08:09 PM
Part Throttle Knock.. Silver Ecstasy MazdaSpeed 3/6 - ECU Computer Tuning 10 06-23-2009 11:34 PM
Part throttle knock solutions? dread
Cobb ATR Support
22 05-09-2009 06:47 AM
Part Throttle knock spikes tunersteve MazdaSpeed 6 - Engine, Transmission & Driveline 15 04-29-2009 11:19 AM
Knock at part throttle! SLOMS3 MazdaSpeed 3/6 - ECU Computer Tuning 7 04-13-2009 10:00 AM
Page generated in 0.55283 seconds with 31 queries
