 Old 06-27-2016, 02:54 PM   #1
Mitchell's Avatar
Posts: 2   (View Stats)
Mitchell is an unknown quantity at this point
Default Periodic Clunking noise at Idle
My speed3 has been making a strange clunking noise periodically at idle. The noise can be heard during both cold starts and after long trips. is this a familiar noise to anyone, the car seems to be driving fine but I'm getting increasingly worried.
The clunk can be heard at around 22 seconds in and just before the 1 minute mark on the video. Thanks again for the help.
Mitchell is offline   Reply With Quote
 Old 06-27-2016, 07:49 PM   #2
g00s3y's Avatar
Posts: 2,128   (View Stats)
Groans: 439
Mods? Mileage? Any other issues?
I would take the valve cover off and inspect, take some pictures, sounds a bit like the chain hitting the valve cover. Not really sure though.
 Old 06-27-2016, 08:00 PM   #3
Mitchell's Avatar
Only mods are a mazdaspeed intake which was on before I got the car, and a CPP rear motor mount. Milage is at 150km, I've had the car for a year and bought it at 130km. Had no issues so far. Car pulls hard, engine runs well although it goes through a little bit more oil than normal.
I'm taking the car in on thursday however I wanted to get a narrowed down opinion before I took it in. Do you think I'll get bent over by going to the dealership or should i just stick to a local mechanic?
 Old 06-27-2016, 11:47 PM   #4
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Groaned at 6 Times in 6 Posts
It sounds like an AC compressor pulley. Take your phone record audio close to the A/C pulley, waterpump pulley, and tensioner pulley. The AC compressor pulley took a shit on my daily 3 and it sounded like the engine was falling apart.
You can try turning AC on/off when the noise happens there should be some change in sound.
Bad news is new AC is like close to $400. Good news is you are going to search and find a thread on how to replace the bearing for $20 and then you can donate to keep the forum alive.
Also, if you don't have a press you might be able to buy pulley with bearing pressed in and a clutch.
But first run those tests and locate where the sound is coming from. Also, here is a diagram to help you locating the specific pulleys.
If all pulleys are ok. You might need to start digging into the motor like the other poster suggested.
2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE
2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too.
Just got my car, Clunking at idle?! Mr Moose MazdaSpeed 6 - Engine, Transmission & Driveline 3 03-08-2010 04:58 AM
Clunking noise Cool Whip MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 11-06-2009 12:18 PM
Clunking noise sleeping MazdaSpeed 3 - Engine, Transmission & Driveline 5 09-21-2009 06:20 AM
Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's Haltech Automotive News 0 03-13-2009 03:30 PM
Page generated in 0.25286 seconds with 23 queries
