 Old 06-24-2016, 12:38 PM   #1
mrjoshyman's Avatar
Posts: 238   (View Stats)
mrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to behold
Default Random misfires after new plugs
Here are my engine mods:
- DP
- cat back
- BPV
- SRI
- turbo inlet
I recently got my plugs changed to the Denso ITV22 and had them gapped per Cobb's recommendations at .026” - .028” (0.66mm – 0.71mm). Since then the car has not been doing well under load. Most recently I've been misfiring and thus losing power while accelerating moderately hard -- not a good place to be when trying to merge in traffic or switch lanes. As a result I got the CEL P0300: random misfire detected.
Any idea why this would be happening with new plugs? Do you think the place I got it installed at may have improperly gapped the plugs? Would resetting the ECU by unplugging the battery help anything?
Any suggestions are much appreciated.
mrjoshyman is offline   Reply With Quote
 Old 06-24-2016, 12:40 PM   #2
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Check the plug gap yourself and make sure coil packs are seated and tightened.
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 06-24-2016, 01:09 PM   #3
Djohns's Avatar
Posts: 3,944   (View Stats)
Groans: 112
Also a fuel pressure regulator would cause a random misfire.
2010 black mica speed3
Soon:built motor
 Old 06-24-2016, 07:41 PM   #4
sheston's Avatar
Posts: 1,847   (View Stats)
I would pull the plugs and check the gaps. Also try the coil stretch mod or go for the solid copper wires.
I don't suppose you got gas somewhere different, meaning bad gas?
 Old 06-24-2016, 07:56 PM   #5
mrjoshyman's Avatar
i brought it back to the shop where they installed the plugs turned out they gapped them way off. they're buying me new plugs and installing them which is good on them at least for admitting the mess up
 Old 06-27-2016, 07:42 AM   #6
WetzMS3's Avatar
Groans: 430
Gap and swap your own plugs, prevent this nonsense.
2013 MS3 Black Mica
The Following 3 Users Say Thank You to WetzMS3 For This Useful Post:
g00s3y (06-27-2016), MS3Shadow (06-27-2016), mxlplx71 (06-27-2016)
 Old 06-27-2016, 07:57 AM   #7
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Run stock heat range plugs, you don't need colder ones
Blue Pu.
 Old 06-27-2016, 09:03 AM   #8
g00s3y's Avatar
Posts: 2,128   (View Stats)
Groans: 439
Has mods, but no HPFP internals and doesn't know how to change/gap spark plugs. Then takes it to a place that can't even do said simple work correctly.
Should probably sell the car and get a Kia with a 10 year/100,000 mile warranty and no mods. Will have much less of a chance of blowing the engine.
The Following 4 Users Say Thank You to g00s3y For This Useful Post:
MS3Shadow (06-27-2016), mxlplx71 (06-27-2016), pharaoh313 (06-27-2016), WetzMS3 (06-27-2016)
cylinder misfires and KR Jaxon MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 09-03-2015 05:41 PM
CEL during road trip, random cylinder misfires? AveryPlaysBass 2010 MS3 - Engine, Transmission & Driveline 0 10-06-2014 09:06 AM
MS6 P0302 CEL, other misfires, stuttering. SirChodesly MazdaSpeed 3/6 - Troubleshoot/Diagnostics 16 08-28-2014 11:28 AM
P0300 Random / Multiple Cylinder Misfires txmedic83 CX-7 > Issues & Troubleshooting 9 08-13-2013 12:45 PM
Random misfires after compression test Dizzy Turbo MazdaSpeed 6 - Engine, Transmission & Driveline 8 12-09-2012 05:25 PM
Page generated in 0.68804 seconds with 25 queries
