 Old 05-30-2011, 10:34 PM   #1
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
Default Rev limit launch and cel
So i just set up my current tune with a 3.5k rpm 9mph launch control, went out for a drive and decided to test it, and got a cel. But the dashhawk wont read a code even after i start the car back up, just says no current trouble code. I have my egr and vcts deleted but i cancelled those codes in atr, so what gives?
NO! No way am I havin a dick made outta hamburger!
stocking out, buy my big turbo shit here, http://www.mazdaspeedforums.org/forum/f229/bye-bye-big-turbo-dreams-82241/ more to come as stock shit arrives
 Old 05-31-2011, 03:00 AM   #2
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
DH is fail at pulling codes. Use the AP to pull it. I've had several that the DH 'can't see'.
The Following User Says Thank You to dougefresh_ For This Useful Post:
turd burglar (05-31-2011)
 Old 05-31-2011, 01:48 PM   #3
Groans: 39
Fuck me, ic codes u0100(lost communication with pcm) u2064(no description) u0101 (communication error to tcm) and abs codes u2023 and u1900. Please help out, i have no clue wtf is goin on!!!
 Old 05-31-2011, 01:57 PM   #4
Spirry's Avatar
Posts: 700   (View Stats)
Spirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the world
Groans: 31
Groaned at 28 Times in 15 Posts
If you start getting crazy codes my first step is to do a static discharge. Disconnect battery cables from battery and touch negative to positive. Wait 15 min and reconnect.
Spirry is offline   Reply With Quote
The Following User Says Thank You to Spirry For This Useful Post:
 Old 05-31-2011, 01:59 PM   #5
MS33SM's Avatar
Posts: 1,821   (View Stats)
MS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the world
Groans: 132
Groaned at 166 Times in 92 Posts
Someone recently posted the U2064 code and it's a Cobb AP specific code. Search their forums
Edit: http://www.cobbforums.com/forums/sho...rown-this-code
MS33SM is offline   Reply With Quote
The Following User Says Thank You to MS33SM For This Useful Post:
 Old 05-31-2011, 02:10 PM   #6
Groans: 39
So after reading real quick, it seems the u2064 is a comms error code, which might explain the reason why the pcm comm error code and tcm comm error code popped up, so the launch just shook shit around and it couldnt communicate basically? I hate this shit!
 Old 05-31-2011, 02:38 PM   #7
4G63's Avatar
Posts: 1,479   (View Stats)
4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world
Groans: 123
Groaned at 157 Times in 79 Posts
Dude I've had those cleared em cause I didn't give a shit a lot of them have to do with the AP and they have never came back. A couple of those I believe have to do with lost/bad connection to an external device (ex: AP or DH). May be wrong but I had those and just cleared em man
2003 Evo VIII
BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever.
Old: 2009 White MS3. Fully bolted and tuned. Sold
4G63 is offline   Reply With Quote
The Following User Says Thank You to 4G63 For This Useful Post:
 Old 05-31-2011, 04:56 PM   #8
Groans: 39
now i have a constant u0100 code for failure to communicate with tpms. I flashed back to a different map to see if the other codes would go away and they have for now, but did i fuck up a tpms sensor on the launch and now its causing all this other shit?
 Old 05-31-2011, 05:29 PM   #9
Groans: 39
also, my tpms light isnt on, so i dunno wtf the deal is
 Old 05-31-2011, 05:42 PM   #10
wtf is tpms? lol
 Old 05-31-2011, 05:45 PM   #11
Groans: 39
tire pressure monitoring system. The little deals in the rims that let you know if you have low tire pressure. I dunno where the actual sending unit for each of the sensors is, or if its all tied into the ecu or how they work
 Old 05-31-2011, 08:16 PM   #12
Groans: 39
Apparently my dipstick also blew out and now there's a good couple courts of oil around my engine bay. Fuck this busted ass piece of shit!
 Old 05-31-2011, 10:26 PM   #13
Oh, my gf's ride has those sensors that give you the actual psi, and a couple have gone bad and been replaced under warranty (different car tho). Your dipstick blowing out isn't a great sign... mega crankcase pressure. That kept happening to Carlson recently, and he found oil in his tip and intake... his pcv system is completely blocked somehow... OCC is dry to the bone.
He's gonna tear it apart and see what's up. Check your tip for oil.
 Old 05-31-2011, 10:29 PM   #14
Groans: 39
I have a catch can between my valve cover and intake as well as one from my PVC. Vc catch can isn't full of oil so I think I'm fine. Either way this is the last straw. Cars gettin sold soon
 Old 05-31-2011, 10:45 PM   #15
lol @ last straw. That was me w/ my fuel pressure issues a year ago. Came close to parting out, but I'm very glad I did not. I saw your sig w/ the stuff. Empty your OCC and see if anything collects. I was saying Carlson's OCC was bone dry.... his pcv system is blocked somewhere and the pressure was blowing his dipstick out, and he was getting oil all over the place. Check your tip for oil just for kicks.
 Old 05-31-2011, 11:27 PM   #16
RayRayBauder's Avatar
Posts: 1,999   (View Stats)
RayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the world
Groans: 234
Groaned at 154 Times in 122 Posts
holy fuck man. rough car day.
'08 MazdaSpeed3 - sold
RayRayBauder is offline   Reply With Quote
 Old 05-31-2011, 11:39 PM   #17
Groans: 39
Well either the ported im or launch control made the dipstick blow out, cuz those are the only 2 things that have changed in the last week
 Old 05-31-2011, 11:44 PM   #18
oh I didn't' realize it was a one time thing. That's good.
 Old 06-01-2011, 12:01 AM   #19
Groans: 39
yup, all this shit has gone wrong in a matter of a few days, but i'm out. Maybe look for a 370 or somethin else not boosted. Cars gonna be a never ending money pit at this rate
SB software limit of 20psi? the_caruch Custom Performance Engineering (cp-e.com) 10 04-09-2011 02:07 AM
HP limit with cobb Sri maf ? jracer Mazdaspeed3/6 General Discussion 17 01-17-2011 04:06 AM
Flashing Limit? 100? Fobio
Cobb ATR Support
4 04-29-2009 07:19 PM
what is the limit??? protur03 MazdaSpeed 3 - Engine, Transmission & Driveline 4 10-18-2008 05:47 PM
Picture size limit? enganear Website Help/Feedback 6 03-21-2008 06:21 PM
Page generated in 0.37619 seconds with 25 queries
