 Old 01-11-2019, 10:35 AM   #1
Thor Hammer's Avatar
Posts: 1,845   (View Stats)
Groans: 211
Default Rough Idle/Gas Smell After Fill Up
Hey guys wanted to bounce something off you.
Starting my MS6, after putting around 5 gallons into an almost empty tank two nights ago, it barley started and struggled to stay running. Sounded like it did when my MAF went bad. After revving it lightly a few times it evened out.
However the idle drops and then bounces back up roughly when at a stop. The next morning it threw a P2187 code. One I am very familiar with.
I figure its definitely an issue with the Evap system. Likely the purge valve or float in the gas tank allowing raw fuel into the charcoal canister. Reason I say that is when I filled it up completely last night, it ran even worse for a while after starting and I could smell raw fuel. Then it idled rough and inconsistent in rpm just like before.
I ordered a new purge valve and will be looking into it this weekend. Boost leak test, vacuum leak check (AP reads -10.2 at idle) and check the ignition.
Anyone ever experience this and find the solution?
 Old 01-11-2019, 01:56 PM   #2
tegxsi's Avatar
Posts: 1,240   (View Stats)
Groans: 87
Have you done any datalogs at idle? Cruising?
2018 Audi RS3
2007 Acura TSX 6MT
 Old 01-12-2019, 03:42 AM   #3
mituc's Avatar
Posts: 3,518   (View Stats)
Groans: 111
90% the purge valve swap will fix it.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-14-2019, 09:23 AM   #4
Groans: 211
Thanks mituc. It was indeed the purge valve causing the issue. It was stuck open.
Rough idle, doesn't want to start after fill up, runs rich, vacuum leak, backfires UnamusedPunk Mazdaspeed3/6 General Discussion 14 12-28-2017 06:39 AM
My 2008 Speed 3 will not hold an idle and rides rough at low rpm and low idle Dgms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 11-23-2016 02:42 PM
hot oil smell in cabin (at Idle) Absolut1l MazdaSpeed 6 - Engine, Transmission & Driveline 21 03-16-2016 10:20 AM
sometimes rough idle....?? MSP611 MazdaSpeed 6 - Engine, Transmission & Driveline 12 07-14-2010 03:32 PM
rough idle? tbone MazdaSpeed 3/6 - Turbo Induction 13 11-11-2008 05:10 AM
Page generated in 0.25141 seconds with 22 queries
