  • 1 Post By ThomasSpeed3
 Old 12-28-2013, 08:22 PM   #1
ThomasSpeed3's Avatar
Posts: 84   (View Stats)
ThomasSpeed3 is a splendid one to beholdThomasSpeed3 is a splendid one to beholdThomasSpeed3 is a splendid one to beholdThomasSpeed3 is a splendid one to beholdThomasSpeed3 is a splendid one to beholdThomasSpeed3 is a splendid one to beholdThomasSpeed3 is a splendid one to behold
Default Rough idle/Vacuum issues
Ok so a few weeks ago my check engine light came on. I hooked up the AP read the code and it was a random misfire code P0300. I checked my coil packs, replaced spark plugs, and cleared code. couple days later it was back, only now when i start my car it hesitates, as well as idles rough at around 700 rpm. As i continue to monitor things i noticed that my vacuum was way off. at idle im at ~ -8 and i know the normal vac at idle should be around -22 or so. I've done all the checks for a vacuum leak, did a compression test, checked my crank position censor, cleaned my TB, checked my stock EBCS. i have not checked the purge valve yet, im not sure if that would be an issue.
mods: cobb SRI, cobb TIP, cobb BPV, was on cobb ots stage 1 93, now back on stage 0, until i get this figured out.
I have read the few threads i could find on similar problems but none of the solutions given seem to help.
ThomasSpeed3 is offline   Reply With Quote
 Old 12-28-2013, 10:53 PM   #2
rolanblack's Avatar
Posts: 2,110   (View Stats)
rolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the worldrolanblack is the leader of the world
might want to make sure your Air mass sensor is clean and placed flat. take a look at your spark plugs and make sure they are gapped properly. make sure your BPV is flush with the gasket it came with
rolanblack is offline   Reply With Quote
 Old 12-29-2013, 01:11 AM   #3
spark plugs are gapped to specs, checked the all the sensors today that would cause any sort of problems like this, and BPV is flat and flush. @rolanblack;
also have checked with carb cleaner for any leaks, even sprayed around the IM to check that gasket. me and @ccspeed3; have been trying to diagnose for 2 days now and still cant seem to get any sort of result or new information on where the leak could potentially be.
 Old 12-29-2013, 02:00 AM   #4
mituc's Avatar
Posts: 3,507   (View Stats)
Groans: 111
Is your car using any oil? Did you take a picture of the spark plugs before you threw them?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
rfinkle2 (12-29-2013)
 Old 12-29-2013, 02:55 PM   #5
i will upload picture of plugs when i get to my house, on my laptop right now. and oil seems to be ok, no signs of excessive use or loss of oil. ok on dipstick and oil pressure is normal. and i now seem to have a boost leak as well, car was holding boost at first but now has reduced about 5psi. @mituc;
tapatalk likes this.
The Following User Says Thank You to ThomasSpeed3 For This Useful Post:
tapatalk (12-30-2013)
 Old 12-29-2013, 03:10 PM   #6
btstarcher's Avatar
Posts: 4,850   (View Stats)
Groans: 112
You say gapped to spec; what spec? Also what plugs did you use?
SnailTune in progress
 Old 12-29-2013, 06:11 PM   #7
they are gapped at .029 and i used the autolite xp iridium @btstarcher;
 Old 12-29-2013, 06:15 PM   #8
btstarcher's Avatar
Groans: 112
Stock heat range I hope, and I'd still close that gap a little. I would definitely check for boost/vacuum leaks too.
 Old 12-29-2013, 06:39 PM   #9
have been checking for leaks for 2 days :/ me and another local NATOR and we are both stumped, been searching through threads and google and nothing we try seems to fix or find the issue. @btstarcher;
but will close gap some! thank you.
 Old 12-29-2013, 07:01 PM   #10
btstarcher's Avatar
Groans: 112
Post a log of idle and some easy driving. Maybe a quick WOT but not a full pull.
 Old 12-29-2013, 07:40 PM   #11
will do! ill try to do logs toight after the game. @btstarcher;
 Old 12-29-2013, 07:45 PM   #12
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I bet it is the purge valve.
p0455 and 2187 and how to troubleshoot a bad purge solenoid valve!
 Old 12-29-2013, 08:00 PM   #13
if it was the purge valve would it be just stuck open or need replacing? @rfinkle2;
will also check that before i do logs.
 Old 12-29-2013, 08:39 PM   #14
rfinkle2's Avatar
Groans: 298
I think I remember hearing someone clean one, but I would probably replace if your car is relatively high mileage.
 Old 12-29-2013, 09:21 PM   #15
ill check and if thats the case ill order a new one. i hope its something stupid like that...and that literally is one of the last things i have left to check.
 Old 01-01-2014, 05:25 PM   #16
Here are my logs.....had trouble finding a way to upload them cause i dont have MS Office.
Didnt know how to lable them, first time doing logs so no promises. tried to keep them short and to the point.
 Old 01-01-2014, 06:18 PM   #17
btstarcher's Avatar
Groans: 112
Boost leak. Something either disconnected or loose somewhere.
Oh and make sure you log STFT also; you left that out.
Last edited by btstarcher; 01-01-2014 at 06:18 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-01-2014, 06:59 PM   #18
will post that tomorrow @btstarcher; and ive been checking everything possible that could leak and i cant find anything. every hose has been checked, im stumped.
 Old 01-01-2014, 07:04 PM   #19
btstarcher's Avatar
Groans: 112
Manifold pressure at idle should be at around -11.5 psi, give-or-take. You're at around -8 and it fluctuates. Definitely vacuum leak. You didn't check everything.
Did you check your purge valve? Are you sure a hose somewhere doesn't have a hole in it?
 Old 01-01-2014, 07:21 PM   #20
I checked the purge valve and it isnt broken or stuck open. I took off the TIP ans SRI and checked them and the BPV hose, also the hoses off the turbo are all good. I checked my BPV itself, checked all the hoses that have to do with boost/vacuum. I will go through everything again tomorrow for the 3rd time, and ill post some more logs. I have checked everything i know i should have checked, and checked everything i was told to check, and everything i have read to check. @btstarcher;
 Old 01-01-2014, 07:39 PM   #21
kby
kby's Avatar
Posts: 653   (View Stats)
kby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the world
Groans: 31
K, curious from your logs. Your a/c and defog are off right? Keep seeing knock and good vacuum at those amounts. Knock could be the a/c compresser kicking off.
also, That knock at wot can't be good.
kby is offline   Reply With Quote
 Old 01-01-2014, 07:40 PM   #22
btstarcher's Avatar
Groans: 112
You say you checked, but how? Did you build a boost-leak tester? Or just visually inspect everything? Or just take everything off and reinstall? Also do you have an oil catch can? Did you check the hose from the PCV valve to the IM? Also you may try swapping your BPV with a stock one, just in case.
 Old 01-02-2014, 05:31 PM   #23
Getting stock bpv to swap to and a new purge valve just for shits. this Saturday going to take all hoses off and do super close inspection as well as do another boost leak test. Tomorrow going to swap out TIP, SRI, and BPV hose with another speeds that is running good to narrow things down fairly quickly with those specific parts. also getting all new clamps for everything just for peace of mind. the clamps on the car were from previous owner and work but replacing simply cause i want to.
 Old 01-02-2014, 07:14 PM   #24
Silverspec06's Avatar
Posts: 244   (View Stats)
Silverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud ofSilverspec06 has much to be proud of
Silly question but if it was a boost leak, wouldn't his afr when he at wot be rich? from what Im seeing its tending on the lean side. no?
Also Im 403speed3
There are no problems that the liberal application of BOOST can't solve.
INSTALLED: COBB SRI//TiP||Turbosmart 50/50 BPV/BOV|| COBB AP||CNT RACING DP||Corksport 3" CBE||JBR FLAPS|| CP-E stage 2 Rmm|| Autotech CDFP Stage2 tune ||Godspeed FMIC|| Hawk HPS Pads|| Sure SSP|| NGK Step COLDER||
Intalling soon: CPE Triple Gauge pod|| Prosport Evo Gauges|| Ebay OCC With baffling mod.
Up next: EBC Rotors|| BNR S3 Turbah|| JBR balance shaft delete|| JBR 88a Pmm 80a TMM
Silverspec06 is offline   Reply With Quote
The Following User Says Thank You to Silverspec06 For This Useful Post:
btstarcher (01-02-2014)
 Old 01-02-2014, 07:30 PM   #25
btstarcher's Avatar
Groans: 112
That's right; I'm thinking vacuum leak, like maybe from PCV to intake manifold, or maybe a hose at the manifold somewhere leaking.
 Old 01-02-2014, 07:55 PM   #26
Hopefully saturday i will get to the bottom of this...id really like to put the rest of my parts on already haha.
 Old 01-09-2014, 07:38 AM   #27
brettmurphy's Avatar
Posts: 5   (View Stats)
brettmurphy is an unknown quantity at this point
What did it turn out to be? Bad hose?
brettmurphy is offline   Reply With Quote
 Old 06-06-2014, 08:24 AM   #28
BrandonRKD's Avatar
Posts: 417   (View Stats)
BrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the worldBrandonRKD is the leader of the world
Any update on this?
I Tapped that
2006 WWP MS6
Cobb AP, SRI, TIP ▌CP-E HPFP, Safe Seals ▌CS TBE ▌TS BPV ▌Custom FMIC ▌NGK Colder Plugs ▌JBR TIG, EGR Blockoff ▌TB Coolant B/P ▌VTCS Delete ▌H&R Springs
FlowTuned By TiGraySpeed6
BrandonRKD is offline   Reply With Quote
 Old 06-05-2017, 05:48 PM   #29
StickySideDown's Avatar
Posts: 8   (View Stats)
StickySideDown is an unknown quantity at this point
#OldThreadRevival
Was there ever a resolution to this? Or did you just give up...
StickySideDown is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f293/rough-idle-vacuum-issues-161713/
Rough idle/Vacuum issues - Mazdaspeed Forums This thread Refback 12-31-2013 12:14 AM
Issues with rough idle, no boost after intall of bolt-ons 08ms3stock4now MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 02-15-2013 11:28 AM
vacuum at idle? chintastic Gen2 MS3 General Discussion 13 11-16-2012 05:13 PM
Report: Scion FR-S, Subaru BRZ rough idle issues require ECU reflash Haltech Automotive News 0 10-05-2012 10:00 AM
Rough Idle and KR fearturtle03 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 05-27-2011 11:38 AM
sometimes rough idle....?? MSP611 MazdaSpeed 6 - Engine, Transmission & Driveline 12 07-14-2010 04:32 PM
Page generated in 0.47248 seconds with 30 queries
