 Old 08-09-2012, 06:04 AM   #1
kish89's Avatar
Posts: 292   (View Stats)
kish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the world
Default Running rich,high KR - strange whistling sound around turbo
I'm currently in the middle of second Stratified tune with BNR S3, so I would appreciate if @Lex can jump in because he knows complete history of my car.
So, car was running great before 4 days, but now when going WOT in any gear past ~10-12PSI of boost I hear some strange whistling noise from around turbo.
Also, my AFRs are rich 10.XX, and they should be at around 11.XX.
Strange thing is that I get some serious KR when my AFRs starts to get rich..
There is no KR when driving partial-WOT.
I have attached two 3rd gear logs, first log is full RPM range, but in second I left throttle because of high KR.
What do you think is my exhaust leaking, post or pre turbo?
I have checked and there is no boost leak..
I would appreciate any input.
Thanks.
edit:
In logs there is not calculated boost pressure, to get it you need to minus 14.5PSI from manifold pressure, but as I said there is no boost leak and boost pressure looks nice as It was before that whistling noise
06 MS6, Versatuner, Stratified Tuned
BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter
Autotech HPFP internals, Forge V1 BPV
Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe
Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP
NGK Iridium IX one step colder plugs, CPE SafeSeals & studs
Custom FMIC with 2.5" piping and Treadstone TR8 IC
SnowPerfomance WMI, Stratified Guardian Angel
Eibach pro kit lowering springs
kish89 is offline   Reply With Quote
 Old 08-09-2012, 08:28 AM   #2
kish89's Avatar
Fixed!
It was exhaust leak where exhaust manifold connects to turbo, two studs were out.
Didn't took any logs, but whistling is gone
The Following 2 Users Say Thank You to kish89 For This Useful Post:
btstarcher (01-15-2014), Lex (08-09-2012)
 Old 08-09-2012, 09:04 AM   #3
Originally Posted by kish89 View Post
Fixed!
Great you found the leak. Not sure if the KR is associated. The fueling richens up because of the knock detected. Did you buy gas from a different source? If the KR is still there drop me a log in an e-mail and I will take a look at it.
kish89 (08-09-2012)
 Old 08-09-2012, 09:26 AM   #4
kish89's Avatar
Nope, gas was from same station, maybe ex. manifold was somehow "knocking" on turbo so that caused fake KR?
I will take some logs later today and see if KR is gone.
Also 3BAR MAP is installed and everything seems fine.
We can continue discussion via mail.
The Following User Says Thank You to kish89 For This Useful Post:
Lex (08-09-2012)
 Old 01-15-2014, 09:09 PM   #5
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
Found this thread in a search; two of my turbo/manifold studs are missing as well, and I've had this "shriek" for awhile now. However I've also noticed a decrease in total airflow; did you see that as well?
SnailTune in progress
 Old 01-15-2014, 09:46 PM   #6
speed3gavin's Avatar
Posts: 8   (View Stats)
speed3gavin is infamous around these parts
Groaned at 31 Times in 2 Posts
loose parts an mimic engine knock under certain conditions.
also lost exhaust gasses before the turbo will drop boost psi due to the fact that the turbo is receiving less exhaust gasses for spool up
hot hatches ftw
Last edited by speed3gavin; 01-15-2014 at 09:46 PM. Reason: MSF Database - Automerged Doublepost
speed3gavin is offline   Reply With Quote
 Old 01-15-2014, 10:00 PM   #7
btstarcher's Avatar
Groans: 112
I'm still meeting boost targets, but total airflow is down. Also AFR is off but that's an obvious thing. Leak is before the primary O2 sensor.
 Old 01-16-2014, 08:03 AM   #8
btstarcher's Avatar
Groans: 112
Well I looked at my logs and I am slightly lower in boost levels. Not much, .5 to 1 psi.
running rich? i need help ericdebruyn1 Mazdaspeed3/6 General Discussion 7 07-25-2012 07:10 PM
Running Rich in 1st and 2nd sallyspeed3 MazdaSpeed 3/6 - ECU Computer Tuning 12 05-31-2012 12:17 PM
Car running rich SilkySpeed3 Gen2 MS3 General Discussion 8 03-29-2012 02:28 AM
Strange Sound RacerX 2010 MS3 - Troubleshoot/Diagnostics 5 12-15-2011 11:02 AM
strange whistling after oil change HARPER306 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 04-23-2011 07:30 PM
Page generated in 0.27785 seconds with 24 queries
