 Old 01-13-2011, 07:07 AM   #1
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groans: 29
Default shaking above 45
alright so last night i was out driving in all this snow the EC has been getting. Anyways, I was on an unfamiliar road and ended up crossing over a small "median" that was raised off the ground. I couldn't see the fucker due to all of the snow on the road and whatnot. It sounded like it scraped up the skid plate a little but everything was fine. I don't think I really got above that speed last night after the incident though.
Anyways on my way to school today i realize my car is shaking pretty bad above 45 and it definitely has to be from whatever last night. I checked out my tires and they are fine. I'm hoping it just needs an alignment? (sucks I just got it done like 2 weeks ago lol) What are the chances it's the tie rods, bearing etc.?
Just looking to see if anybody has any idea on the possible damage I did?
Thanks
shawn. is offline   Reply With Quote
 Old 01-13-2011, 09:04 AM   #2
speedtown's Avatar
Posts: 533   (View Stats)
speedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the world
could be a lot of things. Did you clean out all the snow in the rims? that will cause major shaking if you don't clean them out. Also you could have bent a rim that would cause some shaking as well.
06 VRM MS6 - AP Stage 2 (Self Tuned to 18psi) - Forge BPV - PG SRI - PG TIP - Turboxs TP - ETS TMIC - TMW Stage1+JB SSP - CP-e RMM - PTP smokey turbo fix - Bnoon bolt - Prosport Boost Gauge in block8head vent pod
speedtown is offline   Reply With Quote
 Old 01-13-2011, 09:20 AM   #3
DSIT995's Avatar
Posts: 1,768   (View Stats)
DSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the world
If ur car was parked outside, its prolly snow in the wheel well.... Had that happen to me once on my Yukon and it shook BAD
08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock!
99 Miata NB - Stock for now
Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors
DSIT995 is offline   Reply With Quote
 Old 01-13-2011, 09:21 AM   #4
R3V
Formerly Mr. Duckface Badass
R3V's Avatar
Posts: 201   (View Stats)
R3V is the leader of the worldR3V is the leader of the worldR3V is the leader of the worldR3V is the leader of the worldR3V is the leader of the worldR3V is the leader of the worldR3V is the leader of the worldR3V is the leader of the worldR3V is the leader of the worldR3V is the leader of the worldR3V is the leader of the world
Groaned at 119 Times in 30 Posts
Check the inside of your wheels, my buddy bent the inside part in two places and didn't realize it till his tire went flat a few days later.
R3V is offline   Reply With Quote
 Old 01-13-2011, 09:33 AM   #5
MS33SM's Avatar
Posts: 1,821   (View Stats)
MS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the world
Groans: 132
Groaned at 166 Times in 92 Posts
1. Get hot girl in your car
2. Go above 45
3. ?????
4. Profit
MS33SM is offline   Reply With Quote
 Old 01-13-2011, 10:54 AM   #6
shawn.'s Avatar
Groans: 29
yo guys i'm thinking it's snow in the wheel...i checked them earlier when i made this and there was snow in them. thought to myself the weight difference could be enough to make it shake that bad. however i'm in class so i'll check after...definitely hoping that's the problem.
after thinking about it i drove for a good while after my little "incident" in the OP haha so i'm thinking it's snow in the wheel.
 Old 01-13-2011, 11:01 AM   #7
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
AtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the world
My money is on snow in the wheels. I have to clean mine out when it snows...
AtTheDriveIn is offline   Reply With Quote
 Old 01-25-2011, 01:56 PM   #8
Police - Grammarhead
Vansquish's Avatar
Groans: 1,861
I hope it's just snow and not one of the worse options. It might not be bent rims either. It's also possible that it could be that you've damaged your hubs/wheel bearings. I have a buddy that did an almost identical thing to his Chevy Equinox. The POS was shaking at any speed over about 30 mph after that.
car shaking Fermion MazdaSpeed 3/6 - Troubleshoot/Diagnostics 19 02-02-2011 04:03 PM
Shaking up the pricing model Haltech Automotive News 0 04-18-2010 09:10 PM
shaking apart the car k0m MazdaSpeed 3 - Engine, Transmission & Driveline 22 06-03-2009 07:31 AM
Car is shaking violently above 55 6-Speed-6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 12-26-2008 06:23 PM
Page generated in 0.49044 seconds with 26 queries
