 Old 08-20-2012, 02:22 PM   #1
eleitner8914's Avatar
Posts: 13   (View Stats)
eleitner8914 will become famous soon enougheleitner8914 will become famous soon enough
Default Shaking under acceleration
Last week I lowered my car with Raceland coilovers. Everything installed flawlessly I did not have any issues. I lowered aprox 2 inches all the way around using digital calipers to make sure all sides were equal. After I put the car back together I took it out for a drive. I now had a shaking/ vibration while accelerating. At first i thought it was an alinement issues so I let the car settle for a few days and then went and got an alinement. After the alinement the issues is still there. I double checked every bolt everything is tight, wheels were properly torqued. The vibration is the worst during hard acceleration in 3rd and 4th gear. Not sure where else to look for issues. Please Help!!
eleitner8914 is offline   Reply With Quote
 Old 08-20-2012, 02:29 PM   #2
EdgeAutosport.com's Avatar
Posts: 6,207   (View Stats)
I would say the tires are contacting the coil itself causing the vibration. Pull off the tire and look on the inner side wall.
 Old 08-20-2012, 02:41 PM   #3
Posts: 12,651   (View Stats)
I'm having a slight vibration under accel as well after lowering on COBB springs in those same gears.
What are the alignment specs? Toe and/or camber can affect this. So can a worn out axle.
 Old 08-20-2012, 02:44 PM   #4
Xploder08's Avatar
Posts: 564   (View Stats)
Xploder08 is the leader of the worldXploder08 is the leader of the worldXploder08 is the leader of the worldXploder08 is the leader of the worldXploder08 is the leader of the worldXploder08 is the leader of the worldXploder08 is the leader of the worldXploder08 is the leader of the worldXploder08 is the leader of the worldXploder08 is the leader of the worldXploder08 is the leader of the world
Did you put wheel spacers on? If so they could be mounted wrong which could cause this vibration, I had this exact issue... Took my spacers off and *poof* vibes/shimmy in steering wheel went away.
I do agree with Eric's suggestion to check the inner tire for wear marks.
2006 MS6 TIGray with panda interior (for the ladies) - Fully built bottom end with things attached... enough said.
Xploder08 is offline   Reply With Quote
 Old 08-20-2012, 03:08 PM   #5
Camber > L = -1.8 , R = -1.8
Toe > L = 0.14 , R = 0.18
I do not have spacers on the car and I will check for wear on the inner wall soon and get back to you. Thanks.
 Old 08-20-2012, 03:11 PM   #6
You have too much toe. The insides of your tires will wear very fast with that much camber and toe. I would dial the toe to less than 0.05. This may also be causing the issues. Is it worse when turning?
 Old 08-20-2012, 03:14 PM   #7
I have not noted that it is worse when turning. Only notice it during a hard pull. Ill accelerate threw a turn and see if its different.
 Old 08-22-2012, 02:47 PM   #8
Got under the car today and the suspension compressed the wheels are not hitting the coilovers. There is no evidence of rubbing. I put the car up about .5 in so that the axles were parallel to the ground instead of angled upwards. This seemed to help a lot. There is still a little more vibration then before. This might be attributed to the stiffer shorter suspension.
 Old 03-20-2013, 06:11 PM   #9
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
thatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the world
Default Re: Shaking under acceleration
Did you ever find a resolution to this?
| CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline   Reply With Quote
 Old 06-20-2018, 11:23 AM   #10
CalvinMS6's Avatar
CalvinMS6 is an unknown quantity at this point
[QUOTE=thatsmrgimp2u;1959434]Did you ever find a resolution to this?
bump, anyone find out what this is? same issue 07 speed3, raceland ultimos. about to install my 30r setup but want the car sorted first. thanks.
Current: 2007 Speed3 Sport: FBO + GT3071R On 93 - Freektuned
Sold: 06 Speed 6 (FBO, PD TUNED 21PSI), Evo 8, Several Mustangs, E46
CalvinMS6 is offline   Reply With Quote
 Old 10-18-2018, 05:14 PM   #11
Ageofconner's Avatar
Posts: 1   (View Stats)
Ageofconner is an unknown quantity at this point
Default Having the same issue
Did anyone find out why it is vibrating??? I am getting it aligned tomorrow hopefully but I want to make sure this will fix it.
Thanks!
Ageofconner is offline   Reply With Quote
 Old 01-10-2019, 11:14 AM   #12
Reds3's Avatar
Posts: 4   (View Stats)
Reds3 will become famous soon enough
Default Issues with Vibrations.
I had this issue up until a few weeks ago when i raised my car up for the winter. I am running Raceland Coilovers on my Ms3 and would get a vibration under acceleration, similar to a bad hanger bearing.
Raising the car up 1" and 1/2 seemed to get rid of the issue permanently for me. I did not get a chance to inspect what the issue was but i would tend to agree about the wheel rubbing on something. That is part of the reason i decided to raise the car up too, raising the car in small increments until the issue is gone may send you in the right direction.
I will be taking these coil overs out in the summer, they get you low but the ride quality is god awful and it seems a good aftermarket shock and spring is the way to go.
Reds3 is offline   Reply With Quote
 Old 01-10-2019, 11:55 AM   #13
Bertospeed3's Avatar
Posts: 56   (View Stats)
Bertospeed3 is a name known to allBertospeed3 is a name known to allBertospeed3 is a name known to allBertospeed3 is a name known to allBertospeed3 is a name known to allBertospeed3 is a name known to all
if anyone ever needed more reasons to NOT install raceland coils, just read this thread
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
 Old 01-10-2019, 11:56 AM   #14
MSMS3's Avatar
Posts: 2,324   (View Stats)
Groans: 126
Just go back to OEM Mazdaspeed coil springs on all four corners and Bilstein struts and shocks. Mazda got the spring height and stiffness right. OEM coils are about 40% stiffer in front and 20-25% stiffer in back than regular Mazda 3 springs. It's a very good compromise for all but a dedicated track car.
Mazda cheaped out on the struts and shocks, however. The Bilsteins (B6 or B8 - either work with stock height springs), really solve the handling issues without destroying the ride quality. Very firm on both compression and rebound, but still compliant.
 Old 01-10-2019, 02:11 PM   #15
Jeff23spl's Avatar
Posts: 1,620   (View Stats)
out of ride quality, if you get vibration under acceleration and it get solved when changing the height, i would check carefully axle joints for loose...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
shaking when accelerating Sal's_MS6 MazdaSpeed 6 - Engine, Transmission & Driveline 10 06-13-2011 07:06 PM
car shaking Fermion MazdaSpeed 3/6 - Troubleshoot/Diagnostics 19 02-02-2011 05:03 PM
shaking above 45 shawn. MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 01-25-2011 02:56 PM
shaking apart the car k0m MazdaSpeed 3 - Engine, Transmission & Driveline 22 06-03-2009 08:31 AM
Car is shaking violently above 55 6-Speed-6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 12-26-2008 07:23 PM
Page generated in 0.31924 seconds with 30 queries
