 Old 10-07-2017, 04:33 PM   #1
zolixiii's Avatar
Posts: 3   (View Stats)
zolixiii is an unknown quantity at this point
Default short rattle when i hit the clutch, again when i hit throttle, only when engine is cold, also, shitty mpg
Hey guys, this is my first post.
I have a mazdaspeed 6, got it a year ago. Everything was changed, vvt, timing chain, injector cleaning and upgraded seals, all oils.
I have this issue for quite a while and cant seem to find what ii is.
It happens only when the engine is fully cold, so once a day at the first start.
A small rattle when i hit the clutch, then after the shift, a small rattle again when i push the gas.
Seems the car is running fine, pulls hard, no hesitation, it persists for almost 10.000km s now and its really annoying. It stops right when the coolant temp indicator hits its normal place, so approx 5-6 mins after start.
Also i have terrible mpg but i dont think its related, i will change the valve cover gaskets next week, see how the spark plugs are doing and also possibly clean the intake valves, any other ideas to improve gas milage?
I dont push it hard especially on low revs, mostly city driving, slowly.
I get 14mpg city, 16 combined, thats pretty damn bad imho...
Thanks in advance, i truly appreciate any help in both cases!
zolixiii is offline   Reply With Quote
 Old 10-07-2017, 11:52 PM   #2
mituc's Avatar
Posts: 3,441   (View Stats)
Groans: 108
Flywheel.
If when you stop the car you feel like something is still spinning for half a second there then it's definitely the FW.
2008 Cosmic Blue Mazda 3MPS
SU TMIC, Autotech HPFP internals, GTX2867R gen2, stock cats and stock exhaust FTW
Versatuned
 Old 10-08-2017, 06:30 AM   #3
speed23's Avatar
Posts: 1,469   (View Stats)
I am going with vvt gone bad
 Old 10-08-2017, 06:53 AM   #4
zolixiii's Avatar
Thanks for the quick replies, it doesnt feel like something is still spinning after stop and the vvt was changed with the timing chain 10.000kms ago. So probably none of these :/
Its just for a second when i push the clutch then again when i push the gas after changing gears. Clutch seems to be fine, transmission also.
I was hoping someone experienced the same before and found a solution, my friend who does service on it only works with mazdaspeeds for years now and built hos own to 470hp, but he never encountered an issue like mine before :/
Car only has 144.000kms/89500miles
 Old 10-08-2017, 08:41 PM   #5
mituc's Avatar
Groans: 108
This could explain the shitty MPG though...
Well... this could be caused even by a worn mount.
If an experienced mechanic could not find the issue on site, how would one expect to point you to the root of the issue on a forum based on some symptoms that could have a lot of different causes? Just think about it...
Versatuned
Last edited by mituc; 10-08-2017 at 08:41 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-09-2017, 06:10 AM   #6
GroceryGtr's Avatar
Posts: 469   (View Stats)
First question: was this pre-existing or did it start after vvt replacement? If it started after vvt replacement then I think it wasn't timed properly when it was reassembled. vvt usually exhibits its self as a rattle right at start up as part of the symptoms though, which you didn't mention.
The whole gas pedal thing could be tip in from the fuel pump. Generally you'll get a vvtish sound rattle around 2k on very light throttle that instanly goes away with additional throttle or once you are out of the 2-3k range. Clutch part kind of throws me though.
 Old 10-09-2017, 11:22 AM   #7
zolixiii's Avatar
I was kind of thinking about a worn mount as well, but that shouldnt go away straight after the cooling temp hits its good spot.
I was also thinking vvt wasnt reassembled right but how can i decide if it wasnt are there any signs if we split the engine up?
It does it a little on cold start actually but it totally vanishes after the cooling fluid heats up which is quite weird.
Sorry for the dumb thread i know no one is an internet guru that can heal the car, i was actually hoping that someone had the same issue but it seems something is screwed up only with my ride.
Thanks for all the answers any new ideas appreciated!
We’ll look into this closer hopefully this week.
 Old 03-20-2018, 01:58 PM   #8
Mazdaspeed6RDC's Avatar
Posts: 17   (View Stats)
Mazdaspeed6RDC will become famous soon enough
I am experiencing the same thing happening to my mazdaspeed 6. If you ever find out what the source of the noise is, let me know. I'll do the same.
Mazdaspeed6RDC is offline   Reply With Quote
 Old 03-21-2018, 12:37 AM   #9
mituc's Avatar
Groans: 108
Get out of the car and have someone press/depress that clutch for you. At least doing so you will locate the area the noise comes from, which will help 6 tons.
Versatuned
Thor Hammer (03-21-2018)
 Old 03-21-2018, 01:11 PM   #10
Unfortunately it only makes the noise when the car is in motion. Especially over bumps, jerky acceleration or jerky braking brings it out more as well. This is why I suspect rear motor mount, and I am replacing the stock one with one from Corksport this weekend. What I don't understand is why it only makes it when it is cold and it makes absolutely no noise once warmed up. I will have to see if the new motor mount solves the issue and I will be sure to post the results on here.
2008 MS3 Blows Cock, Shitty Shop Does Shitty Work Resulting in Shitty Numbers aka The I Ignored MSF Clusterfuck deltapsik0 MazdaSpeed 3/6 - Big Turbo Builds 114 03-22-2017 06:37 PM
Metallic rattle under throttle, stutter and misfire rey_06 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 09-20-2014 12:11 PM
rattle/knock noise cold start MS3_CHRIS MazdaSpeed 3 - Engine, Transmission & Driveline 13 02-13-2014 10:52 AM
Rattle under throttle - HPFP? CaseyBueno Mazdaspeed3/6 General Discussion 24 12-17-2013 12:30 PM
Cold Start rattle/scraping alextheguineapig MazdaSpeed 3 - Engine, Transmission & Driveline 6 11-27-2013 02:02 AM
Page generated in 0.30045 seconds with 24 queries
