 Old 07-08-2019, 07:47 PM   #1
esecrazyboy's Avatar
Posts: 6   (View Stats)
esecrazyboy will become famous soon enough
Default Smoking problem and crankcase pressure
Hi I just bought my gen 1 speed 3 2 weeks ago and I am dealing with smoking out of the exhaust and to much crankcase pressure Iíve been reading and Iíve done the 2nd gen valve cover with breather cap but now Iím getting oil out of the breather cap and still throwing smoke not as much as before I did the valve swap Is there anything else I can do? I was thinking of doing a vented catch can and a new pcv would that help out my problem at all?
esecrazyboy is offline   Reply With Quote
 Old 07-08-2019, 08:08 PM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,964   (View Stats)
Groans: 546
so your last resort was to check the pcv?
94 M
06 MS6
 Old 07-08-2019, 08:23 PM   #3
Yes just bought it so I wasnít to sure on what to change out and what to look for
 Old 07-09-2019, 05:21 AM   #4
Jeff23spl's Avatar
Posts: 1,937   (View Stats)
i hope you didn't paid it too much....it will take good money to fix it.
Opening more windows to get the blow by out won't solve the blow by problem....a new engine will....(Assuming you really installed a gen2 cover with a baffle below the oil cap)
Unless it is just smoking at idle and it is your turbo...
Start by checking compression and leak down.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-09-2019, 07:35 AM   #5
MSMS3's Avatar
Posts: 2,531   (View Stats)
Groans: 141
If it has decent compression (see above) the problem may have been fixed by what you have done to the PVC system, but perhaps too late to save the turbo seals. In that case it will be new or rebuilt K04 or BNR S1 time. BNR S1 is a plug and play duplicate of the K04, but with Garrett guts with much better bearings and seals. Same flow, so it runs like a K04 on any K04 OEM ECU or compatible tune.
2017 Audi Q5 3.0 T (supercharged) Stage 2+, EPL tune, JHM overdrive crank pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 450 hp.
 Old 07-09-2019, 08:09 AM   #6
Iím going to check compression and I have a new turbo
The Following User Says Thank You to esecrazyboy For This Useful Post:
MSMS3 (07-09-2019)
 Old 07-09-2019, 05:44 PM   #7
I installed a new pcv and it stoped my smoking problem but I am still getting oil out of my breather cap and thing I can do to stop that?
 Old 07-10-2019, 04:16 AM   #8
Fstrnyou's Avatar
Posts: 2,412   (View Stats)
Did you take any pics of the Gen2 cover with the brather installed?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 07-10-2019, 05:25 AM   #9
Jeff23spl's Avatar
This is what i think also, if the baffle isn't there, the chain just keep shooting oil into the breather at each engine turn...
Wife drive 2010 CX7
 Old 07-10-2019, 09:52 AM   #10
I can take some later but it does have the baffle it only when I accelerate
 Old 07-10-2019, 10:55 AM   #11
Fstrnyou's Avatar
If there is a baffle and it only spews oil on acceleration, then you have an ass load of blowby or something to generate enough airflow through the filter to carry oil with it.
Other rides:
History:
 Old 07-10-2019, 12:47 PM   #12
Anything I can do to reduce it? Would a vented catch can do anything?
 Old 07-10-2019, 02:03 PM   #13
Jeff23spl's Avatar
a good catch can with internal separator and condenser mesh could probably work better than the vented cap at trapping and condensing oil vapors but you will need to empty it at some intervals relative to your blow by....It remain a band-aid. (avoid a cheap ebay anodized can with 3/8'' barb connectors....)
have you pressure tested your intake PCV just in case you got a bad one once installed ? (I mean pressurising the intake and listen for leaks ? )
Engine compression test remain the thing to do first but just in case...
Wife drive 2010 CX7
 Old 07-11-2019, 04:55 AM   #14
Reds3's Avatar
Posts: 30   (View Stats)
Reds3 is a jewel in the roughReds3 is a jewel in the roughReds3 is a jewel in the roughReds3 is a jewel in the rough
Interested in compression numbers, Could be doing this all on a worn out engine.
2007 Mazdaspeed 3 / Cobb SRI / 219K and Counting
1995 EG6 B16A3 78K *sold*
Reds3 is offline   Reply With Quote
Excessive Crankcase Pressure and Blow By skemmm Mazdaspeed3/6 General Discussion 10 04-01-2018 04:03 PM
Crankcase Pressure Venting BuddySpeed3 Damond Motorsports 25 06-27-2016 07:04 AM
OCC and crankcase pressure testing diaries Matt@DamondMotorsports Damond Motorsports 125 05-19-2014 05:02 PM
Our PCV System and improving Vacuum on the Crankcase - Eliminate Smoking Turbo Issue mczimer Mazdaspeed3/6 General Discussion 8 03-25-2012 11:35 AM
Negative Crankcase Pressure kore2000 MazdaSpeed 6 - Engine, Transmission & Driveline 3 03-16-2010 06:56 AM
Page generated in 0.32992 seconds with 25 queries
