speed3turbo,,, driving my son crazy Hi, Please bear with me . I know I have no knowledge about these great machines BUT......... My son was stationed in El Paso Texas - army . He traded a good running mazda 3 for the speed 3 turbo. It's back here in NE Ohio now and running bad. Him and a couple of speed 3 lovers just took it down and replaced injecters , fuel pump and a few other items because of the way it was running. This generally occurs around 4 - 5 then just ' flutters ' and rpms drop to 1-2 . You cannot pedal out of the loss . When he was driving it this happened continuously on the road. bad ju-ju . Just sitting it idles great . Any thoughts here ? :banghead: |
Is it throwing any codes? Maybe switch some of the coilpacks and see if you can isolate a bad one. |
Can you name all the mods that the car currently has and also can you list the "other few items" that his been replaced Also if there is a code, that would help tremendously. |
Which fuel pump was replaced? In tank pump or cam driven fuel pump internals? |
Might want to also insure the injector seals (between injector and block) were installed correctly since the injectors were removed. That being said, it sounds like this was a pre-existing problem, but i'd hate for them to fix the root cause and be left with other subsequent issues. |
| All times are GMT -7. The time now is 04:42 AM. |
