 Old 01-05-2018, 05:40 PM   #1
Badger_'s Avatar
Posts: 1,572   (View Stats)
Badger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the world
Default Stalling at cold start, p2187, high fuel trims, hesitation/sputter
TL;DR
-Cold starts car dies 1-3 times before running.
-Severe hesitation and sputtering under 3,000rpms when engine cold.
-Hesitation when accelerating/cruising under 3,000rpms any temp
-P2187 - too lean at idle
-Ltft really high at 20+
-Stft really high at 20+
-Based on logs my average AFRs are lean. (average 15-16)
-Posted logs
I’ve been putting off starting a new thread, but here we go.
Cold starts (like really cold -10 to +10F) car doesn’t want to stay running after start. Car starts and then dies 5-10 seconds after. This will happen 1-3 times before the car will stay running, but it has always eventually stayed running. If I try to give it a little gas to increase rpms the car dies instantly.
Massive hesitation and sputtering for the first few miles after first start of the day. Increasing throttle does nothing and car struggles to move. Once rpms are about 2900+ the car drives just fine. Logs look like It leans out quite a bit during that time. I will attach logs.
Slight random hesitation while driving after car is warmed up. While accelerating and cruising alike. Seems to be getting worse and appears to really only happen (noticeably) under 2900 rpms.
Car throws p2187 for lean at idle. Ltfts and idle are between 19.xx-20.xx. Stupid high. Sometimes stft+ltft is above 30. AFRs don’t seem super lean. Most of the time it actually reads rich at idle at around 14.41-14.55. Sometimes it creeps up to 15.3-16 (which is lean, true), but usually goes back down to 14.7, 14.55, 14.41 sometimes even 13.9 within 30 or so seconds. I have attached an idle log.
I’ve check for boost leaks twice with no luck. I recently (a couple of thousand miles ago) replaced my MAF sensor because the old one was corroding on the inside. That was also giving me a lean idle code (can’t remember if it was the same as this one) and the car was hesitating similarly to this, with the addition of hard acceleration hesitation.
I just replaced the purge valve today. Made no difference.
I replaced the fuel pressure relief valve about 8 months ago, saw my fuel pressure drop instead of climb after shutting the car off. That was fixed.
Mod list:
Injen sri (used to be a cai, but I cut it down)
Corksport tip
JBR boost and bpv hoses
Thermal insulating TB and IM gaskets
Autotech hpfp
Corksport test pipe
Custom 3” exhaust with 8” glasspack (essentially straight pipe) ADDED AFTER TUNE
Freektune Ots+ tune (same tune for years)
Also to note, I had the TB coolant bypass installed for nearly two years (also cleaned the TB, EGR, and valves at the same time) and about a week ago my TB froze up (it was in the single digits to the -xx *F). I removed the bypass. TB hasn’t stuck again.
No significant change in gas mileage. 14-18 city and 21-25 combined.
I know that was a lot to read, but I would be very interested in any thoughts from you guys.
Things that I am questioning:
Spill valve?
Pcv valve?
Upstream O2 sensor?
Bad MAF?
Bad accel pedal position sensor?
Just too damn cold?
This is my 6th year with this car in winter and the first time I’ve had this problem, so I’m not convinced weather is the only factor here. Somethings fucky.
Car still hauls ass. I posted a 3rd gear to 4th pull (not WOT, but to about 18psi boost).
2007 MS3
Injen SRI | CS TIP | CS TP | 3" TP-Back Straight Pipe | AT Internals
All Mounts | Koni Oranges | Eibach Springs | Moog Endlinks
Thermal Insulating Gaskets | TB Coolant Bypass
AP V3 | FreekTune | Russian Dashcam Mod
Badger_ is offline   Reply With Quote
 Old 01-05-2018, 05:41 PM   #2
Badger_'s Avatar
Looking at the hesitation logs, it looks like the pedal position jumps to 0 when I know I did not lift off the pedal. Is this indicative of a bad pedal assembly? This would explain the hesitation, but not really anything else.
2007 MS3
 Old 01-06-2018, 07:38 AM   #3
5doorsoffury's Avatar
Posts: 1,070   (View Stats)
Groans: 74
Well i see 0 wgdc then out of nowhere it jumps to th 60s for a few cells... stupid lean when low load and 9s when on the gas. It sounds like a big boost leak. Sucking air in during vacume and blowing it out under boost. Do a boost leak test again. Check the bpv and the egr they are both a place for air to leave the system.
MECP
2012 BM
Rfinkle tune in progress
The Following User Says Thank You to 5doorsoffury For This Useful Post:
Badger_ (01-09-2018)
 Old 01-06-2018, 08:52 AM   #4
Badger_'s Avatar
Thanks for the response, Iíll check them both again.
2007 MS3
 Old 01-06-2018, 04:45 PM   #5
torquemaniac's Avatar
Posts: 727   (View Stats)
Watch for leak at the manifold gasket...especially with PTFE thermal insulating gasket (tehy can deform and leak)
2011 CX-7 AWD 2.3 turbo
Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler // Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner
Coming soon : Composite ram-air intake // Hood with heat extraction vent
The Following User Says Thank You to torquemaniac For This Useful Post:
 Old 01-06-2018, 10:22 PM   #6
Badger_'s Avatar
Good advice, thanks.
2007 MS3
 Old 01-07-2018, 09:26 PM   #7
Badger_'s Avatar
Did another boost leak test tonight and found a leaking weld on my turbo inlet. I welded the hole shut and re-tested. No more leak.
Took the car for a drive and saw negative ltfts (other than -0.16) for the first time in months. -3.42%. Im still seeing +18-20 ltfts under some conditions, but Iím hoping it just wants more miles....
Iím not 100% convinced, but it feels good finding a leak, fixing it, and seeing some sort of instant result. Weíll see if it wants to die/stutter tomorrow morning.
Terrible photo, but look at the bubbles.
2007 MS3
 Old 01-08-2018, 08:35 AM   #8
Badger_'s Avatar
Update: car started right up this morning without wanting to stall. Also, no hesitation. Fuel trims are still high.
2007 MS3
 Old 01-08-2018, 11:17 AM   #9
Thor Hammer's Avatar
Posts: 1,766   (View Stats)
Groans: 198
Do you see + trims at idle or while cruising? If at idle there could be a vacuum leak at the intake manifold or elsewhere.
Could also be the ECU needs more time to re-learn the trims.
 Old 01-08-2018, 11:59 AM   #10
Badger_'s Avatar
Highest positive values are during idle. It was ~20, but went down to 19 today while driving. My stfts look a little more sane, so it looks as if the car likes being driven. Cruising on highway fluctuates from -3.26, -0.16, and +17.xx. I only drive like 10-15 miles a day (all city), so thatís not helping the car learn any faster. Going to go for a longer drive later this evening.
About the idle ltft values. Last night after I took it for a drive post hole plug I let it sit and idle for about 25 minutes. Ltfts went down from +20 to +8, but when back to +20 at idle after driving about 5 miles.
2007 MS3
 Old 01-09-2018, 01:00 PM   #11
Groans: 198
Time to check for vacuum leaks.
 Old 01-11-2018, 08:43 AM   #12
Badger_'s Avatar
Fuel trims continue to decrease. Ltfts have moved from +20 to +17.78 while cruising, which is still high, but stfts during this time are usually negative. Idle ltfts continue to drop. Currently at +12.23 (down from 20+) with stfts in the negatives. Accelerating ltfts are -3.28.
Car starts every time without dying and I havenít any hesitations.
I only put about 60 miles on it since fixing the leak.
2007 MS3
 Old 01-11-2018, 08:55 AM   #13
Fstrnyou's Avatar
Posts: 2,149   (View Stats)
I believe disconnecting the battery can reset fuel trims.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 01-13-2018, 02:10 PM   #14
Badger_'s Avatar
This car really hates the cold. It ran great and trims looked good in the 30+ degree weather. We had a couple of 40-50 degree days here in Ann Arbor, MI and the car liked it a lot. Yesterday after work it died upon start up and was hesitating....temp was 16F outside. I'm going to bench the car for now and drive my beater in the bitter cold. Fingers crossed for a short winter...
Still need to look for a vacuum leak, but I'm taking a week or two or three off of working on the car. too frustrating. It's making me want to sell it.
2007 MS3
Stumbling, hesitation, numb gas peddle, Fuel trims crazy, Lean, P2187. brainbot1 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 01-05-2018 06:27 PM
Sputter/Hesitation U2064 P2177 P2187 P2097 KFL989 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 24 03-26-2014 07:35 PM
High fuel trims at idle sdg_3mps MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 32 07-28-2012 07:51 AM
High pitched squeal on cold start curlyface MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 06-05-2012 12:40 PM
hypertech cold start high idle cuse' boost1 MazdaSpeed 3/6 - ECU Computer Tuning 19 06-13-2011 08:37 AM
©Copyright 2008 ; 2018 Cymru Internet Services LLC | FYHNô Autosports HQ
Page generated in 0.36017 seconds with 25 queries
