Notices
 Old 09-08-2012, 01:52 PM   #1
EmPeEs6's Avatar
Posts: 247   (View Stats)
EmPeEs6 has a brilliant futureEmPeEs6 has a brilliant futureEmPeEs6 has a brilliant futureEmPeEs6 has a brilliant futureEmPeEs6 has a brilliant futureEmPeEs6 has a brilliant futureEmPeEs6 has a brilliant futureEmPeEs6 has a brilliant futureEmPeEs6 has a brilliant futureEmPeEs6 has a brilliant futureEmPeEs6 has a brilliant future
Groaned at 8 Times in 5 Posts
Default Strange rattling sound...
Hello,
since this afternoon my car makes a strange sound.
It's a kind of rattling noise which can be heard clearly in engine idle state (and is loudest when the fan runs).
In the engine bay the noise is not as loud as you can hear it directly in front of the right wheel (driver's side).
In front of the other wheel you don't hear any clatter!?
Any ideas???
Mods: BNR S3, cb + rp, CS tip, sri + air box, SU tmic, water inj., itv22 plugs, Forge bov, hpfp-upgrade, Grimmspeed ebcs, 3 bar map sensor, only 102 octane fuel, ACT 6 pad clutch with SL flywheel...
EmPeEs6 is offline   Reply With Quote
 Old 09-08-2012, 02:03 PM   #2
tddvrrn's Avatar
Posts: 2,572   (View Stats)
Groans: 103
belt tensioner pulley..
The Following 2 Users Say Thank You to tddvrrn For This Useful Post:
Jfishe (09-10-2012), TiGraySpeed6 (09-08-2012)
 Old 09-09-2012, 02:55 AM   #3
EmPeEs6's Avatar
Thank's, but why can I hear it just in front of the right side/wheel of the car?
 Old 09-09-2012, 03:05 AM   #4
The Cone Killer
MS6FL's Avatar
Posts: 1,393   (View Stats)
MS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the world
Groans: 40
Think OP really means left side. The drivers side.
OP, vehicle side is always from sitting in the car.
As far as the noise, the only thing there is the intake air box as far as I know. Maybe it's loose?
Ariel
COBB SRI/TIH/XLE/ECBS/AP/Knob, PnP'ed IM, ETS TMIC, Autotech FP internals, Guardian Angel, M2 DP, JBR SSP/EGR Delete, AWR 88 RMM, SURE Dreadnaught/Juggernaught, Whiteline RSB, MD OCC, IM/TB TIGs, Battery Relocate, Trunk Monkey, ITV 22s, Rotella T6, Eibach Pro kit springs, Powerslot rotors, Hawk HP+ Pads, SS lines, 18x8.5 +42 Focal F16s, 235/40/18 NT05s
"Eyes for an eye, Teeth for a tooth."
MS6FL is offline   Reply With Quote
 Old 09-09-2012, 04:02 AM   #5
EmPeEs6's Avatar
Yes, it's the drivers side!
 Old 09-10-2012, 07:40 AM   #6
EmPeEs6's Avatar
It seems that the rattling is because of the release bearing and flywheel of my new 6 pad ACT clutch.
The Following User Says Thank You to EmPeEs6 For This Useful Post:
MS6FL (09-10-2012)
Strange Heat / AC Sound 3Sleeper 2010 MS3 - Engine, Transmission & Driveline 19 11-07-2012 08:59 AM
Funny rattling sound KRheeder MazdaSpeed 3 - Engine, Transmission & Driveline 6 04-07-2012 02:40 PM
Strange Sound RacerX 2010 MS3 - Troubleshoot/Diagnostics 5 12-15-2011 10:02 AM
Odd rattling sound... jman46 MazdaSpeed 3/6 - Suspension & Brakes 7 07-29-2011 02:44 PM
Strange sound from rear of car kgb MazdaSpeed 3 - Engine, Transmission & Driveline 5 09-24-2009 10:39 AM
Page generated in 0.28214 seconds with 22 queries
