  • 1 Post By shamie
 Old 05-16-2018, 05:47 AM   #1
danb's Avatar
Posts: 148   (View Stats)
danb is a splendid one to beholddanb is a splendid one to beholddanb is a splendid one to beholddanb is a splendid one to beholddanb is a splendid one to beholddanb is a splendid one to beholddanb is a splendid one to beholddanb is a splendid one to behold
Default swapped gen 2 motor issue
swapped a gen2 motor into my gen1 and loaded the base map from my tuner. Car starts hard and will die out until it is warmed up.
Mods are SU tmic, HTP 3inch intake, CS turbo, CS ebc set to interrupt per tuner, CS 3.5 map, turbosmart kompact bpv.
Here is a log of a start and idle. spark advance is jumping around and im not sure what is causing it...
Thank you for any knowledge you can shed on this!!
2007 speed3 GT. cobb rmm, JbR pmm, twm solid shifter bushings, AP3, Autotech, corksport turbo, HTP 3.5, Depo catless dp, Turbosmart Kompact bpv, Corksport 3port, cpe BlockD, Guardian Angel V3, DO DVC-30, SU TMIC Freektune 93 and e85 maps
2011 mazda 6 95k. wifes ride
danb is offline   Reply With Quote
 Old 05-16-2018, 06:23 AM   #2
shamie's Avatar
Posts: 923   (View Stats)
Check both your crank and cam position sensors and their connections.
danb likes this.
2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, 51R Battery Box & Raider's AD / StopTech Brakes
 Old 05-16-2018, 07:10 AM   #3
danb's Avatar
Thats exactly what i was thinking the problem was and was going to be checking tonight. Thank you for the help!!
 Old 06-14-2018, 02:21 PM   #4
danb's Avatar
Was fixed with next map revision. Must have been a maf cal, I did put on a HTP 3" intake. Running very nice now
Seeking advice on motor issue mac_ Mazdaspeed3/6 General Discussion 1 03-20-2015 09:56 AM
Motor mount thread issue ziwang55 MazdaSpeed 3 - Engine, Transmission & Driveline 39 04-04-2012 06:29 PM
AWR passenger motor mount issue ? jracer MazdaSpeed 6 - Engine, Transmission & Driveline 3 10-13-2011 11:04 PM
passenger motor mount issue? cageyvet MazdaSpeed 3/6 - Big Turbo Builds 2 07-24-2010 03:23 PM
Can ecu's be swapped? CraigHJr MazdaSpeed 3/6 - ECU Computer Tuning 3 11-19-2008 09:36 PM
Page generated in 0.24805 seconds with 22 queries
