 Old 08-03-2018, 11:54 AM   #1
07MS3TrueRed's Avatar
Posts: 22   (View Stats)
07MS3TrueRed is an unknown quantity at this point
Default Timing Issue
Hey guys I'm new to the forum, only just picked up my Speed3 a few weeks ago.
The car is an 07' and has 113,000km, and had the motor rebuilt at 110,000 at what I thought was a reputable shop in my city but am starting to have my doubts. When I had the car inspected I was told by the garage that it was leaking oil around the basepan so I dropped the pan and the car still leaked oil around the bell housing area so I diagnosed it as the rear main seal based on information I found here.
I just finished hauling the motor/transmission out and changing the seal this past weekend and the leak has stopped. However when I was unplugging everything on the wiring harness I had trouble unplugging what I realized afterwards was the crankshaft position sensor. Being stupid I removed the sensor to unplug the harness and almost immediately realized what it was and put the sensor back in place immediately. I put the sensor back to it's original position to the best of my ability using a light to see the exact position of the bolts on the sensor based on the dirt on the part. The car starts and runs just fine but doesn't have as much power as it should. I have a Cobb accessport and the virtual Dyno says I'm making 186whp. So I'm wondering is it possible that if that ckps is ever so slightly off will it cause this much of a lack in power? If so can a custom tune curb the issue or does the motor need to be re timed?
I'm going to get a compression tester in the next couple days to check the compression because I'm starting to wonder if the rebuild was a bad job or not a proper break in, and the rings might not be set properly.
The car had these mods when I bought it : magnaflow 3.0" exhaust, Mazdaspeed intake, hks blow off valve vta (I've read this is a controversial setup for these cars)
I added autotech fuel pump internals when I took the motor out because I had a clogged cat code so I gutted the primary cat and installed the internals as a safe measure. I loaded up a stage 2 ots Cobb map but again the car doesn't seem to be making the right power, so I haven't been driving it hard.
Any answers would be great, thanks in advance.
07MS3TrueRed is offline   Reply With Quote
 Old 08-03-2018, 02:21 PM   #2
Thor Hammer's Avatar
Posts: 1,788   (View Stats)
Groans: 203
A data log would be very helpful. Without that it could be 100 different things.
If the CPS was off it would run like shit. I'd check the obvious. Boost leak test, EBCS and line integrity, etc.
07MS3TrueRed (08-05-2018)
 Old 08-03-2018, 09:16 PM   #3
mazda62006's Avatar
Posts: 53   (View Stats)
mazda62006 is a name known to allmazda62006 is a name known to allmazda62006 is a name known to allmazda62006 is a name known to allmazda62006 is a name known to allmazda62006 is a name known to all
Groaned at 4 Times in 2 Posts
I would check the position of the sensor. It may be off a little. There are direction in the shop manual on correctly setting the crankshaft position sensor. Check it first.
mazda62006 is offline   Reply With Quote
The Following User Says Thank You to mazda62006 For This Useful Post:
 Old 08-04-2018, 04:56 AM   #4
Yeah that's what I was thinking, the car definitely doesn't run like shit, it's nice and smooth no stammering/jolting/shaking. I'll have to do a data log today and post it up. Before I removed the motor I had a very obvious boost leak, a real shrill squeel when I hit 15psi, and I did a test with soapy water and found the throttle body gasket was leaking, replaced it and the squeel was still there. However when I took the motor out and reattached all hoses etc on the install the squeel went away so not sure what it was. I'll have to do a boost leak again to see if I can find anything but I never seen any hoses in bad condition when I was working on the car.
I'll have to check in the manual and have another look at the sensor. I did double check the position of the sensor against the dirt on it again the next morning and did do a slight adjustment to it before finishing the motor removal.
Thanks for the responses.
 Old 08-04-2018, 07:24 AM   #5
Police - Grammarhead
Vansquish's Avatar
Groans: 1,838
FYI, the "Dyno" on the Cobb AP is absolute garbage and 100% inaccurate. It is so inaccurate in fact that it cannot be used to produce consistent results pull after pull, and certainly should not be used as a means of gauging whether changes you have made are working.
 Old 08-04-2018, 07:26 AM   #6
Fstrnyou's Avatar
Posts: 2,205   (View Stats)
Wouldn't hurt to hit up a local to see if you can borrow the timing tools.
Preliminary, all you'll need is the crank TDC pin to verify the sensor is in the right place. If you prefer, you could dig deeper with the cam alignment plate to verify your cams are aligned with the crank.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
The Following 3 Users Say Thank You to Fstrnyou For This Useful Post:
07MS3TrueRed (08-05-2018), 5doorsoffury (08-05-2018), Vansquish (08-04-2018)
 Old 08-04-2018, 09:51 AM   #7
I definitely take the Cobb Dyno with a grain of salt. However just comparing my butt Dyno to the car I just upgraded from, an 08 Mazda 3 GT, it doesn't feel like it's making the right amount of power. I've also driven two other first gen speed 3's with minimal mods and they were definitely quite a bit faster.
I may have to borrow the tools, the shop that did the machining on the motor mentioned that they had the special tools for timing this motor when I went back to complain about the rear main seal lol. So the least they can do is let me use those tools.
 Old 08-04-2018, 11:37 AM   #8
Vansquish's Avatar
Groans: 1,838
The Cobb AP Dyno should not even merit a grain of salt. It is so incredibly inaccurate and inconsistent that it will not tell you anything useful at all. If you want to track your progress with a virtual dynamometer, use "virtual dyno". At least that will produce reasonably consistent results across similar pulls. Moreover, you should be data logging and reviewing the results of those data logs to help you diagnose what is wrong with your car.
Additionally, if you just had the motor rebuilt by a shop, and there were oil leaks at various different spots around the engine, I would be looking into their warranty. If they fucked something up during the rebuild/install, it seems like they should be fixing it at their expense, not yours.
 Old 08-05-2018, 12:57 PM   #9
Here is a datalog as requested. Also unfortunately the previous owner was the one who had the car rebuilt so its hard for me to kick up too much of a stink about it. I did go to the shop though and they offered me no help because they only did the rebuild on the short block and did not remove or install it. But since I split the bell housing and motor and took pictures of the leakage of the rear main seal I will be going back to see what they have to say. They were trying to tell me the leak could have been this, this, and that trying to say that it has nothing to do with their work.
Again if somebody has a chance to look at the log it would be greatly appreciated. I noticed that the tunes on the AP are not current (v234 I think) as they were the ones on there when I got the car so Im going to load up the current stage 2 tune (v250) and see if it will help at all and hopefully I can get a better log.
 Old 08-05-2018, 02:59 PM   #10
Datalog :
 Old 08-05-2018, 03:37 PM   #11
5doorsoffury's Avatar
Posts: 1,075   (View Stats)
Groans: 74
There are a few threads that show you how to make your own TDC bolt. Check the alignment and call it a day. TDC then count back 20 teeth from the gap and align the 20th one to the center of the CPS.
MECP
2012 BM
Rfinkle tune in progress
The Following User Says Thank You to 5doorsoffury For This Useful Post:
07MS3TrueRed (08-11-2018)
 Old 08-10-2018, 09:37 PM   #12
ZeroDCX's Avatar
Posts: 5   (View Stats)
ZeroDCX will become famous soon enoughZeroDCX will become famous soon enough
This!
Also while the timing tool (TDC Pin) is in and cylinder #1 is at TDC, ensure the crankshaft pulley pin hole is lined up with the bolt boss aka ensure the crankshaft pulley is timed to the crankshaft at TDC.
ZeroDCX is offline   Reply With Quote
The Following 2 Users Say Thank You to ZeroDCX For This Useful Post:
07MS3TrueRed (08-11-2018), 5doorsoffury (08-11-2018)
 Old 08-11-2018, 05:25 AM   #13
I checked the CPS position after with a tdc pin and it was off by a cunt hair... Lol so I fixed it but it didn't seem to make any difference. So I did a compression test and my readings we're 185/182/185/181 so I think in good here as well. However I did another boost leak test and my egr was leaking. I was very confused as to how the egr could be leaking so I took the EGR valve off and cleaned the valve inside so it would seat better, I figured it was stuck partially open (I have my egr unplugged). After I cleaned it and did another boost test it was still leaking slightly and I came to the realization that the pressurized air from the intake manifold was coming back through the EGR tube and leaking on the two bolt flange on the EGR side of the tube. It seems as if all of those rubberized metal gaskets on my car are leaking. The ones I have noticed since I pulled this engine out are the throttle body gasket, turbo oil drain seal turbo side, and now this egr gasket. So I guess I'll have to try to source the EGR gasket and buy a block off kit and get rid of that tube all together.
 Old 08-11-2018, 07:25 AM   #14
Groans: 74
I would just delete the egr its 20 bux on the high end and reversible. Well at least you know comp and timing are spot on. You could try a leakdown test. Do you have a main cat?
Maby its in your head how do you know you are slower. Compare a now and thne log for 60 to 100 times.
MECP
2012 BM
 Old 08-11-2018, 08:13 AM   #15
Yeah I might just fully get rid of the EGR haven't decided yet. And once that leak is fixed then I will see how it is from there and I guess a leakdown test will have to be my next step if it's still slow. I have a gutted main cat and stock secondary cat. I know I'm slow because I did a point to point second gear rolling pull in my 08 2.3 Mazda 3 GT and in the Speed3 to compare and I was only 8 km/h faster in the speed lol which is definitely not right. I tried shifting at 5k and shifting at 6k in the speed and it made no difference I still went the same final speed. I also can't even chirp the tires with dsc off and haven't had any torque steer whatsoever so something is definitely not right. In the log I posted on here it took me 6 seconds to get from 5-6k rpm in 4th gear, that seems awfully slow to me.
 Old 08-11-2018, 12:29 PM   #16
Carskick's Avatar
Posts: 282   (View Stats)
Just for fun, I ran your datalog through the Vdyno. Don't know your tire size, temps, and pressure, but close enough. But you're right, your running really slow.
Your AFRs are pretty rich, but that shouldn't be causing this much power loss. I'm pretty sure the Cobb Stage 2 doesn't run that rich. Also, as rich as you are, you definitely shouldn't be getting that much Knock Retardation.
Did you check the timing and if so, what'd you find? What turbo are you running?
I think you're on the right track suspecting something with the valvetrain...
2009 Mazdaspeed 3 Sport (Original Owner) - 93k miles and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC | SpeedDaddy TP | AT HPFP | Damond RMM | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | Koni STR.T Shocks | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold Fronts | Focal Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: Low Note Additional Horn
Mods Awaitting Install: Bilstein B16 Coilovers (Back Ordered) | Whiteline Bushings, Anti-Lift, & Bump Stops | Whiteline Endlinks | JBR 125 Sway Bars & upgraded bushings/mounts | DM RMM & PMM | JBR TMIC Red Boost Tubes | DM OCC w/VTA
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM
The Following User Says Thank You to Carskick For This Useful Post:
 Old 08-11-2018, 12:33 PM   #17
Fstrnyou's Avatar
Stock fueling is pretty rich to begin with. Getting into the 9's might not be too far fetched with bad knock.
Other rides:
History:
 Old 08-11-2018, 12:47 PM   #18
Carskick's Avatar
But he said he's on Cobb Stage 2 v2.50, I thought that was leaner than stock. I wondered the same thing, but then I saw he said his tune.
EDIT: Correction, he was on Cobb Stage 2 v2.34 and said he'd upgrade to v2.50. Either way, I think Cobb Stage 2 targets high 11s if I remember right.
 Old 08-11-2018, 02:09 PM   #19
Fstrnyou's Avatar
Ah sorry. I missed that.
Other rides:
History:
 Old 08-11-2018, 03:44 PM   #20
Groans: 74
All of the knock is robbing you of timing and decent afr so thats going to take power away to. I ask about the cat because if it is clogged it will make you slow. Maby fucking with it knocked shit loose and clogged the cells. Try unbolting the second cat and do a loud run.
Put a gallon of e85 or meth in the tank and see if the knock goes away. I bet some e85 and unbolting the second cat will make you faster.
A leakdown test will check the head for leaks
MECP
2012 BM
07MS3TrueRed (08-30-2018)
 Old 08-11-2018, 03:49 PM   #21
Thanks for taking the time to have a look at that datalog. That was on v234 and I have a new datalog with v250 now loaded up and after fixing part of my boost leak. AFR's are higher now, but I'm definitley getting some knock.
 Old 08-11-2018, 03:56 PM   #22
Just seeing your other reply, do you think the quality of gas could cause that much knock? I've been talking to poeple in my area and they recommend getting gas from a different brand station has helped with knock for them. I live in Newfoundland, Canada and the best we have here is 91oct at the pump unfortunately.
 Old 08-13-2018, 08:00 AM   #23
Carskick's Avatar
I doubt that would cause that much loss of power. A knock event of 2-3 just pulls a few degrees of timing. It's not nearly enough to drop from 250WHP to 160WHP. In fact, before I tuned & upgraded, I tried the Cobb Stage 1 with only a HPFP in place. I got a 1.5-3 KR throughout the range (I had an intake leak issue at the time, too), and still held 200-240whp is the upper mid RPM range, and that was with it only getting to about 13-14psi of boost.
Something is not right...
 Old 08-13-2018, 08:09 AM   #24
Carskick's Avatar
Just checked your new log. Yeah AFR are more in line with what I would expect with your tune and excessive KR detection. This log is showing the KR far worse. Maybe it is the gas, but it'd have to be horrible gas to product that result. Even using 87oct shouldn't look THAT bad.
Have you done a compression test? Maybe the engine itself has some bad leaks. You've got plenty of boost and air passing the MAF. Fueling looks good. My money's on something inside the block being just not right...
 Old 08-13-2018, 08:47 AM   #25
Compression is good, I still need to to fix the boost leak coming from my egr tube. I'll see how the car is after that and I switched brands of fuel on this tank. Might have to do a leakdown test.
 Old 08-13-2018, 09:37 AM   #26
Fstrnyou's Avatar
As mentioned, add some E85 or Meth to the tank. If knock persists, you have mechanical issues.
Other rides:
History:
 Old 08-13-2018, 10:01 AM   #27
So just pour a gallon of methyl hydrate from home Depot right in the tank when I fill up? Or what kind of ratio do I mix?
 Old 08-21-2018, 01:33 PM   #28
I switched to a different brand of fuel and noticed decreased KR, then I also added methanol and found it decreased even another bit again. No KR at WOT, and 6.5 maximum spikes at partial throttle. After that I sealed my egr to get rid of my boost leak, and switches to ITV22's and my partial throttle KR went up to 7.3/7.5 maximum spikes at partial throttle but still 0 KR at WOT which to my understanding is the only time KR really matters. But the car runs good now a bit quicker each time I make a change. However I think the comment on the possibility of a clogged second cat is correct because my heat shield around the second cat is all melted and the aluminum foil type outer later is completely peeled back revealing the fibre layer underneath. So should I gut the second cat? Or will having both cats gutted cause too much turbulence or boost spikes, I have a magnaflow 3" catback.
 Old 08-21-2018, 01:56 PM   #29
Carskick's Avatar
Or just buy a test pipe, such as a cheap Speed Daddy, which run about $60. That being said, the sheathing around the exhaust can come off for other reasons, such as driving through deep water.
 Old 08-26-2018, 02:22 PM   #30
This is the best datalog I have been able to get recently. KR readings starting at 4900ish RPM, should I be worried about this? I was reading some other threads about high RPM KR readings and some people were saying not to worry too much about it because it could just be engine noise, but is that still true if I'm seeing readings of 5.6 KR?
I uploaded the log to virtual dyno and it seems like my HP is flatlining at about 4100 rpm and TQ also starts to drop off about the same time. This log is with 91 octane fuel, no added methanol. I also forgot to mention at some point in this thread that the turbo on the car was replaced by the previous owner and it looks like an ebay K04. Is this my biggest problem? Or is there something inside the motor I should be looking into? I will try to do a run soon with my second cat unbolted to see if that free's up the car much.
 Old 08-26-2018, 02:29 PM   #31
Fstrnyou's Avatar
Knock, whether real or not, adds fuel and pulls timing. This kills power to save the engine.
By adding methanol, your KR went away. So you have real knock. The only thing to do here is verify AFRs are correct, BATs aren't crazy high, and ignition timing isn't too agressive.
Other rides:
History:
 Old 08-27-2018, 12:20 AM   #32
Solarsurge's Avatar
Posts: 570   (View Stats)
91 octane gas is garbage, especially in the summer. As for the heat shield being melted, it doesn't take much. Aluminum melts at around 1200F and a cat's NORMAL operating temp can reach up to 1600F if you're running crappy gas. It doesn't have to be clogged to get that hot. As for being mangled, I think I have one of the only fully bolted Speeds on Earth with a 100% intact heat shield. Literally everyone else I know's heat shields are mangled AF. The secret to success is not using shitty gas, being meticulous and careful when modding, and never letting me do your electrical wiring.
 Old 08-27-2018, 06:59 AM   #33
Groans: 74
I would bet on a ebay turbo being shit. If the knock went away with the meth then it is not mechanical as the other poster mentioned.
Unbolt the second cat and do a run with some meth and if you are still down on power i would take a look at the turbo.
That log looks fine afr isnt bad just a big knock event higher up. You are just slow.
Compression is good, timing is good and if the motor is flowing air (check for clogged cat) then the last thing to consider is the turbo assuming the tune is good as well. Ebay equipment is as trustworthy as a drunk slut at a batchorlet party. Why do you think it is a ebay turbo.
MECP
2012 BM
 Old 08-27-2018, 09:33 AM   #34
Carskick's Avatar
So even if the logs are showing it holding boost fine, could it still be a bum turbo? It appears holding boost with a reasonable amount of wastegate. I'm curious how it runs without the cat in place. If the cat is clogged, you might still hold boost and flow air, but pumping losses would be much higher resulting in lower power, exhaust getting back into engine, etc. I'm thinking it's something exhaust. But we'll see...
 Old 08-27-2018, 06:01 PM   #35
Groans: 74
G/s is a poor indication of hp. Boost is the resistance to flow so why not. Unless he is towing something or bringing his fat friend and 2 fat as fuck dates along for the logs idk what else to say. Not like there is anything wrong with fat chicks. When you close your eyes everyone's mouth feels the same. There good at eating so there talented with stuff like that. What were we talking about again?
MECP
2012 BM
The Following 2 Users Say Thank You to 5doorsoffury For This Useful Post:
07MS3TrueRed (08-30-2018), Db09ms3 (08-31-2018)
 Old 08-28-2018, 07:43 AM   #36
Carskick's Avatar
Db09ms3 likes this.
 Old 08-30-2018, 08:26 PM   #37
I will try to get a log with my second cat unbolted and methanol in the fuel next week and let you guys know what happens.
I took another log and tried to rev the car higher to see if the knock persisted not and it stopped after about 5800rpm. The car really feels like it falls on its face at about 4500rpm and it stutters and feels like its making no power as you can see from the chart in Virtual Dyno. Thats with no fat chicks in the car hahaha just me and my girlfriend on this log, all previous logs was just me in the car. Also I believe it's ebay because besides a P/N and S/N on the turbo plaque it just says "turbocharger" lol. Sorry for this log being in metric I changed it to display speed in KPH and forgot to change it back.
I really want to get the car etuned but I dont want to waste my time or the tuners time if the car is not mechanically ready. Also I couldn't pull on a 9th gen SI the other day on the highway so that really says something for how much power the car is making lol.
Also is it possible that VVT isn't activating? I'm very unfimiliar with how the system works in this car and I'm only assuming the previous owner replaced the actuator when doing the timing. I dont get any rattles on start up.
 Old 08-31-2018, 03:32 AM   #38
Groans: 74
The knock sensor turns off after 5800 rpm. I would do some reserch on that turbo. If you really have a pos ebay turbo I wonder what other questionable choices the PO made..... take some pictures of it. Check the turbo out for shaft play ect...
Do you have a log of when you thought the car was "faster" before you fixed the rms?
Oh and FYHN I wouldnt go around letting people know you got pulled in by a civic.
MECP
2012 BM
 Old 08-31-2018, 06:48 AM   #39
I attached a photo I took of the turbo when I removed the engine. The turbo is brand new along with the rebuild, I checked it and it has no shaft play, model is K0422-882. I don't have any logs before I did the rear main seal because the motor was still in break in at the time. Also I never got pulled on by the Civic I just couldn't pull on him hahaha it was dead even, still sad.
 Old 08-31-2018, 07:15 AM   #40
Solarsurge's Avatar
A quick google search of the part number and it was pretty easy to find out it’s an XS-Power turbo “upgraded stock replacement” from Amazon.
Dealer Issue - Timing marti74f MazdaSpeed 3 - Engine, Transmission & Driveline 17 01-08-2018 02:44 PM
Please verify timing chain issue mick88 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 12-17-2014 02:27 PM
VVT and Timing chain issue for most Speed3s? sj9ers Mazdaspeed3/6 General Discussion 4 08-29-2014 04:47 PM
Page generated in 0.88711 seconds with 29 queries
