 Old 12-02-2019, 10:43 AM   #1
grammates's Avatar
Posts: 9   (View Stats)
grammates is an unknown quantity at this point
Default Weird idle during neutral
So recently on my 08’ speed I’ve been having some issues one of them being that my idle has been weird lately. Specifically like in the video if I’m driving and coming up to a stop I can throw it into neutral and it will hover over 1000 rpms and bounce around like I’m downshifting through the gears. Once I come to a stop it levels out. I also keep getting the check engine light for (too lean at idle)
08 speed
HPFP INTERNALS
AEM cold air intake
Rear motor mounts
Cobb
Stratified tune
Sorry if this isn’t the right format etc I’m a newer member!
Link to video (https://imgur.com/DnuFb6j)
grammates is offline   Reply With Quote
 Old 12-02-2019, 11:34 AM   #2
Police - Grammarhead
Vansquish's Avatar
Groans: 1,906
08 speed
HPFP INTERNALS
AEM cold air intake
Rear motor mounts
Cobb
Stratified tune
What you're describing sounds like a classic vacuum leak. You should check all of the couplers and clamps from your intake all the way to the turbo, and from the turbo to the intercooler, and from the intercooler to the throttle body. Make sure all the clamps are secure and that the hoses aren't pinched or cracked.
In addition, you should check all the vacuum hoses running to and from the EBCS, as well as the VTCS actuator to make sure that they're all connected properly and that there are no cracks in any of the hoses or their connections.
Weird idle in neutral and TERRIBLE gas mileage 08 grammates MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 11-05-2019 03:19 PM
Just got the Car Weird Noise at Idle Mashaustin 2010 MS3 - Troubleshoot/Diagnostics 13 02-11-2018 10:26 PM
Neutral trans noise at idle 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 21 08-20-2013 07:42 PM
Weird idle mrdouble99 MazdaSpeed 3 - Engine, Transmission & Driveline 53 07-30-2013 12:41 PM
Weird idle...but maybe never noticed it Chompsspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 3 11-03-2009 11:59 AM
Page generated in 0.24038 seconds with 21 queries
