| MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() | | | LinkBack | Thread Tools | Display Modes | ![]() |
![]() | | #1 | ![]() |
| mmmmm...BOOOOST!! ![]() Join Date: Oct 2008 Location: Orlando/ Daytona Beach
Rep Power: 124 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 215
Groaned at 10 Times in 9 Posts
| Not Ranked : 0 score
So today i was doing some WOT pulls for my e-tune and my CEL came on. So i checked it out and i see the normal o2 slow sensor response and no o2 sensor activity stuff (im catless by the way so that explains those codes) but then i scroll down and see P0030: HO2S Heater Control Circuit (Bank 1 Sensor 1). I never seen this in my life! I looked up the code and doesn't give much more detail than that! I think its the heater system but i dunno what! I was using the heater while i was doing the pull cause its like in the 20s here this morning but still shouldnt be an excuse for the CEL. Anyone have any ideas?
__________________ 09 CWP Speed3 GT- CP-e Nano, Speedie6 TIP, CP-e Catless Downpipe, ED FMIC w/ GodSpeed core, Devils Own Stage 2 Meth Injection Kit, KMD v2 fuel pump internals, HKS BPV, SU full motor mounts & shifter bushings, Cobb Springs, 1 res delete in cbe, HID Fogs, AutoMeter Cobalt boost gauge, Michi OCC, Denso 1 step colder plugs, MSD DH, COBB AccessPort V105 Stage 2+sf 93 fmic [Today 11:50 PM] aaronc7: i just measured mine, a little over 12 | ||||||||
![]() ![]() Join Date: Jul 2008
Rep Power: 172 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
Um...Id check all fuses...see if it popped one. Is your heat working? Might have to take it to the stealership
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
Damn that was fast man lol! Yep everything was working! I check some fuses tomorrow but if it still works then i doubt any of them blew out!
![]() | | #4 | ![]() |
![]() Join Date: Mar 2009
Rep Power: 56 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 73
I have the same problem with my car except my CEL is intermittent. I first thought it was the heater as well but then a friend told me that new o2 sensors have a heater circuit in them. The o2 sensor itself works fine and reads afr's fine but for whatever reason the heater circuit is not working.
__________________ Murdered out 2007 speed3 GT with navi. | ||||||||
| The Following User Says Thank You to mtnrunner For This Useful Post: | wakeboarddude (02-19-2010) |
![]() | | #5 | ![]() |
![]() Join Date: Mar 2008 Location: NC
Rep Power: 823 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 525
That code is for the warm up heater in the wideband O2 sensor.. If the heater fails entirely, the sensor itself will fail a short while later...
__________________ My car has issues.... | ||||||||
| The Following User Says Thank You to SSinstaller For This Useful Post: | wakeboarddude (02-19-2010) |
![]() | | #6 | ![]() |
| Alittle Faster ![]() Join Date: May 2008 Location: Cape Coral, FL
Rep Power: 1524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,298
Sensor #1 is getting to hot or not hot enough. It needs to be between a certain temperature range. Does EGT's get high without CATs or with CATs?
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
| The Following User Says Thank You to bioevolve For This Useful Post: | wakeboarddude (02-19-2010) |
![]() | | #7 | ![]() |
Damn so if it's a problem with the o2 sensor and I'm already getting those two other CELs then it is in fact on it's way out! Well I hope it isn't! So any possible fixes or just wait till it goes out and get a new one! I'm guessing it's the 2nd o2 also!
![]() | | #8 | ![]() |
Bank 01 sensor 01 is the OEM wideband. You will sometimes get the slow response MIL if your using anti-foulers to try and fix the cat efficiency MIL. Running catless will not cause the "no sensor activity" that your seeing, that's an entirely seperate problem..
![]() | | #9 | ![]() |
Weird thing is that im not using any ani-foulers or anything. I just put the o2 sensor sraight in the pipe. Its been 2 days now and not seeing anymore codes so i dont think its a huge problem yet but could be soon. SS what do you think could cause the "no sensor activity"? And from the CELs i've been having, does it realate to the primary or secondary o2 sensor? or both?
![]() | | #10 | ![]() |
The codes refer to both sensors. If your not running an anti-fouler in the rear sensor, it's possible you have a problem with that one as well... They may have been damaged when you swap your DP..
![]() | | #11 | ![]() |
Damn well that sucks! Whats weird is they only have been coming up in the past couple months. Ive had my DP in for almost a year now. And they only come up when im driving pretty hard or when i do about 10 WOT pulls in a row! Question though. If this means that they are failing, would that mean they are not giving accurate readings for AFR? AFRs look normal but if they are registering a different value then actual then that would throw off the whole ecu from accurate readings!
![]() | | #12 | ![]() |
So this CEL is coming on now almost everyday. I played around with the wires that hook on to the first 02 sensor and still nothing..i looked in the shop manual and it doesnt give much to diagnose and cure the problem. Im thinking i might have to change out the first 02 sensor which i really dont wanna do! but if anyone has any other suggestions..it looks like it might be my only option. i also read that the CEL is really just an emmisions thing. think it'll be bad if i just leave it?
![]() | | #13 | ![]() |
The secondary O2 isn't as important(it's used only to adjust the calibration of the primary O2 sensor and to monitor the cat), but you should still replace it when you get the time/spare cash...
__________________ My car has issues.... | |||||||||
![]() | | #14 | ![]() |
Well that sucks! By any chance do you know were i can find that o2 sensor for cheap. I looked at the Bosch part # from haltechs dp review but apperently it doesnt exist. Called them up and they found another that crossed with that P/N but its for a regular 3! Anywere else i could find one. lol def not paying 200 for a new oem one from the dealer! thanks for all your help man!
| Thread Tools | |
| Does your A/C compressor kick on with the heater? | Wishbone | MazdaSpeed 3 - Engine, Transmission & Driveline | 13 | 12-15-2009 06:16 PM |
| Wastegate control, Boost spikes, PID control | FreeFlyFreak | Cobb ATR Support | 83 | 11-05-2009 11:40 AM |
| Recurring CEL: PCM 2006 APV Motor Control Circuit IC Problem | bast525 | Cobb Access Port/Maps | 1 | 03-06-2009 06:43 AM |
| Ending Circuit City Coupon Code 5% to 15% off HDTVs, Digital Cameras, GPS, MORE at Circuit City | Haltech | Hot Deals Section | 0 | 04-12-2008 05:10 AM |
