Notices
Like Tree2Likes
  • 1 Post By SWAY
  • 1 Post By karl-hungus
 Old 02-02-2012, 09:08 PM   #1
blue_train's Avatar
Posts: 61   (View Stats)
blue_train is just really niceblue_train is just really niceblue_train is just really niceblue_train is just really niceblue_train is just really nice
Groaned at 9 Times in 4 Posts
Default wtf is wrong? stuttering to the point of not being able to drive??
Need some help here,
so a week ago im driving to my mechanic shop to get my ecu cable fixed (AP would not connect), I warm her up and about 10k into my trip I give her a little blast around 3500rpms in 4th and wham, all the sudden the car starts to jump/studder, like im riding the droping the clutch ever 2 seconds, I pulled over, and shiut her down, started it back up 10 mins later and it was still doing it lightly, so i was going to try and drive to the shop and all the sudden it stops, I drive like a granny to the shop and he jumps in to test it, I do a full run into 6th,m woting all the way and it was fine, so he plugged in his computer (after fixing the cable) and it showed nothing. so I FINALY link up my AP, set my map, and she was pulling like hell, no problems....
Today, Im pissing around and I decided to giver her a little bit in boost, wham, same thing has happened. this time worse, It took me 20 mins to drive 5 k.
can anyone help me? Im really new to turbos.
mods are CIA, and AP.
please help!
blue_train is offline   Reply With Quote
 Old 02-02-2012, 09:11 PM   #2
McGee's Avatar
Posts: 402   (View Stats)
McGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the worldMcGee is the leader of the world
Groans: 27
sounds like a bad ignition coil
McGee is offline   Reply With Quote
 Old 02-02-2012, 09:16 PM   #3
blue_train's Avatar
How do i find out for sure, I mean if its not showing on the computer, fml
 Old 02-02-2012, 09:22 PM   #4
McGee's Avatar
Groans: 27
test it. You might get the shit shocked out of you though. that is weird that it's not throwing a cel
 Old 02-02-2012, 09:26 PM   #5
SWAY's Avatar
Posts: 2,406   (View Stats)
SWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the world
Groans: 190
Groaned at 59 Times in 42 Posts
Sounds like what was wrong with mine, the spark plugs were gapped wrong for my setup. Have you touched your plugs, try out the coil mod might help.
~2011 Liquid Silver MS3~
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
SWAY is online now   Reply With Quote
 Old 02-02-2012, 09:34 PM   #6
blue_train's Avatar
no i have not done anything, how do I do the coil mod? forgive me im uber newby
 Old 02-02-2012, 09:47 PM   #7
RdotQelo's Avatar
Posts: 236   (View Stats)
RdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the world
I had a problem like that in my tiburon when I had it. Gave it gas, and that joker stuttered through first until I shifted into second. I couldn't really accelerate aggressively without shaking it to pieces. Noticed a fuel smell coming in when I used my vents, ended up being the plugs.
AP | Autotech Internals | CS SRI/TIP | JBR 88a Molly RMM | JBR SSP w/bushings
RdotQelo is offline   Reply With Quote
 Old 02-02-2012, 09:54 PM   #8
blue_train's Avatar
hmm, Ya i noticed a smell like rotten eggs? fuck so I should replace the plugs?
 Old 02-02-2012, 10:00 PM   #9
SWAY's Avatar
Groans: 190
coil mod is on here somewhere i have no idea might find it with a lil search, its easy just pull the coil and stretch it rfinkle2 could tell you exactly. I would check the plugs and the gap on them should be around .28 or .30 stock, no need to replace them unless theyre worn though.
The Following User Says Thank You to SWAY For This Useful Post:
rfinkle2 (02-03-2012)
 Old 02-03-2012, 06:37 AM   #10
RdotQelo's Avatar
This.
 Old 02-03-2012, 06:40 AM   #11
rfinkle2's Avatar
Posts: 12,563   (View Stats)
Groans: 235
stock gap = .032
itv 22 gap = .026 - .028
When you stretch the coils, only stretch the ends (you'll notice the ends are less densely coiled).
CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R)CPE HPFP CPE RMMCPE FMICCPE TOW PLATE CPE TRITON CBE HTP 3" TIP HTP BATTERY RELOCATECOBB APGRIMMSPEED 3 PORT BCSCOOLING MIST / DEVILS OWN METHANOL INJECTIONDEFI Boost gauge TWM FULL REPLACMENT TWM M1 ABRAMSJBR SSP JBR RSB JBR TIG H&R COILOVERSJUMPING JACKSON 3 BAR MAP HARNESSSTOPTECH STAINLESS LINESAKEBONO EURPO 915aTANABE STRUT BRACENEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KITGRAM LIGHTS 57 DRTOYO PROXES PLUS
deadlandxtreme (03-30-2012)
 Old 02-03-2012, 06:42 AM   #12
predapio's Avatar
Posts: 7,218   (View Stats)
Groans: 165
Groaned at 139 Times in 88 Posts
As a general rule if the car is stuttering you shouldn't be doing WOT runs.
That's a good way to end up picking up pieces of your block, off the highway.
What a lovable bunch we are!!
The Following 6 Users Say Thank You to predapio For This Useful Post:
chimmike (02-03-2012), deadlandxtreme (03-30-2012), karl-hungus (02-03-2012), rfinkle2 (02-03-2012), ScarMS3 (02-04-2012), uncorked11 (02-04-2012)
 Old 02-03-2012, 06:48 AM   #13
anavrinIV's Avatar
Posts: 2,086   (View Stats)
Groans: 35
Groaned at 25 Times in 14 Posts
How to stretch your coils
I haven't done it, but there's the how to. And while you're doing that you can pull the plugs and check them over.
2007 Black Mica MS3
Go Fast Bits: Tune in progress - AutoTech HPFP Internals - 3.5" JBR WP - CP-E Catted Downpipe - HKS SSQV3 VTA - CNT CBE- JBR EGR Block-off - TB TIG - IM TIG - Ported Stock Intake Mani - NGK Step Colder Plugs - Treadstone TR8L FMIC Core - Custom FMIC Piping
Cornering: Koni Yellows - JBR Rear Sway Bar - TR Motorsport C3s - 5mm Front Spacers
Shifting: JBR SSP/Solid Bushings/Counter Weight - JBR 88a RMM - JBR 70a PMM - JBR 70a TMM
Fiddly Bits: WOLO Model 417 Long Horns - JBR OCC - Spin-on Filter Conversion
The Following 2 Users Say Thank You to anavrinIV For This Useful Post:
deadlandxtreme (03-30-2012), rfinkle2 (02-03-2012)
 Old 02-03-2012, 06:51 AM   #14
rfinkle2's Avatar
Groans: 235
A rotten egg smell is a definite sign that something is catalytic converter / exhaust related.
Did you buy your car new or used?
As the guys mentioned, try to avoid wide open throttle operation until you figure out what your problem is.
What you are describing sounds like some sort of boost / fuel cut.
 Old 02-03-2012, 06:52 AM   #15
CJM
CJM's Avatar
Posts: 175   (View Stats)
CJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the world
Groaned at 5 Times in 2 Posts
This sort of thing happened to me when I shredded a MAF wire (poorly placed clamp + engine movement = chewed wire). So, if the above answers don't work, maybe it's a MAF problem?
Four Wheels:
2010 LSM Mazdaspeed 3 + Tech Package
-Cobb AP, K&N SRI, SURE Motorsports TIH, Forge BPV V1, AutoTechs, NATOR'd TP,
JBR 88 Duro RMM
-CJTuned - VD Numbers: 309whp/358wtq @22 psi tapering to 17psi (CF = 1.01, Smoothing 3)
-Tune with corn in progress!
-Personal 1/8 mile best: 8.515@82.76 mph; 2.087 60' on Eagle GT's. Plan on cracking 7's soon.
Two Wheels:
2009 Husqvarna WR300 - 2 Stroke Power!
-Bone Stock, already way too fast
GT3071 waiting to be rebuilt and installed
CJM is offline   Reply With Quote
The Following User Says Thank You to CJM For This Useful Post:
 Old 02-03-2012, 06:52 AM   #16
blue_train's Avatar
Could this be anything else?? Anyone have any other ideas or suggestions?
 Old 02-03-2012, 06:55 AM   #17
rfinkle2's Avatar
Groans: 235
Did you buy it new or used?
Can you log some normal driving and post the log?
 Old 02-03-2012, 06:58 AM   #18
patrick failman
karl-hungus's Avatar
Posts: 4,646   (View Stats)
Groans: 74
subbed for information on the cia mod.
The Following 5 Users Say Thank You to karl-hungus For This Useful Post:
CJM (02-03-2012), FightaX (02-03-2012), rfinkle2 (02-03-2012), ScarMS3 (02-04-2012), SofaKingAwesome (03-30-2012)
 Old 02-03-2012, 07:20 AM   #19
MS3-a(sore)ASS-rex's Avatar
Posts: 6,267   (View Stats)
Groans: 193
Groaned at 75 Times in 63 Posts
Rotten eggs smell=blown out/clogged catalytic converter
If the cats is clogged it could cause major back pressure issues causing the car to stumble. Mileage of the car?
MS3 has officially been retired to daily duty
Project 1G is officially under way; 1991 Eagle Talon TSi.
Stock Turbo & Stock Motor Grand Champion of the World!
NATOR PA
The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post:
 Old 02-03-2012, 07:49 AM   #20
CJM
CJM's Avatar
Do you have a rough idea of when cats typically clog/blow out?
My car has a sort of sulfuric smell (no stumble though), but it's only got 19k miles or so. It seems unreasonable to me that it would go out so soon.
Four Wheels:
JBR 88 Duro RMM
Two Wheels:
 Old 02-03-2012, 07:53 AM   #21
Groans: 193
It certainly shouldn't be within 20k miles of ownership. I'd take it to the dealer asap with that concern.
NATOR PA
CJM (02-03-2012), rfinkle2 (02-03-2012)
 Old 02-03-2012, 05:26 PM   #22
blue_train's Avatar
I bought the car used, its got 60,000 kilometers on it, shes been fine until this week,
The thing is, i cant even drive it in 2000rpms in any gear, im staying out of boost completely.
No engine light or anything.
I found the thread, but it doesnt show where the ignition spring part is located. Fml.
Where is the MAF sensor wire located ill check it all out
 Old 02-03-2012, 05:30 PM   #23
rfinkle2's Avatar
Groans: 235
Lex, a fellow canadian in need of your assistance.
I'm not sure what his issue could be.
 Old 02-03-2012, 05:44 PM   #24
Utah Mazdas
Black Metal's Avatar
Posts: 690   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 76
Groaned at 6 Times in 6 Posts
I know the plugs get blamed way to much but that is where I would start. Pull them out check for fouling and make sure they have the right gap.
- 06 Black Mica MS6 -
- GT3071R 24PSI - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- E20 - GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
Dynojet 301 AWHP 359 AWTQ SAE Corrected on K04 and Corn
Dynojet 391 AWHP 387 AWTQ SAE Corrected on 3071 and Corn
Black Metal is offline   Reply With Quote
 Old 02-03-2012, 05:54 PM   #25
CJM
CJM's Avatar
Dude, that's exactly what happened to me!
Go past 2k rpms and it starts bucking violently, right?
The MAF sensor is the little square thing on the intake that has five wires coming from it. Mine was actually torn, but I'd imagine the same thing could occur from having a poorly connected wire. So, check each wire's connections at both the MAF sensor and the ECU (other end of the wire). If your connections are solid, try cleaning your MAF sensor. If that doesn't work, you may need a new one.
But, first, check for what the other guys are suggesting. They know a HELL of a lot more than I do; I'm still working on getting my wings.
Four Wheels:
JBR 88 Duro RMM
Two Wheels:
 Old 02-03-2012, 06:05 PM   #26
blue_train's Avatar
well I dont understand how it happened last week, I turned the car off than it ran great, then today the problem came back, does this narrow anything down?
 Old 02-03-2012, 06:07 PM   #27
CJM
CJM's Avatar
So you're saying it happens sporadically?
In that case, it's probably not a MAF issue, because that would probably be a 100% of the time thing (I don't know, because I fixed my problem right when I got home).
It's more likely to be a plug problem, in that case.
Four Wheels:
JBR 88 Duro RMM
Two Wheels:
 Old 02-03-2012, 06:36 PM   #28
dspider's Avatar
Posts: 119   (View Stats)
dspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud of
use the AP and moniter everything you dont know who did what to the car before you got it . if you are monitering when this happens you may get lucky and see what the issue could be or even catch a log that might help figure it out..
like everyone said check plugs,maf and connections,and your cats. would be a good idea to check all the connections while youre in there (boost tubes and electrical).
[/SIGPIC]Just to be fair i hate everyone equally , so dont feel left out.
dspider is offline   Reply With Quote
The Following User Says Thank You to dspider For This Useful Post:
CJM (02-03-2012)
 Old 02-03-2012, 08:47 PM   #29
blue_train's Avatar
OK, so I started her up again, and she started to shudder, than it slowly got better and disappeared, wtf? so confusing
 Old 02-03-2012, 08:58 PM   #30
ChimmyChong's Avatar
Posts: 498   (View Stats)
ChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the world
Groans: 34
So your idle is fucked also??
Have you checked plugs/coils yet like 110% of people mentioned?
Or anything anyones mentioned??
If so clean maf also just to rule it out and it can't hurt anything 5to do that.
Since your gen1 with a good bit if miles try reading up on some EGR valve issue...
If they fall into your symptoms clean the valve (search for the howto) instead of spending $$$ on a new valve...
Just my 2cents... Kinda swasted rite noe lol
yeee
2010 Liquid Silver MS3
// JBR 3.5" WP // CS TMIC // KMD HPFP // 3" Catless DP/RP // TS Dual Port // Cobb AP // GS EBCS // ITV-22's // MD OCC // Dizzy Tune
// JBR Dog Bone RMM // JBR Heavy Knob // JBR Solid Shifter Bushings // JBR Short Shifter Plate // JBR RSB // JBR 80D PMM // H&R Springs //
// 6K HID // 35% tint // 12"RF with Infinity Amp // 17x8 Enkei RPF1's //
Waiting to put in: 3bar Map + MJ Harness & BNR S3
ChimmyChong is offline   Reply With Quote
The Following User Says Thank You to ChimmyChong For This Useful Post:
redmnsterut (03-30-2012)
 Old 02-03-2012, 09:15 PM   #31
Groans: 34
Nvm... Just read your post prob not EGR... Had the TLR thing going on lol
 Old 02-04-2012, 06:37 PM   #32
blue_train's Avatar
Ok guys,
I have checked my intake sensor, it looked fine, i felt inside my CAI and it seemed like it had quiet a bit of moisture in it, but i live in vancouver and its really misty and cold here. the cables looked fine, but I didnt check them with MM yet.
I did the Ignition spring mod, its no longer stuttering in 1st or 2nd, but when im in 3rd in past 3500-4500 rpm and almost at wot shut cuts right back, I tried two runs, with the same problem.
so tomorrow, I will grab spark plug spacers, and try that,
as for monitoring, what would you suggest I focus on? I dont want to be doing a whole bunch of runs.
thanks
 Old 02-04-2012, 07:22 PM   #33
uncorked11's Avatar
Posts: 1,126   (View Stats)
Groans: 156
What is your AFR?
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
uncorked11 is online now   Reply With Quote
 Old 02-04-2012, 08:54 PM   #34
Utah Mazdas
Groans: 76
Ok guys,
thanks
So you pulled the coil packs out but didn't take the time to check your plugs while you had everything off.
 Old 02-06-2012, 05:48 PM   #35
blue_train's Avatar
I didnt have the spacers to calibrate...
 Old 03-30-2012, 10:56 AM   #36
redmnsterut's Avatar
Posts: 838   (View Stats)
redmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the world
I am having the same problem on my MS6, in third when im doing logs or getting on the gas it will sputter/stutter for a quick second then be gone, once i feel it i back off the throttle. I am also getting this in 4th as well. Got some new plugs ordered and going to be doing the coil stretch as well.
Its weird cause it was doing this before I installed my tip in internals but worse, and now its not nearly as bad, but still relevant.
Subscribed to see what else my be causing this.
SURE RMM | SURE Shift Weight | SURE SSP | CP-E CAI | CP-E DP | CP-E TIP | COBB AP |SnailD Tunned| TEIN Springs | SU Turbosmart BPV | Autotech HPFP Internals | Autolite XP step colder plugs | JBR Heavy Shift Knob | CXracing FMIC | Block8 Single Gauge Pod | MSD DashHawk
Waiting to be installed: SURE Dreadnaught | JBR Shifter Bushings | SU Boost Tubes | P&P Intake Manifold
Soon to come:SURE Intake/TB TIG | SURE Juggernaught | RSB |
286awhp / 346lbs tq @4500 ft ASL
redmnsterut is offline   Reply With Quote
First Drive: 2011 Jeep Grand Cherokee redefines the Tipping Point Haltech Automotive News 0 06-19-2010 09:40 PM
Casino valets give Ferrari F430 to wrong owner, let him drive away Haltech Automotive News 3 05-14-2010 08:09 PM
Why is my car stuttering????? BMSPEED3 MazdaSpeed 3 - Engine, Transmission & Driveline 15 10-08-2009 07:09 AM
S S S Still S S Stuttering Stan-O
Cobb Access Port/Maps
2 11-21-2008 09:05 AM
Stuttering at 5K skubidoobie MazdaSpeed 3 - Engine, Transmission & Driveline 10 11-18-2008 04:39 PM
Page generated in 0.53885 seconds with 34 queries
