MAZDASPEED Protegé
> MSP - Wheels, Tires, Brakes & Suspension
 Old 09-01-2018, 10:50 PM   #1
leftydog1961's Avatar
Posts: 2   (View Stats)
leftydog1961 is an unknown quantity at this point
Default Coilover assistance needed please
Hi! I have a 2003 MSP and my right rear strut, and coil look to be blown. coil is loose in the strut, and bangs hard with bumps. I would like to replace this with a strut assembly or coilover which avoids compressing the spring for installation. Most online auto shops do not specify MSP as an option for their coil overs, and I do not want to chance buying the wrong part which would fit the protege but not the mazdaspeed version.
anyone have ideas, links where i can get the entire assembly (right rear) specifically for the MSP.
Thanks,
leftydog1961 is offline   Reply With Quote
 Old 09-03-2018, 09:04 AM   #2
Natey's Avatar
Posts: 535   (View Stats)
Natey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the world
Groaned at 28 Times in 13 Posts
Springs sag, but don't blow out. It's probably your strut that's blown. How many miles are on the car?
A set of Tokico Blue strutss are what your MSP came from the factory on. I'd replace the struts with those. Any coilover you find for a Protege these days is gonna be universal type crap that's not tuned to our cars, so your ride and handling will suffer.
A 30 dollar Harbor Freight spring compressor is easy to use and will save you a few bucks, too.
https://www.harborfreight.com/automo...set-63262.html
'93 RX-7: 100% CARB approved. Just some wheels and stuff.
'03.5 Mazdaspeed Protege: Custom clunk and turkey call.
'12 4Runner Limited: Hollister Hills pinstripes, dog hair, beach sand, melted surf wax, a few french fries under the seat...
Natey is offline   Reply With Quote
 Old 09-03-2018, 04:17 PM   #3
Thanks, I finally took out the strut today after a 3 hr tug of war, and having to dremel off the rusted sway bar link. this is NOT a fun job!. In the process, the ratcheting mechanism of the seat belt (removed the bolt on top holding the seatbelt to the frame) seems to have sucked in all of the seatbelt and now it wont unravel (yet another problem!!) . But anyways,. i just want to buy a cheap strut and bearing strut mount. What are my options? Not really interested in ride and handling cause its old and rusty so its a beater.
the coil does look rusty and its no longer seated properly in the rubber holders at the top and bottom (they are pretty much torn or missing pieces).
Is it worth replacing the spring as well.
this way, i can just buy a strut and new spring and top mount and not have to remove the old spring. I am a bit nervous using the spring compressor so would prefer to just have to do this once on the new setup and just trow away the old strut and coil.
thanks
 Old 09-06-2018, 02:34 PM   #4
Natey's Avatar
Springs:
Suspension Spring Sets - Mazda Protege Performance Parts
You'll need the bump stops too since you're in a Mazdaspeed Protege which is a little lower than a lesser model.
Struts:
https://www.streetunit.com/Tokico_Bl...ge_p/hb222.htm
This, along with the racing beat swaybars are what the MSP came on from the dealership and will take you another 100k miles easily.
Access Tuner Assistance Needed!! kkostec MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 06-14-2018 05:56 PM
Initial Map setup (Assistance Needed) mmanda2290 MazdaSpeed 3/6 - ECU Computer Tuning 8 02-10-2013 06:38 PM
MAF cal log assistance needed bfak66 MazdaSpeed 3/6 - ECU Computer Tuning 8 10-17-2012 07:36 PM
Assistance needed! MSpeed34 Mazdaspeed3/6 General Discussion 4 02-02-2012 10:01 PM
Page generated in 0.25670 seconds with 22 queries
