MAZDASPEED Protegé
> MSP - Wheels, Tires, Brakes & Suspension
 Old 02-03-2015, 03:38 PM   #1
DiLoMSP's Avatar
Posts: 11   (View Stats)
DiLoMSP will become famous soon enough
Default Suspension Options
Hey everyone
I'm looking to upgrade my suspension on my mazdaspeed protege.
I am looking for options and opinions.
What's out there?
Who runs what and how do you like it?
Please post pics also.
DiLo
DiLoMSP is offline   Reply With Quote
 Old 02-03-2015, 04:24 PM   #2
Code Monkey's Avatar
Posts: 7,671   (View Stats)
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
The Following 4 Users Say Thank You to Code Monkey For This Useful Post:
brandon3212 (02-04-2015), hatchedspeed3 (02-03-2015), nilashish (02-03-2015), WetzMS3 (02-04-2015)
 Old 02-04-2015, 06:15 AM   #3
brandon3212's Avatar
Posts: 425   (View Stats)
Your going to go far....
07 Speed 3
Handling: H&R Springs, Koni yellow shocks, JBR .250 Competition RSB, Whiteline poly control arm bushings, Custom 1/2" rod end RSB links, JBR 88D Trilogy, steel RMM bushings, Sparco Pro 2000 race seat (driver), Kirkey race seat (passenger), shift plate, 18X10.5 +15 RPF1, 275/35 18" Nitto NT01
Brakes: Wilwood 6 piston calipers, Cobalt Friction XR1 race pads
Power: Custom 3.5" intake, Synapse Diverter valve, dual 3" Hood Exit, BNR S3, Treadstone 3126 core, 3 port EBCS, 3" custom cold pipe, 2.5" custom underroute hot pipe, Aquamist HSF4
 Old 02-04-2015, 07:09 AM   #4
DiLoMSP's Avatar
Ok. I'm replacing bad struts not just upgrading. Figured i might as well upgrade while I'm doing it.
DiLo
 Old 02-04-2015, 07:26 AM   #5
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 02-04-2015, 07:44 AM   #6
Drive By Fire's Avatar
Posts: 448   (View Stats)
Drive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the world
I'm Feeling nice.
The Official MS3 Suspension Thread
Donate Brownie.
NJ NATOR
Drive By Fire is offline   Reply With Quote
 Old 02-04-2015, 08:42 AM   #7
license2ill's Avatar
Posts: 313   (View Stats)
license2ill is infamous around these partslicense2ill is infamous around these parts
Groans: 30
Groaned at 132 Times in 57 Posts
What's an MSP?
license2ill is offline   Reply With Quote
 Old 02-04-2015, 08:43 AM   #8
WetzMS3's Avatar
Groans: 430
Originally Posted by license2ill View Post
What's an MSP?
Mazdaspeed Protege, brownie.
2013 MS3 Black Mica
Raider (02-04-2015)
 Old 02-04-2015, 08:58 AM   #9
Groans: 30
I was just f'n with the op, but thanks for your help, cousin.
 Old 02-04-2015, 09:20 AM   #10
Silverdecepticon's Avatar
Posts: 277   (View Stats)
Silverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond repute
Holy crap.....READ and use the google search bar. Sheesh.....
06 MS6
GTX3076R, Xs power exhaust manifold(suxs), ebay dp(sux), 3" catless exhaust, 4" HTP TIP, Sure shortshift & counterbalance, COBB V3, Autotech HPFP internals, Grimmspeed EBCS, CP-e RMM, Perm PCV plate, JBR EGR delete, JBR BSD, JBR Oil pan baffle plate, Kozmic OCC, rebuilt fuel injectors, safeseal injector seals, Bosch 3 bar MAP, new gaskets(valve cover, throttle body, intake manifold, exhaust manifold, dp), cleaned valves and chambers, CP-E motor mount & rear-diff mount, ATP-INT-003 FMIC, Stratified Guardian Angel set to 24psi, Stoptech rotors, Hawk HPS pads, Forge BPV, home-made strut mounted tower bar, badgeless, special edition 19" anniversary rims. Battery finally relocated to trunk with custom box. New VVT stuff, BC coilovers, new OEM Clutch, fidenza lightweight flywheel, replaced driveshaft again, replaced power steering pump again, busted rear diff side bolts again....FML
Silverdecepticon is offline   Reply With Quote
 Old 02-04-2015, 11:10 AM   #11
Crarrs's Avatar
Posts: 1,662   (View Stats)
Groans: 98
Holy crap....LOOK at the abundant amount of information available to the OP in this overflowing MSP Suspension section!
MSP - Wheels, Tires, Brakes & Suspension - Mazdaspeed Forums
2004 MSM TiGrey
The Following User Says Thank You to Crarrs For This Useful Post:
 Old 02-04-2015, 11:26 AM   #12
Type in coilovers in the search bar.
06 MS6
The Following User Says NO Thank You to Silverdecepticon For This Un-useful Post:
Crarrs (02-04-2015)
 Old 02-04-2015, 12:36 PM   #13
Crarrs's Avatar
Groans: 98
I guess I forgot that MS3 suspension parts are easily adaptable to the Protege.
2004 MSM TiGrey
The Following 2 Users Say Thank You to Crarrs For This Useful Post:
Dizzy Turbo (02-04-2015), Raider (02-04-2015)
 Old 02-04-2015, 05:20 PM   #14
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
What a lot of shit above.
OP, Tokiko Blues are what it came with. Koni yellows will suit nicely for a speed protege.
The Following 2 Users Say Thank You to Raider For This Useful Post:
DiLoMSP (02-09-2015), Nliiitend1 (02-04-2015)
What are my options? shawn. Mazdaspeed3/6 General Discussion 17 04-04-2014 06:33 PM
Mazdaspeed 6 (Mazda 6 MPS) suspension options robby85 MazdaSpeed 3/6 - Suspension & Brakes 13 12-18-2012 06:23 AM
k04 options Boogie_69 MazdaSpeed 3/6 - Turbo Induction 39 04-08-2012 08:09 PM
BOV/BPV options Derek88 MazdaSpeed 3/6 - Turbo Induction 12 04-18-2008 05:58 PM
Page generated in 0.33654 seconds with 28 queries
