Like Tree5Likes
 Old 02-15-2016, 01:26 PM   #81
Nitro's Avatar
Posts: 229   (View Stats)
Nitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond repute
I have used my windshield washer tank for several years now without a problem.
COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP
CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims
Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85
Stratified Tune
Nitro is offline   Reply With Quote
 Old 02-15-2016, 03:07 PM   #82
mituc's Avatar
Posts: 3,527   (View Stats)
Groans: 111
Yeah, but you can't spray the windshield or headlights with 50+% methanol. Not if you care for your car.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 02-15-2016, 03:11 PM   #83
GEE1989's Avatar
Posts: 182   (View Stats)
GEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant future
+1 on that. I need my wiper fluid around where I live. Lots of dust and construction. That's convenient though. Whatever gets the job done haha
Sent from my SM-G920P using Tapatalk
08 MS3
Corksport turbo, built motor, meth injection, and FREEKTUNED
GEE1989 is offline   Reply With Quote
 Old 02-15-2016, 07:51 PM   #84
Nitro's Avatar
Fair enough. I just use winter washer fluid most times. Alex at Stratified tuned the car and installed the meth kit. It seems to work well, although he said the filter could get clogged over tine. I just pulled the d07 to check it after 2 years and it looked good. Cleaned it anyway but it seems to be a simple set up that works on my setup.
Stratified Tune
 Old 02-16-2016, 07:01 AM   #85
Jeff23spl's Avatar
Posts: 2,163   (View Stats)
Some windshield washer fluids don't have much additives and are made of meth and water. it is probably made of more water but for cooling purpose it will work.
but indeed, 100% meth to clean the windshiel may not be the best.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 02-16-2016, 07:05 AM   #86
Xxblinddzxx's Avatar
Posts: 126   (View Stats)
Xxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud of
Groaned at 26 Times in 11 Posts
Originally Posted by Jeff23spl View Post
Some windshield washer fluids don't have much additives and are made of meth and water. it is probably made of more water than meth but for cooling purpose it is probably good.
Especially the cheaper blue one with less stuff than some with silicone additive or other stuff in it. In case of emergency i will probably use it.
If im not mistaken , windshield washer fluids are somewhere arround 30% meth and 70% water.. would deff use it in case of emergency.
Xxblinddzxx is offline   Reply With Quote
 Old 02-16-2016, 07:37 AM   #87
GEE1989's Avatar
That's good to know. I didn't know methanol was that common in products on the shelf.
08 MS3
 Old 02-16-2016, 07:41 AM   #88
Jeff23spl's Avatar
here i read the ''Laurentide'' is one with a little more meth in it....It would probably be cheaper to use for a low meth mix than buying meth at the store.
Wife drive 2010 CX7
 Old 02-16-2016, 07:43 AM   #89
mituc's Avatar
Groans: 111
Windshield washer fluids may also have glycols, which are also alcohols but they are greasier and their purpose is to blend with the less viscous content (methanol and water) and keep the around for longer and also to lubricate the wiper blade when sliding over the windshield. Also glycols are not great for engines, they may clog the nozzles as well as the higher concentration of die.
However, without these glycols the mix would be more aggressive with the clear coat of the car as well as with the plastic trims and it's not uncommon to see the clear coat and paint making bubbles where the water/meth mix stays more.
So that is why you should not use winter washer fluid as water/meth mix for spraying into the engine, and also why you should not use a water/meth mix as washer fluid.
 Old 02-16-2016, 07:43 AM   #90
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Careful using windshield washer fluid as a meth mix. You're nozzles are likely to clog faster and buildup in the pump could occur over longer periods of time.
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 02-16-2016, 07:49 AM   #91
as i said, i would only use in case of emergency
Nitro likes this.
 Old 02-16-2016, 07:52 AM   #92
WetzMS3's Avatar
Groans: 430
Just trying to be helpful. Additionally, there really is no such thing as an emergency with meth. You'll be tuned for it while under boost when it is sprayed by whatever controller you use. So, if you happen to run out, all you have to do to avoid issues is granny it around out of boost. The only emergency with meth is running out or not spraying when the ecu thinks it should be.
2013 MS3 Black Mica
 Old 02-16-2016, 07:52 AM   #93
GEE1989's Avatar
Im planning on running 100 meth and getting a 5 or 7 gallon tank for the trunk so hopefully I won't run into the issue of it running out on me. Do they have meth pumps like gas pumps?
08 MS3
 Old 02-16-2016, 10:26 AM   #94
Jeff23spl's Avatar
I agree but like the murphy's law, it always that one time where you miss something interresting...So i carry a spare gallon of mix n the car to avoid it
Wife drive 2010 CX7
 Old 02-16-2016, 10:28 AM   #95
WetzMS3's Avatar
Groans: 430
Oh, I definitely carried a spare gallon in the trunk when I ran meth. But that was simply to avoid having to avoid boost. Lol.
2013 MS3 Black Mica
 Old 03-18-2016, 11:48 PM   #96
OfficerMazda's Avatar
Posts: 19   (View Stats)
OfficerMazda will become famous soon enoughOfficerMazda will become famous soon enough
I wouldn't be able to. Where I live the dust and dirt builds up so fast, I'd be stopping at gas stations to wash my windshield every time I got in my car. Hahaha I've heard of people using it in this sense though, never actually seen the set up. I think i'd be to worried about heat factor having something like that under the hood catch fire. Maybe I'm over thinking.
Give credit when credit is due.
OfficerMazda is offline   Reply With Quote
 Old 03-19-2016, 12:27 AM   #97
Nitro's Avatar
It has worked flawlessly for years now. I don't run 100% Meth, although I have tried it. It's not beneficial as I am already running an E85 Mix. Having meth inside the car was a no go for me, but others have done it successfully and are comfortable with it in the rear hatch.
Stratified Tune
 Old 03-19-2016, 12:49 AM   #98
Yeah I guess if i even got far enough into it where I even considered it, having my son in the car I would probably look into something outside or maybe even go a similar route as you did. I can just see my son wanting to play with everything. Main reason I refuse to relocate the battery.
Nitro likes this.
 Old 03-19-2016, 01:10 AM   #99
Nitro's Avatar
I feel the same. I have my boys in the car all of the time.
Stratified Tune
 Old 03-20-2016, 08:19 PM   #100
sheston's Avatar
Posts: 1,847   (View Stats)
I've been running for a year and a half at least using the washer tank for 100% Meth. Haven't had any issues. I don't drive much so get away with just filling it every weekend
COMPARISON: Labonte Stage 2 Water/Meth Kit vs. AEM Water/Meth Kit The Great NY Mazdaspeed Forums User Reviews 2 01-19-2013 08:48 AM
TMIC w/Meth vs. FMIC w/Meth adlpb 2010 MS3 - Turbo Induction 95 09-10-2011 05:32 PM
Problem. Without meth tune is great. On Meth tune shits the bed. dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 16 09-06-2011 06:58 PM
Page generated in 0.39265 seconds with 28 queries
